    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 12-11-2015, 05:39 AM   #886
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by qstorm777 View Post
Normally, when you set the droop, the screw won't run. What some are doing and I did on this last build is turn the screw upside down so the nut and threads are on top. If you have extra washers, you could also add more washers up top.
This or a shorter screw if you have one. As mentioned it doesn't normally rub much if at all when running, but if there are concerns just invert (that's what I do currently).
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 12-11-2015, 06:21 AM   #887
wittyname's Avatar
Originally Posted by R1Joel View Post
Ran into a little problem today while building. When I push the front arms down (Shocks not built yet) the screw the holds the rod end on hits the arms. What can I do? Or what did I do wrong?
As the others have mentioned , when you get your shocks built and set the droop this will go away. My eb48.2 , my nb48, and the new 48.3 stuff all did this , it really is a non issue once the set up is on the car.
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 12-11-2015, 01:28 PM   #888
R1Joel's Avatar
Great. Thanks guys. I'll leave it as is for now. If it's a problem when the car is done I'll invert the screw.
R1Joel is offline   Reply With Quote
Old 12-11-2015, 01:48 PM   #889
werner sline's Avatar
I would shorten the screw, because just like you, this would bother me !
werner sline is offline   Reply With Quote
Old 12-11-2015, 07:52 PM   #890
R1Joel's Avatar
Ended up grinding the bottom of the screw off. I put it upside down aswell but a local with experience said he tried it upside down also and it kept coming loose even with Loctite. All sorted now though.
Old 12-11-2015, 10:31 PM   #891
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I like to run the lower shock mount screws (black normal threaded ones) upside down there. You can't fit any washers with it but the hex head keys in so you only need one 5.5mm wrench to remove the nut on top. Flipping the ball ends plus the 4 washers on the ackermann plate usually gives me all the bumpsteer adjustment I need.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-11-2015, 10:40 PM   #892
so I would finally change the screw for a round head one (2.5mm hex ) , I would put it upside down , I would get rid of the 3 washers and would put a nut ( nylstop ) on top of all that !
Old 12-11-2015, 11:54 PM   #893
R1Joel's Avatar
Thanks for the info guys. I'll see how it goes with the standard setup.
I have another question. What rebound does everyone run with standard built shocks? Or is it better just to build them in the vent setup? I've only ever built standard so I a bit apprehensive of the vent style.
Old 12-12-2015, 12:25 AM   #894
justpoet's Avatar
Trader Rating: 16 (100%+)
There are 3 styles of shock builds that are easily possible with the composite shock caps. Standard, Vented, and Emulsion. With the Aluminum caps, there are 2 options, Standard and Vented.
Emulsion builds use the bleeder screw, and are different shock builds than the others. Standard and Vented on the other hand are built exactly the same way, and rebound is set exactly the same way when building. The only difference is that a vented shock won't build up air pressure to make rebound faster like a standard shock build, since the cap itself is vented. I generally build with about 25% rebound.
I've personally preferred vented on almost all track conditions with all of my Tekno vehicles, but I often run stiffer springs than many as well, which can give me some of that faster rebound back as compared to others with softer springs.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 12-12-2015, 12:53 AM   #895
R1Joel's Avatar
Thanks for your reply. I might try vented. I'm reading the manual and I can't really see the difference during the build between vented and standard. Do I build them exactly the same except the 15mm of shaft showing?
Also, got my practice body finished today. Have a Leadfinger Assassin on it's way from being professionally airbrushed.
Old 12-12-2015, 05:08 AM   #896
stanson's Avatar
Almost done
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 12-12-2015, 07:59 PM   #897
justpoet's Avatar
They build exactly the same. The only difference between standard and vented is if the shock cap has a hole in it to vent air out of the bladder area (vented), or if it is sealed to build up air pressure in the bladder area (standard).
Old 12-13-2015, 01:48 PM   #898
R1Joel's Avatar
Thanks for the explanation. So I have to put a hole in the shock cap or it comes standard with the hole in it?
Old 12-13-2015, 06:10 PM   #899
rcgod's Avatar
Trader Rating: 27 (100%+)
They come with a hole in them.
rcgod is offline   Reply With Quote
Old 12-13-2015, 07:03 PM   #900
jason07's Avatar
I didn't understand the explanation either. I did vented on mine
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
