    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-31-2016, 07:09 AM   #2476
Question regarding the HRC hubs: are the team drivers using them in conjunction with rear diff housing riser, or without the riser? Thanks.
Tampagoalie is offline   Reply With Quote
Old 10-31-2016, 10:59 AM   #2477
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
AFAIK, no team drivers are running the riser plate anymore.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 10-31-2016, 11:00 AM   #2478
Suspended
Are the universals any stronger than the stock driveshafts? My stock ones bend very often...
spite_suicide is offline   Reply With Quote
Old 10-31-2016, 11:25 AM   #2479
How are you bending driveshafts? That baffles me.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-31-2016, 11:34 AM   #2480
Suspended
I can't get one to stay straight on my EB or NB... one of the front will bend within 2 weeks everytime...
Old 10-31-2016, 11:57 AM   #2481
Are you running front and mid braces on EB? And all 3 on NB?
Old 10-31-2016, 12:50 PM   #2482
bigboyz12000's Avatar
Wow..i have not bent or broken any drive shafts on my buggy. Bend not break comes to mind.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 10-31-2016, 01:01 PM   #2483
Suspended
I've never broken a shaft, but they do bend easy... the front ones at least
deceit is offline   Reply With Quote
Old 10-31-2016, 01:28 PM   #2484
Suspended
My front driveshafts bent within 2 weeks of having my eb, and my nb bent one the first time out... I don't recall any crashes that would of caused it either. my sct however hasn't bent one yet, and that thing has had some nasty tumbles.. haha
so you guys run front brace only, and universals and dont have any issues with bending?
Old 10-31-2016, 01:47 PM   #2485
No, I run all braces on ET, EB, & NB....SCT I run front and middle..
Old 10-31-2016, 01:55 PM   #2486
Trader Rating: 16 (100%+)
I've been running a Tekno EB48 since the very first version was released. Always with the front brace only. I have never bent a drive shaft. CVD or Universal.
MX304 is offline   Reply With Quote
Old 10-31-2016, 02:50 PM   #2487
Suspended
the drive shaft is bent, but still works fine.... it doesn't make the car wobble or anything, but when you roll it you can see the shaft is bent... im not talking bent so much that it doesn't work, but it is bent. I want to try the universals, but i wanted to see if they were a little stronger first since they are kinda pricey
Old 10-31-2016, 05:54 PM   #2488
I wanted to know if they give any race advantages. So far I have learned "Made the car better through the bumps." You related they are pricy. I think i saw $50 a pair. I may try them as i run on a bumpy track. Im hoping for more feedback on them.
Old 10-31-2016, 07:36 PM   #2489
Originally Posted by jmcelroy42 View Post
I checked that thanks, one of them was a turn off, so I fixed that. But I am still having the same problem.
Jmcelroy42, easiest way to make camber is to cut the camber rods shorter. We typically remove 3-4 mm per side. Otherwise you can use our TKR5550 SCT camber rods which are shorter.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 10-31-2016, 10:58 PM   #2490
Originally Posted by MattDub View Post
Recommend this or this. For larger than 2.0 use this.
Matt, does the 1.8 vs 1.9 make that big of a difference?
qstorm777 is offline   Reply With Quote
