    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 08-31-2015, 05:26 PM   #271
Mizchief's Avatar
Originally Posted by qstorm777 View Post
Ok. I currently have a serpent 811e and bought 4 2s packs this year. Really want to switch to eb48.3 (sct and trug are tekno), but don't want to have to buy more batt packs.
As long as they are the standard size 2s they should work. Tekno's use two horizontal straps then one vertical so as the batteries put together are about the size of a 4s pack you can make it work.
http://www.smc-racing.net/index.php?...product_id=255
Those are the ones i've used for a size reference
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 09-01-2015, 05:17 PM   #272
wrightcs77's Avatar
Trader Rating: 521 (100%+)
What all are you all doing to get more off power steering?
Thanks.
Running into the same issue, mid corner push. Will be trying some changes soon
wrightcs77 is offline   Reply With Quote
Old 09-01-2015, 05:33 PM   #273
I posted in the original eb48 thread about pushing. I run on a hard dusty track and just can't get enough front traction to make tight turns. I gotta slow wAy down and walk it around the turn till it's straight. My sct410.3 turns on a dime on the same track with same tires. I still say the new front suspension geometry doesn't allow enough weight transfer on loose tracks. It's to stiff when the suspension gets into it's compression.
Dragonfueled is offline   Reply With Quote
Old 09-01-2015, 07:25 PM   #274
Motorman007's Avatar
Trader Rating: 78 (100%+)
Anyone know where I can get one of these
TEKNO R/C TKR4301X 1/8 TRAKTION DRIVE / ELEKTRI-CLUTCH KIT ?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 09-01-2015, 09:54 PM   #275
rcgod's Avatar
Trader Rating: 27 (100%+)
You guys that are haviing pushing issues how many bump steer washers are you running inner and outer? Sometimes increasing bump steer will help mid corner push. I noticed on Lutz's buggy he wasn't running any washers. Maybe something to look at.
Just noticed on his latest setup he runs 1 washer on rack and 0 on outer.
rcgod is offline   Reply With Quote
Old 09-01-2015, 09:55 PM   #276
rcgod's Avatar
I was looking for one today. The only place I found them was in Europe. Tekno discontinued them.
Old 09-02-2015, 04:13 AM   #277
Thank you. Do you have a link?
And do you know if we can still get the shoes and springs?
Old 09-02-2015, 07:36 AM   #278
rcgod's Avatar
Springs are available thru Tekno.
http://www.teknorc.com/product-categ...lektri-clutch/
Shoes in stock at Stormer.
http://www.stormerhobbies.com/cgi-bi....pl?pn=TKR4301
Complete clutch in europe.
http://www.eurorc.com/product/10069/...dapter-springs
Dialed RC Hobbies
Old 09-02-2015, 11:32 AM   #279
pballer2777's Avatar
you could always try the losi system that was just released. i ordered one to give it a shot.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 09-02-2015, 12:11 PM   #280
This will work with out any MOD?
Old 09-02-2015, 12:12 PM   #281
Thank you sir
Old 09-02-2015, 12:14 PM   #282
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
you flip the diff in the mount.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 09-02-2015, 12:38 PM   #283
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I don't know for sure if it'll fit as they're using the longer clutch bell whereas our was using the shorter 3 shoe style clutchbell. It should fit, but again, I'm not sure.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 09-02-2015, 12:39 PM   #284
other than just having to flip your diff i don't know. they are not out yet. i was told mid of sept. so we'll just have to wait and see. but don't see any other reason it wouldn't work.
Old 09-04-2015, 05:33 PM   #285
I was having the same problem with my truggy,another driver helped me and I changed to a 2.3mm sway bar up front and a 2.8 in the rear. On the truggy I like to let the back end swing around to get the front pointed straight. This helped plant the front and let the rear move a little.
Riflebuilder is offline   Reply With Quote
