    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 03-03-2016, 04:03 PM   #1276
RC Matt's Avatar
Originally Posted by qstorm777 View Post
I use the manual to get part numbers and search in amain, etc. by part number. Don't trust what's on the website as far as deciding what fits.
Yeah well I have to learn the hard way I guess.
Tekno EB48.3
Tekin RX8 Gen 2
Tekin T8 2050kv Gen 2
RC Matt is offline   Reply With Quote
Old 03-04-2016, 09:16 AM   #1277
snwchris's Avatar
Yea I always check the Manual P/N versus the website to make sure its right. There's been times they had the wrong description or off by a number. When its a parts warehouse that big carrying that many parts sometimes you have to double check.
I'm curious though if you have the .3 buggy and sounds like a new build, how come already ordering shock shafts??
snwchris is offline   Reply With Quote
Old 03-04-2016, 04:03 PM   #1278
RC Matt's Avatar
I was running it in my backyard track and then when I took it in the rear shock was not smooth so I took it apart. Then after I took it apart I realized that my shock shaft was bent. I have only about >6 hours of run time on it too.
Tekno EB48.3
Tekin RX8 Gen 2
Old 03-06-2016, 03:00 PM   #1279
Trader Rating: 16 (100%+)
The rear shock shafts seem to be an issue. I have bent several on my .3. Never bent one on my .2.
MX304 is offline   Reply With Quote
Old 03-07-2016, 06:36 AM   #1280
RC Matt's Avatar
Have any of you guys bent a rear shock shaft besides me and MX304?
Tekno EB48.3
Tekin RX8 Gen 2
Old 03-07-2016, 06:51 AM   #1281
rcjunky10's Avatar
Trader Rating: 217 (100%+)
So far so good after (4) practice sessions, for both myself and my (7) yr old first time racer, and a full race day. Though I will say this new platform is so stable/predictable that I require very little marshaling. I haven't experienced many bad spills is what I'm getting at.
Nothing but smiley faces and thumbs up from this guy!
rcjunky10 is offline   Reply With Quote
Old 03-07-2016, 07:30 AM   #1282
Super Moderator
Trader Rating: 17 (100%+)
yeah that's how I was. Every time I came off the driver stand I had a big smile on my face. Was flat out awesome.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-07-2016, 08:25 AM   #1283
rcjunky10's Avatar
Having been away for the better part of (2) years - what a welcoming platform to come back to. Car made me look like I hadn't missed (too) many steps. But really the most enjoyment I've had is watching my little man wheel his, especially when he links a few nice sections together. RC at its purest!
I built his, a fully converted .2 with the Bornhorst setup, while putting the box stock on my freshly built .3. Truth be told I haven't run his yet, gotta let him break her in, but the box setup isn't bad. At a race this past weekend the car was great in the infield but wanted to traction roll in some of the high speed sweepers. No worries, a slight move of the rear shock location on the tower and she settled down while still maintaining speed in those pesky sections.
What's most amazing is how WELL this car rotates. Blip the throttle and the back end makes itself around in a controlled fashion and tucks in nicely as you accelerate out of the turn. I'll try the Bornhorst setup this week now that I've a dozen or so packs through the stock setup (upgrades include Delrin shock inserts, TiNi shock shafts).
Looking forward to the next outing....cheers boys and good racing to you all!
Old 03-07-2016, 08:32 AM   #1284
Same here... well, i only bent one, but it happened relatively quickly. I have some spares now. Never bent one on my SCT410.3... I think the longer shock shafts must be part of the issue.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 03-08-2016, 01:52 PM   #1285
What's everyone liking for shock setups these days?
turtle189 is offline   Reply With Quote
Old 03-08-2016, 03:16 PM   #1286
How do you have the shocks angled? I just realized I didn't start bending them until I leaned them in on the tower to the next to inner most hole. I'm thinking that between the angle, potential for binding, and the high shock shaft speeds that it could be part of the problem.
Old 03-08-2016, 03:24 PM   #1287
I have only bent one shock shaft and it was only because I under shot the jump....It all depends how the impact is ...the position of the shock isn't going to save the shock from potential damage. Tune for performance 👍🏻
I'd recommend the derlin insert and tini shafts for better performance and better durability 👌🏻👌🏻
CJH 22 is offline   Reply With Quote
Old 03-08-2016, 04:11 PM   #1288
Default Battery Question
Hi all im speccing out my first ebuggy and trying to decide between these batteries and thats the only difference i see. Does that make a difference and or is there any battery you guys recommend over the other or are they very comparable. Ill be running this with a trackstar 2100kv motor / esc and a protek 130 servo
protek-rc-4s-supreme-power-lipo-100c-hard-case-battery-pack-14.8v-3250mah-
reedy-wolfpack-gen2-4s-hard-case-lipo-battery-pack-35c-14.8v-4000mah
caffeine357 is offline   Reply With Quote
Old 03-08-2016, 04:37 PM   #1289
I have the delrin parts, and I was tuning for performance. It just seems weird that I went from not bending any, to now bending 3 in two trips to the track after changing my setup. No big crashes or anything
Old 03-08-2016, 09:34 PM   #1290
I would personally recommend smc...best bang for your buck and power is great and affordable. I believe smc 3600 is $40 and a 4500 is a tad more ... Great products
