    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 10-03-2016, 01:23 PM   #2311
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Originally Posted by Bob Barry View Post
Don't expect a new car for a while. Even if these new parts are amazing and run perfect this week, it will take months for that to trickle down to EB. Just my 2 cents, not an official word
Parts being run at a world are something that would be well tested imo.
I dont think it will be as long as you might think.
micrors4guy is offline   Reply With Quote
Old 10-03-2016, 02:12 PM   #2312
Trader Rating: 16 (100%+)
The new a-arms look like a production part which of course requires new molds. I doubt they'd spend the $$$$$$$$$$$ required for new molds if it wasn't a for sure deal. The only thing that still looked to be prototype phase are the front c-hubs and spindles. Those are still aluminum.
MX304 is offline   Reply With Quote
Old 10-04-2016, 01:57 PM   #2313
Super Moderator
Trader Rating: 17 (100%+)
you guys aren't taking into consideration all the extra stuff that goes into producing a new kit though. Parts aside, they still have to do all the literature, cover art, setup testing to offer a base line, plus they have to produce enough inventory to actually be able to sell them. Will there be a new kit? Yes. There will ALWAYS be a new kit. That's just evolution.
I'm just saying don't put a date on it yet. And yes I know you can get the parts and slap them on, which most of us will do
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-06-2016, 11:48 AM   #2314
eXXon's Avatar
Hi guys, another newbie question, how can I fit a tall servo (Savox 1231SG) ?
Cheers.
eXXon is offline   Reply With Quote
Old 10-07-2016, 08:00 AM   #2315
Cheers.
If it's too tall, you need to choose a different servo.
There is just so much space allowed, and you don't want to go taller than designed because it would put your steering link an an inefficient angle, if it will work at all. Don't try spacers on the servo saver side, as it doesn't work out well, and will produce too much slop.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-07-2016, 04:49 PM   #2316
What's the servo of choice for the eb48.3?
RookieRacer00 is offline   Reply With Quote
Old 10-07-2016, 05:48 PM   #2317
Ive seen a lot of people run Savox (1273) and Protec 150S as well as the old trusty Hitec 7955
mlax is offline   Reply With Quote
Old 10-07-2016, 07:27 PM   #2318
Trader Rating: 19 (100%+)
Cheers.
you could try doubling up on the servo brace (part no TKR5060
) and using longer screws
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 10-07-2016, 07:56 PM   #2319
It's still going to get the steering link at a bad angle though.
Old 10-08-2016, 02:54 AM   #2320
eXXon's Avatar
Cheers, I ordered different servos that should fit.
But I had to use spacers with a standard height servo on the saver's side to fit it on top of the horn, I guess that's a fault of Savox servos, but there really isn't room for anything else but standard sized servos on these Tekno kits :
Thank you, ordered. Wish I've tried that before mangling one of the collars on a brand new servo (entirely my fault):
Wouldn't spacers solve that though ?
Old 10-08-2016, 06:54 AM   #2321
mkl
I wonder if that servo is tall above the mounting ears compared other servos. Also, using a low mount servo horn would help as well. The Tekno horns lower the link quite a bit. http://www.teknorc.com/shop/tkr5251b...p-double-hole/
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 10-08-2016, 09:51 AM   #2322
No, because when you have to stack a bunch of spacers on top of the steering arm, you introduce a ton of flex. The steering feel will be weird, it may not center correctly every time, and it will greatly increase the chance of breakage.
Old 10-08-2016, 10:14 AM   #2323
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Be interesting to see what they come out with. One thing with the shock springs the do look pretty darn close to the shock body.
what advantage are the tekno vehicles seeing by running the chub setups still versus the pivot ball that others are doing?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-08-2016, 10:12 PM   #2324
I'd really like to see what a Kysoho / HB style c-hub front suspension could do on a narrow chassis car like the Tekno. I'm not sold on the Tekno / TLR style c-hub. It's just too edgy.
Old 10-09-2016, 02:04 PM   #2325
stanson's Avatar
Official Polish National Championship - my Tekno takes 3rd place. Tough weekend, bad weather, different conditions every hour - was a lot of fun! Fought hard, missed just a few seconds for the top spot.
I had no single issue for the whole season with this buggy. Amazing car.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
