Tekno RC EB48.3 Thread >
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 01-08-2016, 10:32 PM
  #1051
Default Ride Height
Anybody running with 26mm ride height? If so, what kind of track and what size are the jumps? I'm thinking about going 26f/27r on my ride height.
qstorm777 is offline
Old 01-08-2016, 10:52 PM
  #1052
R1Joel's Avatar
I went 26mm/26mm. Track is big and loose but not bumpy, with one big jump and several medium sized. Haven't had a good go with it, but tomorrow is my first race so I will have a play and see how I go. I had a practice battery last week and didn't like the 27mm/29mm at all for a loose surface. I am thinking 26mm/27mm might be a go.
I'll report back after tomorrow. Hopefully I don't regret my decision to get this buggy.
R1Joel is offline
Old 01-09-2016, 03:28 AM
  #1053
RC Matt's Avatar
Originally Posted by qstorm777
I don't quite understand the question. Any pics?
http://www.rctech.net/forum/r-c-item...f-s-artr.htmlS please take a look at the servo and could you guys tell me if its a good buy or not because I'm about to pay for it soon, thanks.
RC Matt is offline
Old 01-09-2016, 05:52 AM
  #1054
It says page not found.....is it on eBay?
CJH 22 is offline
Old 01-09-2016, 07:08 AM
  #1055
RC Matt's Avatar
It's not on eBay but it was working when I put it on but I'll upload a picture when I get on my computer.
RC Matt is offline
Old 01-09-2016, 07:30 AM
  #1056
RC Matt's Avatar
This is the picture of the buggy. I would like to know if it is a good buy or not and will the servo effect anything because he sent me a video of it working just fine but in the long run will it effect anything.
RC Matt is offline
Old 01-09-2016, 07:50 AM
  #1057
Trader Rating: 33 (100%+)
Picture is too small to see, but the servo should be installed with the spine on the inside of the vehicle. Page 20 of the EB48.3 manual shows the install.
http://www.teknorc.com/tekno5/wp-con...structions.pdf
I however am not understanding the real concern question here. Are you concerned about fixing it yourself? Wrenching on your RC should be something you become comfortable with, so this should be something you tackle if it's done wrong. The only other thing I can think of, if the individual has it installed in the wrong direction, that makes you wonder what else they've done wrong or how good the build of the vehicle is.
RokleM is offline
Old 01-09-2016, 07:54 AM
  #1058
And I found the link, and yes it absolutely is in the wrong direction. Looks like it's brand new, but I would definitely give it a good check before running it to make sure everything else is built right, including the diffs.
http://www.rctech.net/forum/r-c-item...-f-s-artr.html
RokleM is offline
Old 01-09-2016, 08:13 AM
  #1059
The servo does need to be turned around, but if it works, no big deal. Car looks good. Lots of tires and I think pics shows a cpl of clear bodies. I would personally like to see the chassis, but car looks like new so I'm betting all is good there. Is the 2000kv motor the truggy motor or a typo? Just wondering - some people use the truggy motor. All-in-all, it looks good.
Old 01-09-2016, 08:28 AM
  #1060
What are the major problems that need to be addressed with this car right away . Looking at buying one and just wondering how durable they are . Thanks
Speedfactory is offline
Old 01-09-2016, 08:39 AM
  #1061
RC Matt's Avatar
Does the price seem fair to you guys
RC Matt is offline
Old 01-09-2016, 08:48 AM
  #1062
Is he saying it's never been run? I think for everything he is offering, it's a good price, especially if he hasn't run it and he did a good job of building the kit.
Old 01-09-2016, 09:01 AM
  #1063
Not really, that's going to put unnecessary strain on the system.
RokleM is offline
Old 01-09-2016, 09:15 AM
  #1064
RC Matt's Avatar
So you are saying that the servo should be turned around and it will perform better steering wise
RC Matt is offline
Old 01-09-2016, 09:29 AM
  #1065
The servo should be installed as it's detailed in the instructions yes.
RokleM is offline
