    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 12-06-2016, 03:12 PM   #2596
Any talk of a new model coming out?
Hard to pass this up.
rydaddy is offline   Reply With Quote
Old 12-06-2016, 03:53 PM   #2597
mkl
Pure speculation- but I think there has to be something. On the MT410 thread it was stated that the steering geometry had changed completely. If you look at the drag link, it is a fair bit different than what is currently used.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 12-06-2016, 04:00 PM   #2598
Trader Rating: 16 (100%+)
If you look on the new parts page on Tekno's site, you'll see the new steering parts. They list them as being compatible with the EB/NB 48.4 so I'd say we'll see new cars sooner than later....
http://www.teknorc.com/shop/tkr8100-...ized-ebnb48-4/
MX304 is offline   Reply With Quote
Old 12-06-2016, 05:30 PM   #2599
I have been hearing rumors about one, I guess that confirms it.
hpiaddict is offline   Reply With Quote
Old 12-06-2016, 05:41 PM   #2600
I went ahead and purchased one, I just couldn't pass up this great deal. When the .4 comes out I could use the new parts I would think but the .3 is a proven design.
Old 12-07-2016, 06:33 AM   #2601
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
I am looking into one of these, how much do we know right now as far as what would be changed going from a .3 to a .4? Could factor that in to price of a used eb48.3 and see if its worth it or just wait for the .4
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 12-07-2016, 06:48 AM   #2602
Nothing is known at this point, besides that ackerman arm obviously changes the steering. Leads me to believe that there may be a change on spindle side. I'm sure it will have a lot of the current "option" parts in it, but I doubt we'll see universals on the 4 corners as they are more of a tuning aid.
I doubted any suspension changes to geometry, but others have said there is.
We're all in await and see approach right now.
And I'm quite positive that if there is an upgrade path, that Fiercercsolutions will have one available.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 12-07-2016, 07:33 AM   #2603
Super Moderator
Trader Rating: 17 (100%+)
What the public knows is what you see on the Tekno site for the new parts. The limited team guys can't discuss it. You know the drill. If you do your homework and look at recent race reports in the US that had tons of media attention (hint vegas), you'll find all you need to know.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-07-2016, 07:38 AM   #2604
^^^Spot on....I could actually garner some info when the .3 was about to drop....This time no one is saying anything.
That ackerman arm is the first confirmation something is coming that I've seen. I'm getting anxious to find out. Just like everyone else.
The hard part about looking back at worlds, is you don't know what was prototype, and what will make it....So regardless, it's a wait and see.
Old 12-07-2016, 08:05 AM   #2605
Judging by the pics from the worlds and other places
chassis
steering components
front spindles and uprights
A, B, C, and D plates
A-arms
diff bulkheads
rear hubs
I don't think updating from .3 to .4 will be worth it. Just wait for the .4
Old 12-07-2016, 08:49 AM   #2606
Tech Legend
Cain's Avatar
sounds good thanks everyone!
Old 12-07-2016, 08:54 AM   #2607
Super Moderator
chassis
steering components
A-arms
diff bulkheads
rear hubs
Time will tell
Old 12-07-2016, 09:15 AM   #2608
Time will tell
That it will. I'm more curious to see what, if any, updates the truggies get. I've kinda given up on making the narrow chassis buggy work on rough tracks.
Old 12-07-2016, 09:22 AM   #2609
Please leave truggies alone. I don't think I could improve on my setup if I tried.
What doesn't work for ebuggy on a rough track? I don't think there is a track that gets rougher than the one I regularly club race on. It's an old school dirt track with loam, sand, and some hard park. It changes lap to lap, let alone heat to heat. What is it doing that you don't like? Do you have a setup sheet?
Old 12-07-2016, 09:46 AM   #2610
shadaloo's Avatar
So with some .4 stuff popping up, what does everyone do with their old models? I know and sell before the new one releases, some just slowly buy the upgrade parts, etc.. I hate to sell my .3 for such a discount, but I don't see the point of holding onto a outdated kit that I would never race again, since I'd most likely only use the new kit... So what's the best option? ><
shadaloo is offline   Reply With Quote
