    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-26-2016, 07:23 AM   #2431
Originally Posted by Dragonfueled View Post
I just set mine up based on the new outdoor setup. Man the bump steer is aggressive. At full compression theres allot of toe out. Ill find out tomorrow night how it feels
Hey guys, The recommended setups on our site are brand new and might need to be tweaked a little. Especially the bump setting.
We like to have a good amount of bump out but not a super excessive. At ride height, there should be 1 to 2 of toe out, and at full compression, it should go to 3 or 4. Let me know if it is more and I will adjust the setups.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 10-26-2016, 07:24 AM   #2432
Originally Posted by Jpm1 View Post
Just double checking that in the new outdoor setup that using different pistons front to rear isn't a Typo?
This is correct, we are using less pack in the front.
Matt Wolter
Old 10-26-2016, 08:39 AM   #2433
jmcelroy42's Avatar
I am confused as to why you would want to add bump steer?
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 10-26-2016, 11:57 AM   #2434
More bump out gives more mid corner steering.
Hey Matt, who else is stocking your low frequency springs right now? I'm looking for the black fronts and orange rears and teknorc.com and http://www.fiercercsolutions.com/ are both out of stock.
anr211 is offline   Reply With Quote
Old 10-26-2016, 12:29 PM   #2435
jmcelroy42's Avatar
Thank you,
I am also looking for those springs, as well as the HRC rear hubs
Old 10-26-2016, 12:31 PM   #2436
Suspended
I got the sct and eb hrc hubs, and LF pink/red, but they are out of LF black/orange. ]:
-Tekno SCT/EB-
deceit is offline   Reply With Quote
Old 10-26-2016, 03:53 PM   #2437
Just curious, why the less pack up front?
qstorm777 is offline   Reply With Quote
Old 10-27-2016, 05:10 AM   #2438
MattDub, I don't know if you ever ran Joe's AMS or Southern Nat setup, but, if so, can you compare the recommended outdoor setup to Joe's setup?
Old 10-27-2016, 10:35 AM   #2439
suzukipro's Avatar
Trader Rating: 22 (100%+)
Any plans to release softer rear LF springs as yellow is the softest of the current offering. I would like to try a set of pink or green rears on my EB48SL
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 10-27-2016, 10:51 AM   #2440
Trader Rating: 16 (100%+)
Thank you,
As of about 15 minutes ago, Amain has the springs and hubs in stock.
MX304 is offline   Reply With Quote
Old 10-27-2016, 11:44 AM   #2441
bigboyz12000's Avatar
Quite a bit of difference actually. Emulsion is better on bumpy tracks and also helps reduce chassis roll, lands better too. We run emulsion on all EBs and NBs. Vented caps have a slight delay when the bladder compresses before they start producing resistance.
I always use emulsion on all my 1/8 builds. For the reasons stated above.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 10-27-2016, 12:27 PM   #2442
jmcelroy42's Avatar
thanks, got the springs, hubs were sold out already
Old 10-28-2016, 12:50 AM   #2443
Jpm1's Avatar
Matt, how are you drilling the 1.8 out to 1.9, what brand of drill are you using, i cant find that size anywhere?
Justin
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 10-28-2016, 05:57 AM   #2444
Justin
#48 drill is 1.93mm if that is any easier for you to find.
Old 10-28-2016, 07:01 AM   #2445
RokleM's Avatar
Trader Rating: 33 (100%+)
Justin
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
