    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 08-17-2016, 06:11 PM   #2086
Anyone else having issues with the rear bottoming out? I feel like no matter how thick I go with the rear fluid it's still to soft. Currently at 50wt associated lol, can the Pistons wear out? It slaps really hard off jumps. Been an on going issue for me lately.
Dragonfueled is offline   Reply With Quote
Old 08-17-2016, 07:14 PM   #2087
8ight-e's Avatar
Trader Rating: 57 (100%+)
40-47.5 losi oil is normal for me.. higher side w/ the extreme temps lately. Also are you setting the rebound correctly, STD setup w/ bladders I assume? Makes a big difference if not setup well. Can try to change the shock position higher on the tower if it's the track or conditions related.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 08-17-2016, 07:28 PM   #2088
Yea standard setup. I'm almost reAdy to convert it to a 48.2, I don't remember having pushing issues and bottoming out with the .2 lol
Old 08-18-2016, 05:45 AM   #2089
I'm shocked your having bottoming out issues. The .3 is SO much better than my .2, I would never go back.
Post up your setup, and we'll try to get you right.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is online now   Reply With Quote
Old 08-18-2016, 06:34 AM   #2090
Super Moderator
Trader Rating: 17 (100%+)
new shock parts? leaking any fluids? emulsion or bladders? which pistons? Taper up or down?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-18-2016, 06:46 AM   #2091
Trader Rating: 16 (100%+)
Is it bottoming on the take off face of the jumps, or landing? Mine will bottom if I miss the downside on a big jump, but it never bottoms up the takeoff. Unless of course the jump is built way too steep, or has big blown out holes in the face.
MX304 is offline   Reply With Quote
Old 08-18-2016, 07:38 AM   #2092
After looking at it again last night I'm gonna replace the Pistons with new ones. The edges are scuffed up looking and I'm thinking the oil may be seeping around the outside on hard landings.
I should say i don't remember having this issue when I started running it when they first came out. This car has ALLOT of run time on it but is well maintained. I've never worn out Pistons but I will know soon enough. Was just wondering if anyone else had seen this. I believe I started with associated 30 weight and it was good. Now at 50 weight it's still not damped enough so obviously something changed.
And it's slapping on landings. It's just blowing through the dampening. just trying to pin point it
Old 08-18-2016, 09:02 AM   #2093
rregl0612's Avatar
Trader Rating: 33 (100%+)
Make sure you replace your seals and bushings at the bottom, if your pistons worn that means they are letting it get side load rubbing during tansitions..
rregl0612 is offline   Reply With Quote
Old 08-18-2016, 12:30 PM   #2094
Super Moderator
if the shock bodies are really old, they could be worn inside. That's not common, but something to consider
Old 08-18-2016, 02:41 PM   #2095
I was thinking about that but wouldn't you see the anodizing all scratched up? They look perfect inside. Gotta be the Pistons........ I hope
Old 08-18-2016, 03:09 PM   #2096
Suspended
EB48.3, AKA Enduro's (Impact out of stock for awhile), Tekin 1900kv, 2 SMC 6500s, RX8g2, DE skid plates, and Pink/Red springs shipping today! Can't wait to build this beast. Anything else I should invest in now? Next up is a better servo, I have a cheap hitec right now. Is there any oils I should use instead of stock oils?
-Tekno SCT/EB-
deceit is offline   Reply With Quote
Old 08-19-2016, 04:28 AM   #2097
Aluminum servo horn
anr211 is offline   Reply With Quote
Old 08-19-2016, 05:18 AM   #2098
Suspended
Should I use stock oils? Going to use pink/red springs
This is the track I'll be at mostly...
https://youtu.be/jiQtYOqbIu8
https://youtu.be/mrGdkuOx-zA
And occasionally this one.
http://youtu.be/zLBpw1_qG7M
-Tekno SCT/EB-
Old 08-20-2016, 05:42 PM   #2099
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
anyone using the hobbywing XR8? any fitment issues? pics?
RC*PHREAK is offline   Reply With Quote
Old 08-20-2016, 09:32 PM   #2100
everyone swears by PT racing oils and all their pros use that.
caffeine357 is offline   Reply With Quote
