    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 10-24-2016, 10:33 PM   #2416
jason07's Avatar
Originally Posted by shannow View Post
From your setup sheet I'd try 24mm or less front ride height and 1 toe out front.
The camber links are already giving you quite a low front RC compared to the rear RC to a car that, as said, has tons of steer.
My two cents as some says
Edit: Something just went across my mind : what tires are you using ? Sometimes it's as simple a that.
I appreciate the advice. I'm running AKA Impacts.
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 10-24-2016, 10:35 PM   #2417
jason07's Avatar
Originally Posted by MX304 View Post
Yeah I can't get it to attach. Keeps saying file size is too big. Anyone know how to reduce the file size of a .pdf?
EDIT: Maybe this will work...
I'm trying to get a good grasp on wha the pills indicate. Your rear toe is -3.5 degrees right? You posted "0" on your setup sheet, but I figured you just left it blank and didn't actually mean "0" degrees? Am I right?
Old 10-25-2016, 07:10 AM   #2418
Trader Rating: 16 (100%+)
Front toe is 0, rear is 2.5.
MX304 is offline   Reply With Quote
Old 10-25-2016, 09:22 AM   #2419
Originally Posted by MattDub View Post
Most definitely, we have been using TKR6018 emulsion caps on the EB, NB, SCT and EB48SL with great success!
Matt,
I crash too often to risk plastic caps on a buggy. Please say an aluminum version will be available soon.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-25-2016, 09:39 AM   #2420
bigboyz12000's Avatar
I tried searching and didn't find the exact answer.
I'm struggling with off power steering (or just getting through a corner tight vs taking it wide)
I used the Joe Bornhorst setup but I have gotten so far away from that that I'm not sure what to call it.
I am using 7/7/5 in the diffs and I believe 425/ 475 in the shocks. The car just won't turn into the corner, I can't comment if its getting out of the corner well because I have to go so slow to setup for the exit.
Any help would be appreciated.
I have my 48.3 setup to factory standards except for shock oil. I am running 5 5 5 in the duffs and have no issues with tight cornering entering or exiting. I enter the corner with speed or coast and get back on throttle 1/2 way through and the rear just comes around perfectly. I am running on a loose dirt outdoor track. I would say medium to low bite at best. I am also using TLR shock oil 40wt front and rear. So far so good.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 10-25-2016, 09:51 AM   #2421
Originally Posted by ezlight View Post
Matt,
Not for some time. We have been using the plastic caps for a while and they are very durable. I personally have never broken one. Several of our team guys have been using them for years and only broken a couple.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 10-25-2016, 09:54 AM   #2422
Suspended
I have never broken a plastic cap on my NB, I was running plastic on the NB for awhile because I hated the look of the scratched up alum... But haven't had any issues with durability.
Is there much of a difference between emul and vented? I run emul on my sct and vented on my buggies, but don't know the actual differences in performance.
-Tekno SCT/EB-
deceit is offline   Reply With Quote
Old 10-25-2016, 10:00 AM   #2423
Quite a bit of difference actually. Emulsion is better on bumpy tracks and also helps reduce chassis roll, lands better too. We run emulsion on all EBs and NBs. Vented caps have a slight delay when the bladder compresses before they start producing resistance.
Matt Wolter
Old 10-25-2016, 10:57 AM   #2424
Suspended
Why isn't emulsion recommended for stock setup? When I built my SCT i went emulsion since that is what I used on my Losi SCTE, I never knew the differences between the styles though. I only went it because it's what I knew.
Thanks for clearing up the pros/cons a bit.
-Tekno SCT/EB-
Old 10-25-2016, 12:13 PM   #2425
If you look on Tekno's website they have updated setup sheets for outdoor, rough outdoor, and indoor.
Old 10-25-2016, 03:53 PM   #2426
Has anyone tried the new JC Body? I am finding the servo horn hits the body and not just a little bit
revhead145 is offline   Reply With Quote
Old 10-25-2016, 04:19 PM   #2427
Suspended
I haven't had any issues with servo horn rubbing, I use the tekno alum horn and 0 issues
-Tekno SCT/EB-
Old 10-25-2016, 09:18 PM   #2428
jason07's Avatar
I actually said that but then I edited my post.
Old 10-25-2016, 10:58 PM   #2429
I just set mine up based on the new outdoor setup. Man the bump steer is agressive. At full compression theres allot of toe out. Ill find out tomorrow night how it feels
Dragonfueled is offline   Reply With Quote
Old 10-26-2016, 04:48 AM   #2430
Jpm1's Avatar
Just double checking that in the new outdoor setup that using different pistons front to rear isn't a Typo?
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
