    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 07-10-2016, 03:35 PM   #1936
SLO county race's Avatar
Looking forward to picking up one of these buggies sometime next week. I'm at page 70 so far through the thread and learning lots already.
SLO county race is offline   Reply With Quote
Old 07-11-2016, 05:40 AM   #1937
what position are you guys running the battery in?it seems there is about 10-15 mm that the battery can be used in either direction.im struggling to get a planted feel with this buggy so far.ive tried the box setup and joes snats..it never feels like it has really good grip.ive tried several tires and only get marginal improvement.
hanker39 is offline   Reply With Quote
Old 07-11-2016, 06:05 AM   #1938
Trader Rating: 34 (100%+)
I run my battery all the way back and it felt alittle different but nothing eye opening.
GettinLapped is offline   Reply With Quote
Old 07-11-2016, 08:50 PM   #1939
Default tini coated shock shafts
Are the tini. Coated shock shafts stronger then the none coated ones? Is it the same steel shaft with a coating?
proliteandsc is offline   Reply With Quote
Old 07-12-2016, 06:20 AM   #1940
Super Moderator
Trader Rating: 17 (100%+)
I'm not sure that they are tons stronger, but when coupled with the delrin inserts, they are considerably smoother.
I will tell you that it's a good idea to keep a spare set of shock shafts on hand. I've bent 1 front shaft between my EB and NB this summer and it was on a horrific crash.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 07-12-2016, 02:15 PM   #1941
justpoet's Avatar
Trader Rating: 16 (100%+)
While this may be a bit stiff in spring/oil for your track if it is rough, give this a shot if you've been working with the other pro setups and just can't get a handle on rear traction. I've often had people tell me it is the easiest to drive buggy they've ever tried. Obviously use appropriate tires for your track. I ran this setup mostly on medium traction.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 07-16-2016, 02:06 AM   #1942
werner sline's Avatar
awesome tailwhip with a eb48.3, really extrem, very nice driving there !
+ YouTube Video
werner's bunch of 1/8 RC freestyle tricks NEW video : werner's home made rigid axle monster truck : bashing, jumping, crashing, welding, hitting the driver, double flip !
check it out : https://www.youtube.com/watch?v=WpAlaTrpNa0
werner sline is offline   Reply With Quote
Old 07-16-2016, 11:41 AM   #1943
DRJVogel's Avatar
Yes! That was truly awesome! Wow! Watch out Slo-Mo Guys!
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 07-19-2016, 05:06 AM   #1944
mxrcracer23's Avatar
Finally got the buggy built and on the track this weekend. I used the wicked weekend nb setup and was very impressed with the car, it was extremely stable through every section of the track. I changed to a JC hybrid wing which seemed to give it good rotation in tight turns. The only thing the car seemed to lack was forward bite. I will be looking at wheelbase and diff adjustments next time out
mxrcracer23 is offline   Reply With Quote
Old 07-20-2016, 01:18 PM   #1945
Default Turn on power?
Got my car to turn nice in off power tight turns, but pushes bad on wide turn. Anyone have any suggestions how I can get it around wide turns without compromising it's tight turns and jump ability?
Old 07-20-2016, 01:30 PM   #1946
Super Moderator
We really can't give suggestions without knowing the entire setup, track surface, tires, etc. Best thing I can tell you is show us a quick vid of the track and link your setup. Then we can offer advice.
OR just put Joe's Southern Nats setup on your car with some Blue Reflexs or Blue Triple Dees on your car and be dialed
Old 07-20-2016, 04:24 PM   #1947
Stubbs's Avatar
Trader Rating: 57 (100%+)
Maybe it's just mine and my buddy's 43 year old, slow-arse reflexes, but we both found Joe's setup very twitchy, and difficult to drive consistently.
We went back to the box set up, and did a little tweaking from there, and it's much better for us "old guys".
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 07-20-2016, 04:51 PM   #1948
DRJVogel's Avatar
Originally Posted by Stubbs View Post
Maybe it's just mine and my buddy's ... slow-arse reflexes ... us "old guys".
I resemble that remark!
Old 07-21-2016, 07:34 AM   #1949
Haha...can't be. I'm 42 and I love his setup...lol. I do have a ton on expo on my steering (M12 - 60%), but I'm also running a protek 150t servo.
Seriously, yeah posting your current setup sheet will probably be the best way to get help.
qstorm777 is offline   Reply With Quote
Old 07-21-2016, 02:05 PM   #1950
I started with Joes Southern Nats and made a few changes.
Front arm shock mount is A.
2mm rear wheel offset.
Front shock 32.5 AE
Rear shock 37.5 AE
Diff 7,10,3 AE
Track is outside smedium dusty hard packed clay, sometimes wet. I guess about medium grip.
I tried calibers, subcultures, hole shots, crime fighters, sweeps, all about half worn.
I did notice the servo saver could be made tighter. That might help. I'll try that next time I race.
Anyone have any ideas what I need to change to get this car around wide turns? It pushes when turning on power.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
