    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-14-2015, 02:40 PM   #496
Trader Rating: 16 (100%+)
Originally Posted by stanson View Post
I have a question directly to Tekno RC or maybe someone could help.
I built my buggy with stock diff fluids: 5000/5000/5000 for the diffs and 400/450 with the shocks.
In the future these fluids will wear, I would also like to test some different settings. Are these stock oils cts, csp, "Tekno WT" or something else? I have a lot of Losi and AE oils on hand, found a conversion chart but not sure where is a starting point I am at?
Stock oils are CST
MX304 is offline   Reply With Quote
Old 10-14-2015, 03:35 PM   #497
Originally Posted by MX304 View Post
Stock oils are CST
Also, I was told the oil with kits are ptrc oils.
qstorm777 is offline   Reply With Quote
Old 10-14-2015, 03:48 PM   #498
Originally Posted by Carter Flotron View Post
+1 Give it a try! Definitely improves the car in many aspects. IF you still have issues with enough steering and you're stuck just post your setup and one of the many team drivers like myself can help you guys out.
Wicked Weekend Nitro buggy setup is what most are running on both cars (with minor adjustments in a few spots for driving style).
Not positive on the Losi oil, but for Associated its around 35/40. Hopefully that helps.
Tried looking at the setup sheets but any I open appear blank. Don't know why this is, anyone else having the same issue?
Tbone17 is offline   Reply With Quote
Old 10-14-2015, 04:04 PM   #499
rcgod's Avatar
Trader Rating: 27 (100%+)
Try a different app. Pdf reader works well for me.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-14-2015, 05:19 PM   #500
Thanks. Used the Adobe app and it all shows up.
Old 10-14-2015, 05:43 PM   #501
On Joe's Wicked Weekend setup. Are the A, B, C, D blocks stock, as why he did not mark. Also, the ball stud orientation. Thanks
Wenrock is offline   Reply With Quote
Old 10-14-2015, 05:51 PM   #502
Disregard, got on the old pc and everything shows up.
Old 10-14-2015, 09:21 PM   #503
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
The oils included with the kit are not PTRC Racing oils. However, PTRC Racing oils are what most of the team uses.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 10-16-2015, 04:34 AM   #504
stanson's Avatar
Guys am I doing something wrong here or do I need low profile servo?
Trying to fit in Savox 1258 but there's no space to attach the servo horn :/
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 10-16-2015, 04:58 AM   #505
slakr's Avatar
Trader Rating: 28 (100%+)
Think you need to flip the servo horn the other way (you have it upside down). Then connect the steering link to the bottom of the servo horn.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 10-16-2015, 05:00 AM   #506
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Use a counter sunk screw from the bottom of the servo arm, linkage on top then the nut.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 10-16-2015, 05:35 AM   #507
stanson's Avatar
I don't get it.
I can't filp over the horn, if i put it upside down, it won't connect with the servo teeth (sorry for my bad english), the horn works with the servo only the way I put it before...
Old 10-16-2015, 06:38 AM   #508
suzukipro's Avatar
Trader Rating: 21 (100%+)
I don't get it.
You had the horn on the servo correctly the first time, the post above this one is correct and you'll need to use a countersunk screw inserted from the bottom of the servo horn then the linkage with a locknut on top.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 10-16-2015, 08:32 AM   #509
stanson's Avatar
Thanks, I was using the wrong screw, now it works ok so problem solved.
Old 10-16-2015, 09:33 AM   #510
justpoet's Avatar
Glad you got it sorted out.
Also of note, to make it easier on the servo, you should make the link as flat as possible. So if you have a big angle going on, add washers (and possibly a longer screw) on the servo saver side until the link is close to flat.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
