    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 07-14-2015, 06:34 PM   #61
Originally Posted by MX304 View Post
Got mine about half way done. I like some of the new touches like the left hand thread shock bolts and the set screws to capture the front hub pivot bolts to keep them from backing out. Looking forward to testing it back to back with my current .2 this weekend.
Almost got the .2 to get going. Glad I'm waiting. Really excited to hear your results.
Riflebuilder is offline   Reply With Quote
Old 07-16-2015, 02:45 AM   #62
Box stock setup with a few tweaks,The car is amazing to drive and jumps incredibleably.
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 07-16-2015, 07:49 AM   #63
Trader Rating: 16 (100%+)
Are the shock pistons supposed to be taper side up, or taper side down? I didn't see any mention of that in the manual.
MX304 is offline   Reply With Quote
Old 07-16-2015, 12:01 PM   #64
Trader Rating: 20 (100%+)
Down
NoobRacer is offline   Reply With Quote
Old 07-16-2015, 12:17 PM   #65
Taper down =Less pack
Taper up=More pack
Old 07-16-2015, 12:31 PM   #66
Taper up=More pack
Thanks!
Old 07-16-2015, 12:57 PM   #67
snwchris's Avatar
Originally Posted by Matthew_Armeni View Post
They are CNC machined with a slight taper on one side. We're referring to the new pistons as "tapered" and our original style as "conical". We've found that for the buggies running our tapered pistons upside down, /_____\ has worked best whereas the truggies like our conical pistons rightside up, \_____/.
This was over on the EB48 thread, just a couple pages back from last post.... Post #14876
snwchris is offline   Reply With Quote
Old 07-16-2015, 03:52 PM   #68
Lutz' EB48.3 setup sheet from the ROAR e-nats.
http://lutzinator.com/wp-content/plu...%207-12-15.png
Old 07-16-2015, 05:15 PM   #69
werner sline's Avatar
lutz eb48.3
looks good
werner sline is offline   Reply With Quote
Old 07-16-2015, 05:21 PM   #70
Mizchief's Avatar
Originally Posted by Riflebuilder View Post
Checked out SMC batteries. Price is half the Protek at Amain. The only problem is what connectors should I be running?? My 410.3 runs 4mm bullets and I would like to standardize them. From what I understand the SCT needs the best connectors as possible because of the amp draw while the 1/8 ebuggies can get by with less?? Any thoughts?
I was having issues with deans coming apart so I switched to EC5's. The def won't come loose but are kind of a pain to unplug. Also need to solder them clean so they will seat well and can't reuse them.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 07-16-2015, 11:04 PM   #71
Carter Flotron's Avatar
Definitely start with them taper up. Gives better bump handling and an around less twitchy feel.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 07-18-2015, 07:23 PM   #72
spdrac430's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to spdrac430 Send a message via Yahoo to spdrac430
Taper down better feel and handling jumps and rough conditions
Tekno, Kyosho, SMC-racing.com, AKA, Avidrc.com, Futaba
Trick Graphics
Heart of a Hustler Racing Team
spdrac430 is offline   Reply With Quote
Old 07-18-2015, 07:26 PM   #73
Send a message via AIM to munrath
The taper is supposed to be up based on our finding. It's a tuning option for sure.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 07-18-2015, 07:59 PM   #74
so how does every one like the new buggy is it much better then the old
coombes is offline   Reply With Quote
Old 07-19-2015, 04:07 PM   #75
Loved my SCT410.3 build so much I just ordered my EB48.3 to replace a FT RC8.2e I've hated since the day I bought it. Can't wait to get it all together! Big thanks to all the guys at Tekno designing these fantastic kits.
HoldDaMayo is offline   Reply With Quote
