    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 07-28-2015, 05:58 AM   #121
I'm having issues with my centre diff seems it's binding in 2 spots when I bolt down the top plate it runs free if the top plate is off. Any ideas guys ? This is the 3rd Tekno I have buit in 2 weeks having built an sct and superlight as well but no issues with centre diff with those builds ....
wraithperth is offline   Reply With Quote
Old 07-28-2015, 06:01 AM   #122
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Are all of your center diff bolts tight? is there a chance that it is hitting on he mount?
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 07-28-2015, 06:10 AM   #123
Trader Rating: 16 (100%+)
Originally Posted by MadRiderSD View Post
If any of you have driven or currently owns a mbx7eco , would pick .3?
All day long. I had the mbx7 and the .3 is a better car all the way. Drives better, fewer parts, easier to work on, more durable.
MX304 is offline   Reply With Quote
Old 07-28-2015, 06:15 AM   #124
Yeah I have checked that and it's fine maybe a dodgy spur gear have a spare so might try that just wondering if anyone else has noticed it during their build also . Could also be the top plate ...
Old 07-28-2015, 06:33 AM   #125
Definatly check the top plate. Also look over on the sct410.3 as i think someone posted a solution there as well.
Old 07-28-2015, 07:08 AM   #126
Originally Posted by 8ight-e View Post
Quick question has the driveshaft issue been corrected with all current .3 kits? Ive seen a lot of issues w/ these even with the part lots not just .2 and even et48 kits
We have worked very hard with manufacturing to fix the issue as well as with our customers to replace defective drive shafts. Anyone with bent drive shafts in the kits is welcome to contact our customer service info@teknorc.com to request a replacement.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 07-28-2015, 07:33 AM   #127
Your spur gear isn't tightened down evenly and the resulting warp in the gear is making it rub. Back out all four screws and make sure you get them evenly torqued and not over tightened.
Old 07-28-2015, 02:53 PM   #128
CAR
CAR's Avatar
Anyone know what the 15 degree caster blocks (version 2 ) are all about? Thanks
CAR is offline   Reply With Quote
Old 07-28-2015, 03:28 PM   #129
8ight-e's Avatar
Trader Rating: 57 (100%+)
Thanks for the reply,,, I have a eb48.2, et48 even the nt48 lol.. I'll be updating at some point just working on a timeline to do so, no hurry so I was going to verify if the updated parts were in the current shipping kits or if I should hold off. Nice job though making sure any issue parts are taken care of, I've heard a lot of positive things about the support. Lot of success w/ my tekno vehicles over the last two years
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 07-28-2015, 04:46 PM   #130
They are a trailing hub design. In other words the axle is shifted slightly behind the vertical pivot line.
Old 07-28-2015, 09:57 PM   #131
Spur gear is fine not over tightened and screwed down evenly. After trying a few things I rubbed chalk all over the spur to see where it was binding I noticed the cnc motor mount was what was rubbing on the spur so got the verniers out and measured the gap between the motor mount to check if it was square and one side was smaller where it was rubbing so loosened off the motor mount screws put pressure on it with my hand to keep it forward and then screwed it back down now the it doesn't rub. So the tolerances must be super tight as the motor mount only moved a fraction back but was enough to make it bind. Oh well at least I got it sorted was frustrating as I had built 2 centre diff previously and they were fine.
Old 07-29-2015, 05:57 AM   #132
Yes, the currently shipping kits have all updated parts.
Matt Wolter
Old 07-29-2015, 10:24 AM   #133
Carter Flotron's Avatar
Its simply to distinguish between the .3 kits trailing steering block design, versus the .2's inline design. The .2 parts DO fit the .3, for those looking for more steering response.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 07-29-2015, 02:21 PM   #134
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Just to be sure to use the spindles and blocks as a set. The trailing spindles require the trailing blocks and the standard spindles need the standard blocks, they can't be combined.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 07-29-2015, 03:31 PM   #135
Has anyone got any video off this buggy in action
BlackWindow is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
