    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 02-03-2017, 02:38 AM   #2821
Originally Posted by latentspeed View Post
installed the new steering and ackerman plate. Such a big difference. Really big improvement. Still a lot of steering without feeling twitchy. It's a must have. All those who didn't like how aggressive the .3 was might change their mind with the updated steering. The buggy can drive much harder. The old steering somewhat prevented hard driving and confidence, but this update makes a very positive difference.
Most brands don't change their steering feel, but I'm glad tekno is willing to make changes for the better.
Other than the ackerman plate, steering bellcrank and two 3x10mm screws, cutting out extra space in the body for the new steering needs to be done. I'd recommend getting shorter turnbuckles because I have them as tight as possible without digging into the pivitballs, yet still getting toe in.
Do you have a part number on the shorter turnbuckles ?
Expose193 is offline   Reply With Quote
Old 02-03-2017, 09:14 AM   #2822
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I am back after a very long hiatus
I have eb48.2
what is needed to upgrade to 48.4?
ALSO, IS this the official thread for the continuing 48.4?
thanks!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 02-03-2017, 09:16 AM   #2823
jmcelroy42's Avatar
I have eb48.2
what is needed to upgrade to 48.4? Read the last 3 pages
thanks!
.4 thread...
http://www.rctech.net/forum/electric...-4-thread.html
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 02-03-2017, 09:18 AM   #2824
I have eb48.2
thanks!
There is another thread for the .4. There is no affordable way to go from the .2-> the .4. If you'd like to upgrade to the .3, which is still a very good car, then here is a package
http://fiercercsolutions.com/Tekno-E...kit-FRC010.htm
Add in the .4 steering stuff, and I think you'd be happy.
http://fiercercsolutions.com/TKR8104...on-TKR8104.htm
http://fiercercsolutions.com/TKR8100...84-TKR8100.htm
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 02-03-2017, 11:00 AM   #2825
boudin4evr's Avatar
I just found the official .4 site
I DO NOT have time to read anything but it might be more feasible to
buy The New 48.4
My 48.2 is only 1 spring season old with TONS of parts!
Marc Richard
Old 02-03-2017, 11:02 AM   #2826
boudin4evr's Avatar
wonder about how much I can get for a .2 thats fresh with tons of parts
I still do not know what parts to keep yet!
Marc Richard
Old 02-03-2017, 11:26 AM   #2827
bigboyz12000's Avatar
Good question. I still have my .2 as well and may post it on here for sale. Probably ask $200obo(roller) as I have spare parts as well.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 02-03-2017, 12:49 PM   #2828
suzukipro's Avatar
Trader Rating: 23 (100%+)
If you race any indoor, the .2 is an awesome indoor buggy if you lighten it up with a PRO4HD 1850 or T8i 1950 motor and the 4500/3600 Mah SMC 4s batteries. aluminum hubs, SCT410 center driveline and or carbon towers and you start to get a nice advantage.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 02-05-2017, 08:47 AM   #2829
mxrcracer23's Avatar
In the process of installing the new Ackerman plate and bell cranks on the .3, what is the recommended starting setup for the ackerman? Are the newer setups on the tekno site with the new plate or old? I know it's probably been asked but I couldn't find the info.
mxrcracer23 is offline   Reply With Quote
Old 02-05-2017, 10:39 AM   #2830
The middle hole is the recommended hole to start with on the new ackerman bar. I don't believe the new bar was out at the time the setups came out, but I still would follow them if that's what you wanted to try out.
qstorm777 is offline   Reply With Quote
Old 02-05-2017, 03:31 PM   #2831
jason07's Avatar
I asked the same questions a few days ago. Hopefully he responds to you.
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 02-05-2017, 04:56 PM   #2832
I used lunsford lns1450
Old 02-05-2017, 08:07 PM   #2833
The .4's use tkr5050. Wish they would have just came out with a new part because it's a little thinner, the mark faces the opposite direction of all the other turnbuckles and it's from the 1st gen of the sct.
Old 02-06-2017, 03:19 AM   #2834
Hadz's Avatar
EB48.3 to EB48.4 upgrade.pdfThis Spreadsheet may help those thinking to upgrade to the .4 or parts thereof. Prices are correct at time of post and not necessary the best deal available. But will give you a good estimate. Sorry could not get the xls spreadsheet to load just the pdf.
SCTE 2.0, RX8, T8 1850, Hitech HS-7955TG
Tekno EB48.4 Tekin 1950 / RX8 Gen2, Hitech 9370TH
Hadz is offline   Reply With Quote
Old 02-06-2017, 03:55 AM   #2835
werner sline's Avatar
thank you for the parts number. How come fierce solution is so much cheaper than amain ??
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
