    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 07-02-2015, 04:49 AM   #31
Thanks, running a Savoy 1258TG in my 410.3, overall been happy. What should I run on the EB48.3? Running Tekin RX8 Gen 2, so it should handle power hungry servos.
Riflebuilder is offline   Reply With Quote
Old 07-02-2015, 06:07 AM   #32
There will be many recommendations on servos but I run the Savox 1268 in both my buggy and truggy and have been more than happy. The performance is great on 7.4V but only decent on 6V so crank up the BEC on that Tekin.
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 07-02-2015, 06:32 AM   #33
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Originally Posted by fizzy View Post
I'm getting this as my first ebuggy I was wondering what are the essential spares/upgrades needed and if anyone can advise on a good 1/8 ESC/ motor combo as I've only ever ran electric 1/10 touring cars any advice/ help would be great
get the Tekno al. servo horn.that should really be the only upgrade you will need.
the tekin gen2 esc and 1900kv motor is used the most.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 07-02-2015, 01:14 PM   #34
Ordered the Savox 1283SG for the buggy. I figured this would be the best for what I'm looking to do.
Old 07-02-2015, 01:21 PM   #35
Trader Rating: 16 (100%+)
That's what I have in my EB48.2. Works great!
MX304 is offline   Reply With Quote
Old 07-02-2015, 01:25 PM   #36
Was hoping someone would say that!!
Old 07-03-2015, 05:42 AM   #37
I'm getting my 48.3 at my local shop at retail pricing, but Amain will have them at $60 off. Figured I would help someone!!
Old 07-03-2015, 05:45 AM   #38
Originally Posted by micrors4guy View Post
Smc and promatch both have quality 4s packs at good prices.
Checked out SMC batteries. Price is half the Protek at Amain. The only problem is what connectors should I be running?? My 410.3 runs 4mm bullets and I would like to standardize them. From what I understand the SCT needs the best connectors as possible because of the amp draw while the 1/8 ebuggies can get by with less?? Any thoughts?
Old 07-03-2015, 06:02 AM   #39
werner sline's Avatar
any picture with the body ? can't wait to see this massiv front tower !!
werner sline is offline   Reply With Quote
Old 07-03-2015, 07:11 AM   #40
Dan.J's Avatar
Trader Rating: 21 (100%+)
Most run Deans on there buggies, I too have bullets on my 410.3 and yes there is ALOT of amp draw on a heavy 4wd SCT with a 2s setup.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 07-03-2015, 07:20 AM   #41
550 size motors continuously generates maximum power around1000 watts while buggy motors reach around 1300 watts(guessing from neu motor chart). Since buggies use 4s lipo compared to 2s lipo in sct, amp draw will be significantly lower in theory.
murat61 is offline   Reply With Quote
Old 07-03-2015, 07:43 AM   #42
So dean's should be good to go then?
Old 07-03-2015, 07:57 AM   #43
Yes, that will work fine.
Old 07-03-2015, 09:01 AM   #44
Hoese37's Avatar
Deans really work fine in either.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 07-03-2015, 09:08 AM   #45
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
EC5 and forget about it.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
