Tekno RC EB48.3 Thread >
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 12-09-2016, 07:55 AM
  #2641
Trader Rating: 22 (100%+)
I have no idea what he's talking about so I didn't comment. And I'm bored, at work (never a good combo) and happened to hop on here. My shocks are fine. I don't cover them with anything.
Bob Barry is offline
Old 12-09-2016, 07:56 AM
  #2642
Originally Posted by ezlight
You mean like the trophy race at hillside in late october? 109 entries on october 23rd, and a bunch of new faces. Can't complain 1 bit.
But yeah....4wd sct and prolite for me now. (Although I'm taking this month off.)
we live like 500 miles apart
Old 12-09-2016, 08:41 AM
  #2643
Yup, and we'll meet in the middle at Motorama to race together 1 weekend a year.
ezlight is offline
Old 12-09-2016, 10:27 AM
  #2644
shadaloo's Avatar
Originally Posted by MX304
Any of the shock covers that go on over the spring like that can cause handling issues. You won't find too many racers that can give opinions on them because we simply don't use them.
Ah ok, see I figured they would cause issues.. I don't mind using normal boots. Just I saw people on facebook saying the covers don't cause any binding issues, and some people even said that normal boots cause more issues than the covers? Ill just stick with the boots if that's the case. I've just seen a lot of talk the past few days about the covers so I figured I'd ask. Thanks for the reply!
shadaloo is offline
Old 12-09-2016, 10:53 AM
  #2645
goehm's Avatar
Trader Rating: 45 (100%+)
Servos: Make sure you are at least at 300oz torque. I prefer closer to 400 if possible. I am not nearly as focused on speed. In fact, my preference is around .11-.14 for speed. Which if you look at alot of the top pros, they run that too. For example, Tessman and Cav run the 2274 from Savox....don't have the specs in front of me, but I think it's like .10 at 370ish torque.
ProTek makes really nice servos as well, so definitely check them out.
347 oz-in, .08 @ 7.4
goehm is offline
Old 12-09-2016, 11:14 AM
  #2646
goehm's Avatar
Originally Posted by shadaloo
Does anyone use the shock covers from badhorsie.com ? I noticed they have basically every brand aside from Tekno... Was wondering what size would fit Tekno, or if anyone knew of a better option?
I would use the Tekno boots vs. over the spring covers, but if I wasn't me and was going to go with these shock socks, then check out their measuring section here:
http://www.badhorsie.com/faq/shock-s...asurement.html
Tekno has 16mm shock bodies w/ 65-85mm springs. However, I don't know the actual spring diameter, but I suspect that the 'small' springs (for springs 16.5 - 17.5mm, up to 102mm in length) would fit though a quick measure would tell you for sure.
goehm is offline
Old 12-11-2016, 10:58 AM
  #2647
I've been using these balloons with good luck
https://m.youtube.com/watch?v=cUlXi6SKseA
Vujkovicv is offline
Old 12-12-2016, 12:52 AM
  #2648
shadaloo's Avatar
Yeah ive been using those for awhile. Was curious about the covers since I keep seeing people talk about them, ill keep my balloons I guess tho.. Hah
shadaloo is offline
Old 12-13-2016, 07:24 AM
  #2649
Hi, i bought the eb48.3 and i have one question. The front suspension arms have a lot of separation, is normal?
guren is offline
Old 12-13-2016, 08:02 AM
  #2650
Can you post a picture of what your talking about?
ezlight is offline
Old 12-13-2016, 09:15 AM
  #2651
shannow's Avatar
If you're talking about the play on the hinges then it's normal and should be less as you add sweep/kickup.
shannow is offline
Old 12-13-2016, 10:02 AM
  #2652
mxrcracer23's Avatar
Just wanted to make sure that the new steering components will work on the .3? Can anyone that has ran them give some feedback on their performance.
mxrcracer23 is offline
Old 12-13-2016, 10:19 AM
  #2653
Yes, but you have to use it all. (ackerman, bellcrank, and I believe spindles.) All are in stock at fierceRC.
ezlight is offline
Old 12-13-2016, 10:31 AM
  #2654
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
To add to this, you'll also need to trim the front of the mudguards and body for clearance as well as cut your steering turnbuckles down (remove about 3mm from both ends) or buy shorter ones from lunsford.
Last edited by Matthew_Armeni; 12-13-2016 at 11:14 AM. Reason: Changed 2mm to 3mm.
Matthew_Armeni is offline
Old 12-13-2016, 10:44 AM
  #2655
jmcelroy42's Avatar
Originally Posted by Matthew_Armeni
To add to this, you'll also need to trim the front of the mudguards and body for clearance as well as cut your steering turnbuckles down (remove about 2mm from both ends) or buy shorter ones from lunsford.
Can you or someone else explain what the new steering stuff is supposed to do? different geometry, what is supposed to be better about it?
jmcelroy42 is offline
