    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-29-2015, 03:39 PM   #571
R1Joel's Avatar
Originally Posted by Dont Hack Me View Post
Ive seen a lot of the old 150a in Tekno. Starting to see the new xr8 150a in them as well. They do fit...
Originally Posted by Carter Flotron View Post
It's very easy to get both the new XR8 and 150A to fit just got to have a short sensor wire
That sounds good. Thanks guys.
R1Joel is offline   Reply With Quote
Old 10-29-2015, 06:55 PM   #572
Carter Flotron's Avatar
If you need detailed pictures or instructions of the best way to install these just pm me I've put about 6 of these in a Tekno chassis at some point and know how to route everything now. The XR8 is far easier to fit though because of where the wires exit the case.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 10-29-2015, 08:21 PM   #573
Not so much not enough steering. More like to much push. If I'm not on power swinging the rear around it's just a real wide turn. But I'm working on it lol. Just got universals and hoping it lets the front dig in more on a turn.
Dragonfueled is offline   Reply With Quote
Old 10-29-2015, 08:24 PM   #574
wrightcs77's Avatar
Trader Rating: 521 (100%+)
Shorten the front link. Inside on hubs, outside middle on tower.
wrightcs77 is offline   Reply With Quote
Old 10-29-2015, 08:43 PM   #575
I tried that. To me honestly it feels like it bites in harder with a longer link. The short link felt like it pushed more.
Old 10-29-2015, 08:45 PM   #576
R1Joel's Avatar
When the time comes I will. Thanks alot.
Old 10-30-2015, 04:17 AM   #577
shannow's Avatar
That's what I would have thought as well.
Longer front link will make the roll center lower as the car leans in the turn which will make the front dig more than the rear and therefore transfer weight to the front of the car.
The reverse is true for the rear. A shorter rear will also make the front dig more.
It only then depends if you you rather prefer a responsive car in mid corner (shorter rear) of a bit smoother mid corner responsiveness (longer front). All of which shouldn't alter how the car behaves in entry and exit corner.
shannow is offline   Reply With Quote
Old 10-31-2015, 06:01 AM   #578
I just bought this kit. I'm a news to rc Buggys. What kind of grease should I use when I build it? Will any kind work? (I have a tri flow grease that I use for my helis. I'm not sure if that will work though.)Also what size battery would be good? I'm still trying to decide on the motor and esc right now. I'm also trying to decide on a radio system too.
EricM is offline   Reply With Quote
Old 10-31-2015, 06:11 AM   #579
stanson's Avatar
I'm interested in this kit but I am increasingly worried about having fitment issues with my Hobbywing Xerun 150a.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 10-31-2015, 08:50 AM   #580
wrightcs77's Avatar
Originally Posted by teknorc View Post
Shortening the front link makes the car more stable. Sweepers, off-power, on power, etc. It will land better as well. We have been moving to a shorter front link lately and the results have been great.
Theoretically it gives you less initial steering but more on power steering. What we have found is less twitch and the rear follows the front better around and out of corners.
Start with the front link short (shortest on hub, shortest on tower, middle on tower). Tune the steering with the rear end:
thicker sway bar (more steering everywhere)
more rear toe (more entry steering)
less rear toe (more stability entering, but more steering out of the corner)
This is direct from Tekno. I have tried it and find out to be very accurate for our tracks..... Low to mid bite, outdoor.
Old 10-31-2015, 08:53 AM   #581
rcgod's Avatar
Trader Rating: 27 (100%+)
You get a small tube of grease in the kit. Any tacky grease will work fine. I've used everything from associated black grease to mobile 1 synthetic and they work fine.
Most guys run around a 5000 4s pack. That will get you 10 to 15 minutes run time which is more than enough for racing.
Motor and esc depend on your budget. Hobbywing sct pro and smc 1900 motor work great and you can get both for about $150. Or tekin rx8 gen2/1900 combo is around $300. There are other options like lrp but those are the most popular. The new hobbywing xr8 plus is getting popular but the price is close to an rx8. That paired with an smc motor would be about $230 which is in the middle price wise.
When recommending a radio I always tell people to buy what fits their hand the best. Some radios are bigger than others so get what feels good to you. Airtronics, Futaba and Spektrum are most popular. Any of their radios that aren't entry level will have more than enough features. I personally run the Airtronics MT4 and love it, but have ran Futaba, Spektrum and KO with no complaints.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-31-2015, 08:56 AM   #582
justpoet's Avatar
Trader Rating: 16 (100%+)
The kit will come with a black grease that works quite well for the kit. It will also have shock oil and diff oil in the kit along with some thread lock. The included oils are great, but you may want some others for the purposes of tuning to your driving style and local track.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 10-31-2015, 10:09 AM   #583
Thanks for the replies. I'm supposed to get the kit next week.
Old 10-31-2015, 11:36 AM   #584
Is there a battery manufacturer that you could recommend? Like reedy glacier, etc. What discharge like 30c or 45c?
Old 10-31-2015, 11:49 AM   #585
SMC are pretty good. I've also had good luck with my Reedy and Eco power batteries.
SpongeX is offline   Reply With Quote
