    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 09-24-2015, 10:12 PM   #376
lowspark's Avatar
That wrench is on my wish list... come on payday !!!
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 09-24-2015, 10:36 PM   #377
Originally Posted by rcgod View Post
Stock setup has no washers between ball and rack. Use the extra washers on the other end of the ball to keep the screw from rubbing the underside of the top plate and as a convenient place to keep them for when you want to change the bump steer.
Ok, that makes sense as they have both ends with the washers floating at the opposite end that makes any mechanical changes. Thanks for that!
I have not looked up any actual setup sheets, what is typical washer count on the inside and outside for the steering arms?
Fasttrak is offline   Reply With Quote
Old 09-24-2015, 11:07 PM   #378
rcgod's Avatar
Trader Rating: 27 (100%+)
Depends on the track. Lower bite most use less washers. But it depends on the steering feel you're trying to get.
rcgod is offline   Reply With Quote
Old 09-25-2015, 08:00 AM   #379
Sounds good, like most vehicles this is going to be a track specific and driving style adjustment. I added one washer on both ends and left the other three under the ball. With a couple hours each night I have the chassis complete up to building the shocks, going along smoothly and looking good. You gotta love that in-line drive shaft setup, it just looks proper.
Being that I am at the shock build and this kit offers two different setups, I am curious what the advantages and disadvantages are to each type of shock build? What did most folks opt for, vented or emulsion build?
Old 09-25-2015, 08:13 AM   #380
rcgod's Avatar
Acuallt there are 3 options. Emulsion, vented bladder and non vented bladder. I opted for vented bladder mainly because I find it easier to set rebound consistently between shocks. I know some of the other guys have tried emulsion I'm sure they will give their experiences.
Old 09-25-2015, 09:18 AM   #381
rcgod's Avatar
In case anyone is thinking of trying it, the losi electric clutch fits perfect.
Dialed RC Hobbies
Old 09-25-2015, 10:28 AM   #382
jmcelroy42's Avatar
Are they going to have carbon fiber towers for the .3? or do they have them already and I cant find them?
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 09-25-2015, 10:34 AM   #383
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Stupid question but, does it take a specific brand clutch bell?
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 09-25-2015, 10:50 AM   #384
suzukipro's Avatar
Trader Rating: 23 (100%+)
The newest carbon towers out are for the SCT410.3 & EB48SL which are different than the truggy towers on the EB48.3
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 09-25-2015, 11:40 AM   #385
rcgod's Avatar
You might be able to make it work with a different brand but I used losi. The Tekno clutch bells for the nitro car are the same style as losi but this is the only one I could find in an 18t.
Dialed RC Hobbies
Old 09-25-2015, 11:46 AM   #386
MOE
MOE's Avatar
Thanks for the info, curious how this system works on an electric car. Never seen anyone run one.
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Old 09-25-2015, 12:53 PM   #387
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
There are currently no plans to offer the towers in carbon fiber. Your best bet would be to email Xtreme Racing and request them to make some.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 09-25-2015, 04:47 PM   #388
rcgod's Avatar
I used to run the Tekno version on my original eb48 and it worked great. Made the car easier to drive on low bite. Smooths out the low end punch. You can use different springs and shoes to tune it.
Dialed RC Hobbies
Old 09-25-2015, 05:13 PM   #389
I am real curious the advantage to running the nitro style clutch on an electric buggy? Is it that the drive line is disengaged quickly to help rotate through tighter corners? Never even realized that was being done on the electric side of the industry.
/poke rcgod Menthol Camels?
Old 09-25-2015, 07:00 PM   #390
rcgod's Avatar
The original Tekno traktion drive you could run as a nitro style clutch but you had to use mechanical brakes and 2nd servo. You could also configure it as a slipper, which is how the losi is made to work. Instead of the springs pulling the shoes in, they push them out in constant contact with the clutch bell. The harder the spring the harder they are pushed against the clutch bell and less slippage. Just smoothes out the buggy in acceleration and a little in braking. It's a nice tuning option to have.
Dialed RC Hobbies
