    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 08-29-2015, 08:42 PM   #256
Originally Posted by HoldDaMayo View Post
Took some video of the EB48.3 today at the track, we have a super loose surface and pretty bumpy/rutted. The EB48.3 laps start a couple minutes in, first part of the video is SCT410.3 and the A-block breaking. Let me know if you have any ideas for reducing over-steer when powering out of corners on a very loose surface... and yes, I do believe the best improvement I can make is to ease into the throttle a bit nicer, but any other thoughts would be appreciated.
+ YouTube Video
Can some copy and post the link for this video. I can't find it from my phone. Thanks.
skyler hays is offline   Reply With Quote
Old 08-30-2015, 12:59 AM   #257
https://www.youtube.com/watch?v=iPirLbzGKd0
ebay007 is offline   Reply With Quote
Old 08-30-2015, 08:03 AM   #258
Got my 48.2 with the .3 upgrades yesterday. Shocks towers and steering upgrades. Car was sweet. My .2 was really good but this does jump a bit better and more stable. Running black front springs 32.5 orange rear 35 tried pink front but didn't like it as much.
turtle189 is offline   Reply With Quote
Old 08-30-2015, 10:01 AM   #259
Default Batteries
Anybody run two 2S packs in the .3? Wondering how you do that and if you have any pics?
Thanks.
qstorm777 is offline   Reply With Quote
Old 08-30-2015, 11:37 AM   #260
rcgod's Avatar
Trader Rating: 27 (100%+)
Thanks.
Here's one way to do it.
Tekno RC EB48.3 Thread-960868d1345568268-tekno-rc-eb48-thread-img_0171.jpg.cf.jpg
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-30-2015, 04:50 PM   #261
Is it just the straps holding it in place?
Old 08-30-2015, 05:56 PM   #262
rcgod's Avatar
Not sure. Grabbed the pic from google. Could always tape them together with strapping tape or double sided tape.
Dialed RC Hobbies
Old 08-30-2015, 06:54 PM   #263
Trader Rating: 75 (100%+)
+ YouTube Video
A quick change that you can try is to raise the rear camber link up one hole on the tower. On my .3 this is a very noticeable change, and it really slows down the rear end rotation of my car. It was soo much of a change that I didn't like it because the car just drug its arse through turns and was very slow at cornering.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 08-30-2015, 08:35 PM   #264
Mizchief's Avatar
Thanks.
I do on the ET for 20min mains when running with the nitros. I was using two bullet packs with low profile bullets with them stacked vertical. When those wore out I switched to EC5's with the packs wired into on 4s plug for easier charging.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 08-30-2015, 09:08 PM   #265
Ok. I currently have a serpent 811e and bought 4 2s packs this year. Really want to switch to eb48.3 (sct and trug are tekno), but don't want to have to buy more batt packs.
Old 08-30-2015, 10:04 PM   #266
rcgod's Avatar
If anyone needs a good servo better jump on this they're almost gone.
Ko power servos on amazon for $39
Old 08-31-2015, 07:33 AM   #267
RokleM's Avatar
Trader Rating: 33 (100%+)
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 08-31-2015, 08:23 AM   #268
rcgod's Avatar
Originally Posted by RokleM View Post
Ko rsx power servos were being blown out on amazon for $39. They're $150 everywhere else. Sorry couldn't get the link to work. All gone now.
Old 08-31-2015, 09:49 AM   #269
wrightcs77's Avatar
Trader Rating: 523 (100%+)
I bought nine of them last night
wrightcs77 is offline   Reply With Quote
Old 08-31-2015, 11:15 AM   #270
Thank you for this advice, I was just reading up on roll centers and this sounds like a fantastic idea for the setup on that track... Cheers!
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
