    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-26-2015, 01:24 PM   #556
Maybe this is a stupid question or a dumb place to ask but I'll shoot it out anyways.
What's the difference between the EB 48.3 and the EB SL? I know the SL can basically be a SCT or a buggy with a couple different parts. Is the same true for the 48.3 then? Basically a SCT410.3 with a couple buggy parts? Lastly, difference between EB48.3 and the ET48.3, other than wheels and longer a-arms? Can they all be interchanged?
Calde315 is offline   Reply With Quote
Old 10-26-2015, 01:38 PM   #557
vwduud's Avatar
Trader Rating: 45 (100%+)
All 3 vehicles share a similar platform. The chassis layout between the SL and the EB48.3 are the same (although different aluminum and stamping/milling), with the ET48.3 having a longer version of this same chassis layout.
The drivetrain of the SL is smaller and lighter than that of the full weight EB48.3. This is noticeable mostly in with the smaller diff 1/10th scale outdrives and dogbones. However, the arms, towers and shocks are all smaller, lighter versions on the SL.
ET48.3, as you mention, has longer arms in addition to the above mentioned longer chassis. The EB48.3 and the ET48.3 now share the same size front and rear shocks(long - front, extra long - rear), whereas the SL uses short up front and the "long" shock in the rear. Truggy uses heavier springs than the buggy.
The ET48.3 also has a different internal drive ratio in the front and rear diffs to accommodate the larger truggy wheels and tires.
There are a lot of common parts across all three vehicles, making it nice to own a fleet of Tekno's and being able to share parts.
And yes, the SL and SCT share the same light weight drivetrain parts.
Jim Brown
Tekno EB-48.4, ET-48, Rx8 G2, 1900kv/2000kv, Savox 2274/2273, SMC, 4PX
Sponsors: Tekno, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 10-26-2015, 07:11 PM   #558
Mizchief's Avatar
Anyone running box setup and wants a little more rotation / exit corner steering try moving the links to the inside on the hub on front and dropping the rear to 4k. I'm running 7-5-4 and feel it squares up just a little faster but still hooks and powers out of the turn.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 10-27-2015, 03:36 PM   #559
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
What brand diff oil, PT?
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 10-27-2015, 07:08 PM   #560
Mizchief's Avatar
I use a different brands just depends on what I have on hand and what I can get in the rating I want. CST rating should be a standard measurement across brands, but who knows how close they really are.
I'm using AE 7k front, Kit 5k in the middle and Mugen 4k in the rear
Tekno Team Driver
AKA Racing
Old 10-28-2015, 10:58 AM   #561
justpoet's Avatar
Trader Rating: 16 (100%+)
Generally diff fluids are closer to each other than shock fluid "wt" since cst is an actual measurement. However, various brands still tend to feel softer than others, and some are more consistent than others.
I've not picked up any PT myself yet, though a lot of the Tekno guys love it. I've had good luck with Kyosho diff fluids myself when not using oils from kits (which I still have plenty of).
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 10-28-2015, 11:16 AM   #562
stanson's Avatar
Took my EB48.3 to the track for the first time - finally!
Very, very suprised how this thing drives. After a few laps I beat my Losi 3.0 lap time record by 1,5 seconds (rather big track, it's 45+ seconds laps). And I was able to be very consistent with these fast laps! Amazing And it was all stock setup.
Don't really understand why some of you write it doesn't have enough steering. I had a lot, much much more than on my Losi which is perfectly tuned for this track.
Rear end felt a little nervous, need to tune it. Can't wait for 2016 season!
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 10-28-2015, 01:36 PM   #563
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Install the steering limiters if you haven't already, 4 washers. Should help the rear end feel better and you'll still have plenty of steering.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 10-29-2015, 02:37 AM   #564
R1Joel's Avatar
I'm interested in this kit but I am increasingly worried about having fitment issues with my Hobbywing Xerun 150a.
R1Joel is offline   Reply With Quote
Old 10-29-2015, 02:54 AM   #565
I just got my .3 so i don't know if it was covered. On the shock package. 400 front/ 450 rear is stock, witch isn't that bad at all. Feels like a pillow. what else are people running? Still thicker in the rear over the front? I would like to try heaver fluid all around. Honestly I've never had my rear thick then my front before.....im kinda at a loss on what to try. I would like to try them a little more "dead" where they just take the hit, suck it up on a landing...not a lot of rebound
Dont Hack Me is offline   Reply With Quote
Old 10-29-2015, 02:55 AM   #566
Ive seen a lot of the old 150a in Tekno. Starting to see the new xr8 150a in them as well. They do fit...
Old 10-29-2015, 10:22 AM   #567
Carter Flotron's Avatar
It's very easy to get both the new XR8 and 150A to fit just got to have a short sensor wire
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 10-29-2015, 10:31 AM   #568
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Its probably because the previous version had even more steering than the new car. Loved the car,it worked well but was still hunting for a setup a bit more than I liked but other drivers on the track made it go quite well.
next year if all goes well I hope to see the Tekno drivers with the new cars laying down some laps and get some good setups as they track unless something changes in general is rough and very loose. Fun track though.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 10-29-2015, 12:06 PM   #569
justpoet's Avatar
Tekno RC is now accepting driver sponsorship applications with driver resume. Please send an e-mail to your Regional Team Manager (as shown in the link below) with the title "2016 Tekno Sponsorship Application" if you would like to be a part of the team. I am in no position of power at all, just spreading the word. Good luck!
http://www.teknorc.com/rtm-territories/
Old 10-29-2015, 12:08 PM   #570
justpoet's Avatar
A lot of this is dependent upon shock position so that you end up with somewhat matched response on the front and back. I run the same oil all the way around on mine.
