    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 12-04-2015, 03:22 PM   #841
Super Moderator
Originally Posted by wittyname View Post
When off is facing the front of the car , a hard hit can turn the car off at a bad time.... I have had it happen , I have seen it happen , It does happen. especially as a switch wears some.
+1 Maybe sideways, but don't have off to the front or down either. The directions the majority of hard hits occur.
Dave H is offline   Reply With Quote
Old 12-04-2015, 05:03 PM   #842
Default ESC switch mounting
I used a piece of aluminum angle to make a mount for the switch. One for the 410 and one for the 48.
Official Tekno RC EB48.3 Thread-img_1398.jpg   Official Tekno RC EB48.3 Thread-img_1399.jpg
jjl1 is offline   Reply With Quote
Old 12-04-2015, 05:58 PM   #843
jason07's Avatar
Originally Posted by qstorm777 View Post
Thats normal. I believe its a 4 to 1 ratio.
Thanks man!!
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 12-04-2015, 06:46 PM   #844
Thats cool. Maybe thats an idea for Tekno to include a spot like that similar to what the do for nitros.
qstorm777 is offline   Reply With Quote
Old 12-05-2015, 08:42 AM   #845
Yeah it would be nice if they would include a switch mount in the kit. I promise I wouldn't sue them
Old 12-05-2015, 08:58 AM   #846
And allow for duel 2s bat like durango...lol.
Old 12-05-2015, 09:33 AM   #847
I allways cut my switches off and solder the wires together. Less crap laying around lol.
Dragonfueled is offline   Reply With Quote
Old 12-05-2015, 05:43 PM   #848
Not having a switch makes it a little harder to calibrate the ESC though
Old 12-05-2015, 07:47 PM   #849
mkl
How so? What ESC? Ive never needed one on an RX8. Maybe I'm missing something?
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 12-05-2015, 08:09 PM   #850
it is not an issue with the RX8 because the calibration proceedure starts with the nuetral throttle. My Castle starts with ful throttle so I would have to hold full throttle while plugging in the ESC (turning it on). I not sure about other makes.
Old 12-05-2015, 08:53 PM   #851
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I'm pretty sure you can plug it in and then grab full throttle, but you have to do it quickly, before the beeps finish I think. Try it with someone holding your car off the ground to be safe .
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-07-2015, 12:15 AM   #852
Default Transponder
Anybody try to place transponder here? Behind ESC on the plastic mudguard floor?
SCT410.3, NT48.3, NB48.4, EB48.4, Xray T4 2014
Old 12-07-2015, 12:20 AM   #853
R1Joel's Avatar
I've managed to do it a couple of times by myself with a Castle. If you can't just get someone to help.
R1Joel is offline   Reply With Quote
Old 12-07-2015, 02:16 AM   #854
Mav-07's Avatar
Trader Rating: 43 (100%+)
Originally Posted by R1Joel View Post
Ordered mine yesterday. Can't wait to get it. Hopefully have it ready for next season.
Welcome to the team my friend :-)
Mav-07 is offline   Reply With Quote
Old 12-07-2015, 06:12 AM   #855
wittyname's Avatar
Been here before ... I used to lean the radio trigger against my wing while I plugged the batt in . Pick it up in time to do reverse .
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
