    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 09-23-2015, 11:05 AM   #361
vwduud's Avatar
Trader Rating: 46 (100%+)
Originally Posted by stanson View Post
3. What about diff pins: TKR5150 vs TKR5150A? Which will last longer and cause less problems? ...
I run the aluminum diff cross pins just for the idea of a lightened drive train. The kit comes with the steel ones.
The aluminum ones that are in my .2 were installed just as these were available and are still in use today, with little to no wear at all.
Not a "must have" by any means, but this is one area where you can shave weight and rotating mass without the worry of accelerated wear. The steel ones never failed for the year+ that I ran them as well. Either way, these shouldn't be an area of concern. This, like the rest of the car is as tough as the Losi in terms of breakage, but seems to get less sloppy over time.
Great car. Great company. Great customer service.
Jim Brown
Agama A215E, Rx8 G3, 1900kv, Savox 2273, SMC, 4PX
Sponsors: Agama, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 09-23-2015, 01:08 PM   #362
I am pretty sure the cross pins are really only there for assembly purposes, after that they are just along for the ride.
Tekno eb48.2
Tekno sct410.3
one8updragracer is offline   Reply With Quote
Old 09-23-2015, 01:51 PM   #363
Pretty sure the cross-pins are just static weight, the bevels rotate the pins are stationary. Probably an area I would leave in steel but, not that big of a deal either way and if you're shaving weight, everything matters.
Fasttrak is offline   Reply With Quote
Old 09-23-2015, 01:51 PM   #364
I bent a shock shaft last race, honestly, not a really big hit either... must have just hit just right... either way, i'd like to upgrade to the TiNi shafts but i'm not sure which length to get. On the Tekno site for option parts it lists 3 sizes - 107mm, 122mm, and 137mm... What's the proper lengths for the EB48.3 front and rear? Thanks!
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 09-23-2015, 02:08 PM   #365
122mm front, 137mm rear
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 09-23-2015, 06:33 PM   #366
vwduud's Avatar
Since the whole diff rotates (along with the internal pins and gears), the lighter diff pins affect both the static weight and the rotational weight.
Jim Brown
Old 09-23-2015, 08:06 PM   #367
Mikeand22's Avatar
Trader Rating: 24 (100%+)
Just ordered one of these. Switching From a Losi to match the rest of my Tekno fleet. Can't wait to get it out on the track.
Mikeand22 is offline   Reply With Quote
Old 09-24-2015, 02:36 AM   #368
stanson's Avatar
Could someone please link to 1x8 pistons or give the part number? Blind or something, can't find them.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 09-24-2015, 03:57 AM   #369
snwchris's Avatar
I don't think I've ever seen a 1x8 piston...
Most of the common pistons are 8x1.3, 6x1.5, 4x1.8
snwchris is offline   Reply With Quote
Old 09-24-2015, 07:08 AM   #370
Yes they do, not sure why but I was just picturing the inner diff and how it functions and not how it is installed and used in the drive train.
Funny as later that same day a package arrived and I got to build three 1/8th scale diffs last night. Pretty surprised how much mass those three diffs have filled with oil. This hardware is quite a bit more stout than my experiences with 1/12th and 1/10th scale vehicles.
So far I am really impressed with the fit and finish on this kit, it is going together very smoothly. The only tricky part with the diffs is getting that damn pin into the out-drive to diff casing connection, fat fingers make it a chore.
Old 09-24-2015, 07:23 AM   #371
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Use needle nose pliers to get those pins in the diff case.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 09-24-2015, 08:14 AM   #372
Ilias's Avatar
Default New Products Now Available
Hi guys,
I just wanted to share our latest products here:
First of all we have our Multi-Purpose Shock/Ball End Tool:
Main Features are:
  • Precision CNC machined high quality aluminum
  • Best tool for shock building and pivot balls / rod ends
  • Two tone anodized finish
  • Laser etched size and tool indications
  • Comfortable and easy to use
Also new Front and rear Sway bars:
Details:
TKR5095 Sway Bar (front, 2.9mm, EB.3/NB.3/SL/SCT.3)
TKR5094 Sway Bar (front, 2.7mm, EB.3/NB.3/SL/SCT.3)
TKR5093 Sway Bar (front, 2.1mm, EB.3/NB.3/SL/SCT.3)
TKR5092 Sway Bar (front, 2.0mm, EB.3/NB.3/SL/SCT.3)
Details:
TKR5499 Sway Bar (rear, 2.9mm, EB.3/NB.3/SL/SCT.3/ET/NT)
TKR5498 Sway Bar (rear, 2.7mm, EB.3/NB.3/SL/SCT.3/ET/NT)
TKR5497 Sway Bar (rear, 2.2mm, EB.3/NB.3/SL/SCT.3/ET/NT)
TKR5496 Sway Bar (rear, 2.1mm, EB.3/NB.3/SL/SCT.3/ET/NT)
Products are now in stock and available for purchase.
Tekno RC
www.teknorc.com
Ilias is offline   Reply With Quote
Old 09-24-2015, 08:50 AM   #373
Already ordered from Pete.
Originally Posted by Ilias View Post
Hi guys,
Main Features are:
Old 09-24-2015, 09:03 PM   #374
I am at step J-4, the steering rack assembly, and something seems off to me.
They show the washers being under the ball between the head of the screw and the ball. How does that change the bumpsteer? Shouldn't the washers be between the ball and the steering rack to change the bumpsteer?
Old 09-24-2015, 09:11 PM   #375
rcgod's Avatar
Trader Rating: 27 (100%+)
Stock setup has no washers between ball and rack. Use the extra washers on the other end of the ball to keep the screw from rubbing the underside of the top plate and as a convenient place to keep them for when you want to change the bump steer.
rcgod is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
