    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 08-01-2015, 09:44 AM   #151
blackshark3's Avatar
Originally Posted by MadRiderSD View Post
If any of you have driven or currently owns a mbx7eco , would pick .3?
3 weeks ago, I ran my newly built MBX7r ECO, just couple of days ago I ran my newly built 48.3. Both cars according to stock setup, and have identical electronics and tires.
Mugen: Pro: Lots of turn-in. Lots of overall steering. Glides through hair pins with ease. Chassis very balance. Very stable. More space to fit a fan/cooling fin for the motor. Can accomodate bigger ESC. The car is not so finicky on tires. Cons: More flimsy plastic materials. Wears out easily. The parts design are not as well thought out as Tekno. The original suspension setting seems very soft, the car bottoms out easily after jump, and tends to traction roll easily. After around 15 runs the lower a-arm broke without any crash.
48.3: Very stable jumps, especially landing. Car act like a suckion cup. Very well thought out parts design, basically fixed all the small hick ups of the 48.2. Very good quality plastic parts. Car sturdy like a tank. Quite sensitive and responsive to tires and setting changes. Cons: Not as much steering as the MBX, especially turn in. Getting out of the corner need a bit of wrestling, car would tell me I throttle too much too early by giving me a wriggle on its tail. I keep all the reinforcement struts, as I once bent a chassis of my .2 right after I took off the mid and rear struts. With the struts off I am sure the car would have more traction and steering, but I just won't risk a chassis to do that. The space is too cramp, I think the ESC mounting space is designed for Tekin.
My verdict: Mylaps tell me out of the box I am about half a sec faster with my Mugen. I miss my Mugen as I wrestle the .3 out of hairpins. However, the .3 shine on jumps, bring a big grin on my face.
My .02 cents
blackshark3 is offline   Reply With Quote
Old 08-01-2015, 06:01 PM   #152
the ?? is which one do you used more now the mugen or the tekno
coombes is offline   Reply With Quote
Old 08-01-2015, 10:53 PM   #153
justpoet's Avatar
Trader Rating: 16 (100%+)
My .02 cents
I've driven a few of the Mugen's. I found that they were more lazy in general, as I can't get as aggressive with them or get the turn in I want (with the setups I tried on other folks vehicles) without also making the rear break free a lot more than I want. It jumped confidently when going for a normal jump and downside, but I couldn't land it sideways without something odd happening (a bounce, a roll, a wiggle, etc). Both it and the EB48.2/3 are good cars, and both can be tuned towards your driving style, but I believe the EB48.3 has the largest range of tunability in that regard. I converted my EB48.2 to an EB48.3, so never ran the box stock setup that the 48.3 ships with. That being said, holy crap is this thing stable and BEGGING to be driven hard. Not because it needs throttle to drive ok, but because I can throw it off of any jump in any direction and it'll land it without issue, and I can go full throttle/brake and get exactly what I expect in a controllable and stable way. I find the EB48.3 to be way more forgiving than the EB48.2 or the Mugen in all regards. When I went from the EB48.2 to the EB48.3, I didn't get faster...I just stopped having big mistakes and my lap time spread became very close to my fast lap.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 08-02-2015, 09:13 AM   #154
CAR
CAR's Avatar
Anyone fine a better shock boot for this car the stock ones are like to big and get pinched between the spring and spring perch on compression. After running them for a little while it looks like someone took a knife to them.
CAR is offline   Reply With Quote
Old 08-02-2015, 11:08 AM   #155
Mizchief's Avatar
I've been happy with the new boots.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 08-02-2015, 01:46 PM   #156
Trader Rating: 33 (100%+)
i like the tlr boots the best. for me they have held up better than the updated tekno boots and also do a better job of keeping dirt out as they have a tighter seal around the shaft and cartridge caps.
RC 4 LIFE is offline   Reply With Quote
Old 08-02-2015, 02:42 PM   #157
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Take the smallest hole on your punch and put a hole way up at the top. Pount the hole to the back of the car. The air wont blow the boot up and into the spring this way.
micrors4guy is offline   Reply With Quote
Old 08-02-2015, 03:26 PM   #158
CAR
CAR's Avatar
I don't think this will help much because of the amount of cuts the are in the boots.
Old 08-02-2015, 03:54 PM   #159
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I believe he was suggesting that you try this with a new set of boots
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 08-02-2015, 04:36 PM   #160
CAR
CAR's Avatar
After the first cut in the boot it's vented right? If that were to work I shouldn't see any more cuts in the boots, some of my boots have four cuts in them.
Old 08-03-2015, 08:36 AM   #161
Anyone else having the screws from the mudguards rubbing on the body shell ?
wraithperth is offline   Reply With Quote
Old 08-03-2015, 08:55 AM   #162
I have had this on certain bodies. I am thinking about using a countersink bit on the guard and using a countersunk screw for it to fit flush.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
Old 08-03-2015, 01:57 PM   #163
jetgsr's Avatar
Default screws rubbing
I run the Leadfinger assassin body and mud guard screws have rubbing really badly to the state there is nearly a hole in the body from them and that's just after 1 local club meet. Might have to trim the body more to get the freedom and not bind. But its the only bad thing i have found on it so far.
Tekno EB48.2 : Tekin RX8 Gen2/T8 Gen2 1900
Tekno EB48.3 : Tekin RX8 Gen2-T8 Gen 2 1900
Panther Tyre's / Coast2coastrc
jetgsr is offline   Reply With Quote
Old 08-03-2015, 02:32 PM   #164
vwduud's Avatar
Trader Rating: 48 (100%+)
I just trimmed off a little lexan off that area. Problem solved. Removed lexan is not easily visible nor does it cause any problems. This is across the stock, JConcepts and LFR bodies.
Jim Brown
Agama A215E, Rx8 G3, 1900kv, Savox 2273, SMC, 4PX
Sponsors: Agama, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 08-03-2015, 04:46 PM   #165
I just purchased a used EB48.2. Can I slowly replace my existing parts to the new .3 - or does it all need to be changed at once to work?
home13oy75 is offline   Reply With Quote
