    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 01-04-2016, 12:53 PM   #1006
Originally Posted by justpoet View Post
You should adjust to a setup sheet after the build. I believe there is one for the box stock setup at the back of the manual. The measurements during the build process are for ease of build and for a general guideline where things will hold together and be able to be adjusted from.
If you're steering is working different one way vs the other then you should make sure everything is on in the correct directions and especially that the ball ends aren't flipped on one side vs the other. It should go the same amount both directions. I'm assuming no servo issue/etc since this is during the build.
Thanks Poet.....Yes the steering works fine..just. Was just puzzled as to why they would use those values. Can't wait to finish this build!!!
Tekno SC 410
Tekno EB48.3
Airtronics MT-4
Iwata HP-CS
http://s1006.photobucket.com/user/JJ_Spray/library/Airbrush%20Paints?sort=3&page=1
WoodyRacer is offline   Reply With Quote
Old 01-04-2016, 03:51 PM   #1007
dbizzle5's Avatar
Loving my EB48.3 here in the UK!
Official Tekno RC EB48.3 Thread-12243432_916771185066234_603267983334591687_n.jpg
Tekno RC - www.rprcdistribution.com
dbizzle5 is offline   Reply With Quote
Old 01-04-2016, 04:04 PM   #1008
I ran the crap out of mine all year on rough outdoor track. At a few points I was running 8 packs two days in a row each day.
I broke an Ackerman plate and wore out a rear pinion bearing. That's it! All year , hundreds of crashes and cartwheels. Tekno did a great job. I have reputation for running for hours on end and going home dirty but still running.
Only bad thing is my teknos ruined my thoughts about my other trucks that I thought were reliable. They aren't
Dragonfueled is offline   Reply With Quote
Old 01-04-2016, 05:35 PM   #1009
Do some parts interchange between the new Tekno buggy and the new Shortcourse truck?
Ballistic2 is offline   Reply With Quote
Old 01-04-2016, 06:01 PM   #1010
Yeah. If I had to guess, I would say almost 30%, but not sure about that.
Diffs except outdrives
Diff cases
SCT rear shocks and buggy front shocks
All internal shock parts are the same
Springs
Sway bars
Just to list a few
qstorm777 is offline   Reply With Quote
Old 01-04-2016, 06:07 PM   #1011
Ok thanks, that's what I was needing to know. Have the truck now.
Old 01-04-2016, 06:22 PM   #1012
R1Joel's Avatar
Sweet paint! Looks good.
R1Joel is offline   Reply With Quote
Old 01-04-2016, 07:23 PM   #1013
Which body is that. I like it!
JASF4I is offline   Reply With Quote
Old 01-04-2016, 07:39 PM   #1014
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
LFR assassin
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 01-04-2016, 08:35 PM   #1015
R1Joel's Avatar
Awesome body. I had to trim the rear though as it was hitting on the mud guard screws.
Old 01-05-2016, 03:33 AM   #1016
Me too. Had to do this with stock, lfr and jconcepts body.
Old 01-05-2016, 07:44 AM   #1017
I have an EB48.2 and want to slowly build it up to a 48.3. I thought I saw somewhere a list of parts that you can do without needing others from the .3. Anyone have this off the top of their head? Just want to upgrade it slowly over 2 or 3 parts orders.
Calde315 is offline   Reply With Quote
Old 01-05-2016, 08:29 AM   #1018
vwduud's Avatar
Trader Rating: 46 (100%+)
http://fiercercsolutions.com/Tekno-E...kit-FRC010.htm
Jim Brown
Agama A215E, Rx8 G3, 1900kv, Savox 2273, SMC, 4PX
Sponsors: Agama, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 01-05-2016, 08:55 AM   #1019
Originally Posted by vwduud View Post
I've seen that was just going to piece it together slowly, for nothing better to do this winter and haven't driven it on a track yet (bought used). Figured why not build it up over winter to .3 specs.
I could buy that kit, but what I'm asking is can I get say the new arms and install those by themselves without any of the other add ons, and then keeping adding on piecemeal?
Old 01-05-2016, 08:57 AM   #1020
wittyname's Avatar
The arms , towers , and shocks all work together and should be changed at once. I just used the kit in the link from fierce and it was a good buy. Add the trailing spindles and hubs if you want them . The .3 suspension blocks when your ready for them . The car is really different now. I have to give props to Pete at fierce , when I ordered , I did not add the new size bearings to my order and he promptly emailed me and made sure I didn't miss something . That's how you earn somebodies business right there !!
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
