    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 09-06-2015, 07:23 PM   #286
Originally Posted by wrightcs77 View Post
Running into the same issue, mid corner push. Will be trying some changes soon
I had the same problem until I moved the camber length in on the front wheel side. This gave me a lot more steering to where I was over steering. I calmed it down by moving the shocks one hole out on the shock tower. This is assuming stock setup.
Ulch
Ulch is offline   Reply With Quote
Old 09-08-2015, 05:40 AM   #287
snwchris's Avatar
Finally got another race day on the Tekno .2-3 with the upgrades. Last time I had a lot of push issues with it in some of the tight turns and 180s and not the best finish.
This time I out I switched to the Lutz Enats setup but using 7-7-5 in the diffs instead and also Green fronts and Yellow Rears. The car felt super planted and tons of steering. I was able to keep tight lines in the 180s and hammer thru the sweepers no problem. I could drive in and out of the corners a little harder and faster.
snwchris is offline   Reply With Quote
Old 09-08-2015, 05:32 PM   #288
Default A arm wear.
Is anybody getting somewhere like this on there a arm from the screw that secures the rod to the steering knuckle of the hub? I'm going to clearance it with a dremel just curious if anybody else has seen this.
Riflebuilder is offline   Reply With Quote
Old 09-08-2015, 05:35 PM   #289
wrightcs77's Avatar
Trader Rating: 521 (100%+)
Yes. Then I limited my travel so my shock length is the same as the Lutz set up. No more rubbing.
wrightcs77 is online now   Reply With Quote
Old 09-08-2015, 06:30 PM   #290
rcgod's Avatar
Trader Rating: 27 (100%+)
Also you can put more washers under the head of the screw to limit how much of the screw hangs down below the nut. That's what I did as well as slightly limiting droop by 1mm
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-08-2015, 08:23 PM   #291
It's too much droop. Gotta take some out and no more rubbing.
SpongeX is offline   Reply With Quote
Old 09-08-2015, 08:32 PM   #292
Lutz's setup from Amain.com labor day race... Thinking about trying this setup out, even though the track i run on is more loose than Amain. What do you think?
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 09-09-2015, 06:28 AM   #293
RokleM's Avatar
Trader Rating: 33 (100%+)
This setup has been getting great reviews and is apparently possible on both the EB48.3 and NB48.3
I plan to give it a try as I've made quite a few adjustments to both vehicles already. Worth looking into if you're interested.
http://www.teknorc.com/tekno5/wp-con...0Bumpy_Dry.pdf
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 09-09-2015, 12:05 PM   #294
Carter Flotron's Avatar
+1 This is a very good setup. Great base to start with.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 09-09-2015, 12:46 PM   #295
I don't have many more races this season but I might give it a try.
Old 09-09-2015, 12:57 PM   #296
snwchris's Avatar
Yea same boat here with only couple races left for Outdoors. I'm definitely happy with the Lutz Enats setup, so already filled out my setup sheet for next year.
It will be interesting to see what changes I need to make for Indoors in a few weeks.
Old 09-09-2015, 08:06 PM   #297
wrightcs77's Avatar
This looks like it is for high traction. I am looking for a good starting point or base set up for low to mid traction, dusty track that is outdoors. I am having a mid corner push. I am not the only one, another local driver and some people on line are having the same issue.
Old 09-10-2015, 09:18 AM   #298
snwchris's Avatar
^^^^ Try the Lutz Enats setup, the buggy felt planted and tons of steering.
Old 09-10-2015, 05:23 PM   #299
Mizchief's Avatar
+1 Or can use a shorter screw, forget the exact length.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 09-11-2015, 06:17 AM   #300
RokleM's Avatar
Agreed. Easiest is to just use a different screw or dremmel a small portion off quick. No need to change your setup to accommodate this change.
- Eric G. -
