    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 04-07-2016, 04:32 PM   #1456
Originally Posted by werner sline View Post
do you bash ?
any vid of the crashes ?
I was just bashing around. It's been too cold and rainy to go to the track. I've been getting out when the rain lets up. I don't have any videos. I need to get a camera. That's one thing I don't have.
EricM is offline   Reply With Quote
Old 04-07-2016, 06:32 PM   #1457
werner sline's Avatar
oh ok, I just wanted to see some eb48.3 bashing !
werner's bunch of 1/8 RC freestyle tricks NEW video : TRUGGY tricktionary, part 2: 14 tricks
check it out : https://www.youtube.com/watch?v=5PVrXfs5TG8 6s power !
werner sline is online now   Reply With Quote
Old 04-07-2016, 06:41 PM   #1458
Trader Rating: 16 (100%+)
Watch the Psycho Nitro Blast coverage on LiveRC this weekend. Lutz always does some crazy stuff with his at that race.
MX304 is offline   Reply With Quote
Old 04-08-2016, 09:43 AM   #1459
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by ezlight View Post
Amateur tip, stop listening to pro's.....
Bob Barry is offline   Reply With Quote
Old 04-08-2016, 10:18 AM   #1460
Was there ever a Tekno guide realeased? I remember reading about it but did a full tuning guide ever get realeased?
Dragonfueled is offline   Reply With Quote
Old 04-08-2016, 10:21 AM   #1461
Negative. It's a work in progress....There is one out there, but it's not accurate to the new vehicles yet.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-08-2016, 11:00 AM   #1462
Default hex and nut drivers
im about to start my build of th eb48.3 and im unclear if i need to buy any of the nut drivers because they are listed as 1.2 11.32 etc instead of mm as they show on the tekno box.
these are the tools I have so im asking for input if i need to buy additional nut drivers.
http://www.amazon.com/Team-Associate...ef_=sr_ph&sr=1
http://www.amazon.com/Black-Decker-7..._7&s=hi&sr=1-7
second part of that is if i buy the tekno nut drivers should i just get one handle and the bits seperately? it doesnt look like theres a set. Im laos guessing i need the wheel and shock wrench no matter what in addition to the tekno shock tool.
thanks in advance guys!
caffeine357 is offline   Reply With Quote
Old 04-08-2016, 11:18 AM   #1463
Skip the AE drivers, get MIP below:
http://www.ebay.com/itm/MIP-9502-Met...cAAOSwyjBW6jsm
Skip the black and decker...You need actual metric...Like these.
http://www.amazon.com/Pack-Essential...+driver+metric
Something needed for the build, and helpful for the toolbox is a 4mm reamer for the arms.
http://www.ebay.com/itm/Hudy-4Mm-Rea...AAAOSw--1Ws6RY
As for the tekno shock tool, it's one of my favorite tools, period... SOO helpful.
http://fiercercsolutions.com/TKR1115...um-TKR1115.htm
That combined with this will make shock building easy.
http://fiercercsolutions.com/TKR1116...ol-TKR1116.htm
Old 04-08-2016, 11:48 AM   #1464
justpoet's Avatar
If you already have those, the Associated hex driver there will work fine. I personally didn't care for the quality of the tips, but there are certainly worse ones on the market. You'll use the metric sizes on it, which are the 1.5mm, 2.0mm, and 2.5mm. Note that the 2.0mm size is not listed, but is actually there, as it doubles with one of the imperial sizes that they do list.
As for the nut drivers, it looks like those are all also imperial (aka "standard" and done in fractions of an inch). Those will NOT be the correct sizes.
You will need 5mm for the shock piston nut, 5.5mm for a few other nuts, and 7mm for some nuts. I don't believe the 8mm is needed for anything other than the short course wheel nuts.
You CAN get just 1 handle from Tekno and the tips you need, but if you want to use 2 at the same time, such as many often do for putting the shocks onto the towers, then you'll want at least 2 handles. Since you only need 3 of the 4 nut drivers, and it is cheaper to get the handle and driver tip together than apart, I'd just pick up the nut drivers as a whole tool, and then you'll be good to go.
As for the shock wrench multi-tool...it is my favorite tool, so I highly highly recommend it!
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-08-2016, 11:52 AM   #1465
justpoet's Avatar
Originally Posted by MX304 View Post
https://youtu.be/GT2AdfBfM6M?t=2m49s It works very well, and doesn't seem to weaken the arms much. I have not broken one after cutting them.
Thanks for linking one of my videos. Glad it helped you out!
I expect to get another short one up for this coming tuesday.
Old 04-08-2016, 02:51 PM   #1466
thanks for the tip
https://www.youtube.com/watch?v=kjk3...&nohtml5=False
I didn't find much except this tekno jumping high @ 2.39
Old 04-08-2016, 08:29 PM   #1467
RC Matt's Avatar
I had my first race this night and unfourunately I have to say I am a little upset with the buggy. Before I bent a shock shaft from practicing and now I just blew a bearing on my first race (both with the buggy and for myself). I'm not bad at driving either because I was too good for the novice class according to the people I was racing. The bearing I blew was the one that goes on the inside of the rear hub. It was an unfortunate and unexpected experience but hopefully I will be able to race the whole thing next time. At the beginning this buggy was doing very well in my opinion and when it did crash it was my fault not the buggy's. I guess I have bad luck or something with this buggy because it seems like I'm part of the few people that break this buggy.
RC Matt is offline   Reply With Quote
Old 04-09-2016, 09:26 AM   #1468
Cuebulon's Avatar
Well I just got mine built and all the electronics are dialed in. One thing I noticed:
When holding it in the air, and hitting the throttle I noticed the wheels don't spin as long as i feel it should. Compared to my sct410 or my 8.2e. I've checked all the shafts and diffs for binding but nothing seemed bound. Is this normal?
Cuebulon is offline   Reply With Quote
Old 04-09-2016, 09:46 AM   #1469
mkl
it could have to do with your ESC settings. The motor will act like a brake and not allow your wheels to spin. You could take off the pinion and spin the wheels by hand to feel for any binding.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 04-09-2016, 09:57 AM   #1470
Cuebulon's Avatar
I did and it feels great. I checked to see if the drag brag got turned back on somehow as well and nothings there. I did however replace the motors bearings before putting it on the kit. Could that have anything to do with it? I put the motor back together exact opposite of how i took it apart so it should be fine there.
