    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 08-26-2016, 01:26 AM   #2116
Suspended
Just finished building my eb48.3, and wow... So many aluminum parts compared to my sct410.3! Thing is amazing. Now if only Saturday would come, so I could try it on the track.
-Tekno SCT/EB-
deceit is offline   Reply With Quote
Old 08-26-2016, 03:40 AM   #2117
werner sline's Avatar
looks good !
werner's bunch of 1/8 RC freestyle tricks NEW video : TRUGGY tricktionary, part 2: 14 tricks
check it out : https://www.youtube.com/watch?v=5PVrXfs5TG8 6s power !
werner sline is offline   Reply With Quote
Old 08-26-2016, 04:37 AM   #2118
don't want to bend the main shaft again so I did this ( sorry ! )
by the way, TEKNO is really correct with their prices and the main shaft only costs 17 bucks. thanks god it's not an Xray !!
+ this aluminium piece is really the best main shaft to do the job. Any steel will bend and wobble
Old 08-26-2016, 07:19 AM   #2119
Super Moderator
Trader Rating: 17 (100%+)
That's cool and all, but just keep in mind that you can now no longer take ANY setup advice that anyone is giving you here. You completely changed the characteristics of the car so unless someone here has that brace too, just ignore it.
Make sure you now phrase any questions like this "I'm looking for more entry steering, will raising my front inner camber link help or hurt".
Not trying to be rude, I just don't want you to have a bad experience because one of us is trying to help and we don't realize that your car has that brace.
For what it's worth, none of us run any braces except the front one, and personally I haven't seen a single bent center drive shaft yet.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-26-2016, 08:46 AM   #2120
Can't forget about Tekno's awesome warranty. Send in your bent driveshaft, and get a replacement at 50% off.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 08-26-2016, 03:10 PM   #2121
thanks guys for all the advice. I'm not a racer so the setup isn't very important for me. The only thing I do is jump ( check my videos in my signature ) so it's all about survival !!
So far the tekno hold better than I thought. This mainshaft bending brings me back to my first 1/8 buggy with the exact same problem : the hobao hyper 9e
I won't ask any warranty because this car is meant for racing, not stupid freestyle jumps like I do ! ( video is half filmed ... )
Old 08-26-2016, 05:37 PM   #2122
Suspended
Ok.. so I took my eb48.3 to the track today, just finished building it yesterday. I have pink/red springs, 7-7-5 diffs, stock shock oils, and this setup.
http://www.teknorc.com/wp-content/up...ern%20Nats.pdf
it was extremely loose, handled jumps amazing and landed very well. but it was a handful to control and turning was awful. there is a pic of the track, any tips on where a good starting point for a setup would be appreciated. If i tried to take it slow i couldn't drive it, but if i drove it hard it actually handled better sliding around the turns. I want it to be easy to drive as i get used to 1/8 ebuggy. this is my first one, so driving that loose isn't a good starting point.
ps, using the rx8g2, t8 1900kv, and smc 6500 60c i ran for 1hr 45m before losing a body slip and switching batteries (only because i had to stop anyway, the batt wasn't dead).... not sure how that is possible, i was running the car pretty hard. since it was loose i kept on the throttle hard a lot. it was running 145* motor temp after the run with a 15pinion.
-Tekno SCT/EB-
Old 08-26-2016, 05:57 PM   #2123
mkl
1hour 45!!?? Wow, I have the same set up and only get 20-30mins before LVC.
But look at your tires. Are those popular choices at that track? I would think something with smaller pins might be better for a hard, loose track.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 08-26-2016, 06:34 PM   #2124
Suspended
I honestly dont know how the battery lasted so long... I did have to go flip my car over a lot, but still.. and probably not, i wanted impacts, but tower was out of stock when i ordered them and they just got them back in stock 2 days ago. these are enduro mediums, and they handle like shit on this track. no one else was there today, so im not sure what others run. but it is a very hard/loose track.
ive been running a tekno sct and i have 6000 and 7200mah packs, and they dont last long with a tekin 4300kv... not sure how this thing lasted so long, and the battery never actually died, i swapped just cause i knew it had to be close...
but i definitely need to change the setup and possibly the tires. im just getting back into rc and racing, so im pretty clueless on a starting point for setups. tweaking it slightly to get it where i want it isnt a big deal, but i feel like im way off with the setup i have. haha
-Tekno SCT/EB-
Old 08-27-2016, 08:58 AM   #2125
RokleM's Avatar
Trader Rating: 33 (100%+)
Tires really really matter. Personally I think it's probably 50-75% of the setup at least. Big blox, enduros, etc all do well on hard packed dust free tracks. That looks very dust, so they would basically slide across the surface instead of cutting through the dust and getting to the hard pack. This would cause what you stated, loose vehicle as the tires slide in the dust, lack of turning due to the tires sliding across the dust instead of biting into the surface, etc. Start with a tire change first, then start working on the setup.
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 08-27-2016, 10:38 AM   #2126
Super Moderator
You're loose because of tires. Go with a small pin tire. Also temps play a big part of it. I run Blues mostly which are Soft. If the temps drop below 75 deg I'll switch to Greens which are Super Soft. My tire of choice is the Reflex by JConcepts. Followed by Triple Dees and Chasers.
Make sure you rebuild your diffs and shocks after about an hour of track time. Also Pistons taper up.
Old 08-27-2016, 11:29 AM   #2127
Suspended
Would impacts be a decent choice then? And yes, it was very dusty. I have green subcultures on my sct410.3, but i didnt get to run it yesterday.
I have the white 4hole's, taper up atm with stock 400/450. someone recommended i switch to 10/7/5 diffs also.
I am hitting the track again tomorrow, so hoping I can make some adjustments to it today so i can get some better laps in tomorrow.
-Tekno SCT/EB-
Old 08-27-2016, 12:01 PM   #2128
mkl
Pistons taper up has been talked about a lot recently. What is the theory behind that? Seems like taper down would allow a little quicker rebound to get the shock set up for the next impact. Then with taper down it will help with compression as well.
I think I will try the taper up, just rebuilt my shocks though-drat!
What is happening with the taper up?
Old 08-27-2016, 12:59 PM   #2129
dogwood174's Avatar
New car? New cars can be looser until they break in. And of course, those tires.
Team Tekno driver, AKA, Futaba, Tekin, Hitec, Bodies by "Fat Joe"
dogwood174 is offline   Reply With Quote
Old 08-27-2016, 02:14 PM   #2130
Suspended
Damn.. for the sct I know Enduro's were kinda popular. For ebug, I don't see any at all.. and unfortunately they were more expensive than any other tire.
-Tekno SCT/EB-
