    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 10-15-2016, 09:03 PM   #2356
Originally Posted by qstorm777 View Post
Tekin hotwire interface allows you to change the bec voltage. Did you set the endpoints for steering on your radio?
The travel?
Expose193 is offline   Reply With Quote
Old 10-15-2016, 10:03 PM   #2357
Super Moderator
Trader Rating: 17 (100%+)
ahh yes he brought up a good point that I always assume everyone knows. Make sure you are setting the End Points / Travel correctly. You don't want the servo to keep trying to crank away when it's physically limited.
Watch Ryan's video here
https://www.youtube.com/watch?v=8mw4rkTeWbQ
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 10-16-2016, 06:37 AM   #2358
So if I go with a 1268 savox
I would need to run it at 7.4 bec to get the 300+ torque correct? Sorry for the noob questions.
Old 10-16-2016, 06:53 AM   #2359
Suspended
Correct, it would drop to 208!!!! Which is an insane drop
Dimensions(mm): 40.3x20.2x37.2
Weight(g): 62.0
Speed(@4.8V sec/60): .15
Torque(@4.8V oz-in): 160.0
Speed(@6.0V sec/60): .13
Torque(@6.0V oz-in): 208.3
Speed(@7.4V sec/60): .11
Torque(@7.4V oz-in): 347.2
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
deceit is offline   Reply With Quote
Old 10-17-2016, 05:44 AM   #2360
Super Moderator
Yup that's correct. I run it in 6.0v for 10th scale. Again, it's nice to just use one servo in all cars.
Old 10-17-2016, 08:42 AM   #2361
We are pleased to announce a complete line of Low Frequency (LF) springs that will further improve the handling of your NB/EB48.3 vehicles. Our new spring design improves traction by reducing chassis oscillation on rough track surfaces and large jump landings. Overall stability of the vehicle is improved, providing better forward grip, increased corner speed and quicker lap times.
With additional coils as well as a larger wire diameter, the new LF springs feature a bronze gunmetal finish with a color indicator for easy spring identification. The springs fit all variants of the NB48 and EB48 vehicles and include two springs per package.
Click here for more info.
MattDub is offline   Reply With Quote
Old 10-17-2016, 08:51 AM   #2362
Been very noticeable for me. Sometimes I feel like the rear is locked down too much.
If it feels like the rear is locked down too much (not rotating), recommend adding a little camber to the rear. Should help free it to rotate in corners. The new HRC hubs do add more grip to the rear and adding camber helps it rotate and also be more forgiving in the bumps.
Matt Wolter
Tekno RC - National Team Manager
Old 10-17-2016, 12:04 PM   #2363
exheliguy's Avatar
Hey guys. I have a Tekno eb 48.2 and want to make it a sct. What do i change or add ? Or do any of the parts" front and rear bumpers and body mounts fit?
exheliguy is offline   Reply With Quote
Old 10-17-2016, 07:17 PM   #2364
Good deal. That will be my next change. Right now I'm sitting at 2 deg. I'm going to play with my driving style (buggy rotates pretty good when carrying speed). It's the slow corners (180s) that get me from time to time if I had to slow down too much (mistake, traffic, bad line, etc).
qstorm777 is offline   Reply With Quote
Old 10-19-2016, 05:43 AM   #2365
rregl0612's Avatar
Trader Rating: 33 (100%+)
No first hand exp. Doing this, but de makes 17mm wheels, you'd need side guards, and bodymounts, if the mounts don't fit on the eb towers you'd need to fabricate or switch out towers.
If the 17mm offsets to wide. It's gunna get pricey as you'll need nwmew cvd
rregl0612 is offline   Reply With Quote
Old 10-19-2016, 05:44 AM   #2366
rregl0612's Avatar
If the 17mm offsets to wide. It's gunna get pricey as you'll need new cvd ends, and new hubs front and rear with the correct bearing size
Old 10-19-2016, 07:52 AM   #2367
Could also try shorter wheelbase to help rotation, correct Matt?
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-19-2016, 06:00 PM   #2368
Originally Posted by Bob Barry View Post
Our rule of thumb is 300+ oz torque. the 1256 is 277oz of torque.
With that being said, it SHOULD be enough. But if you're rough on the car, landing often on one wheel, taking big tumbles, etc... you could blow through one.
The other thing is make sure your servo saver is actually working, nothing is bound. Also it's NOT an HV servo, so you can only run it at 6 volts.
This is actually the servo I had in my 10th scale stuff and 4wd sct prior to switching to the 1268.
So I got the 1268 in today and the wire is not long enuff? ??
Old 10-19-2016, 06:04 PM   #2369
Suspended
You need a servo extender, can pick up a 3" at your LHS for $2-3
Old 10-19-2016, 06:11 PM   #2370
Damm well I guess I should have asked no lhs. Ehh what a bummer , thanks anyways fellas
