    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 07-03-2016, 10:08 AM   #1906
Trader Rating: 16 (100%+)
Originally Posted by JOELD View Post
I as well have this problem, did the pink springs come with the kit?
The Bornhorst setup uses pink front springs, not the black. With the black springs I can get 28mm of front ride height with the spring adjuster all the way down to the bottom of the threads. With the stiffer pink springs, the adjusters sit about 3-4mm further up the threads for the same ride height.
MX304 is offline   Reply With Quote
Old 07-03-2016, 10:42 AM   #1907
https://www.amainhobbies.com/tekno-r...kr6090/p274871
those juans?
JOELD is offline   Reply With Quote
Old 07-03-2016, 11:08 AM   #1908
Those are longer for the Truggy you need these ones for the buggy
https://www.amainhobbies.com/tekno-rc-70mm-front-shock-spring-set-pink-1.5-x-9.0t-2-tkr6035/p231833
crash n go is offline   Reply With Quote
Old 07-03-2016, 03:25 PM   #1909
I run 7-5-3 on my low grip dirt track as do all the fast guys using Mugen diff fluid.
What does PT diff oils stand for?
Slashn77 is offline   Reply With Quote
Old 07-03-2016, 04:59 PM   #1910
mkl
PT Oils are a brand of oil. They sell both diff and shock oil.
http://www.ptrcracing.com
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 07-03-2016, 06:34 PM   #1911
PT racing oil. It's thinner than most other brands so take that into account. For example 7-7-3 in PT oil is closer to 10-10-5 in AE oil.
Old 07-03-2016, 07:45 PM   #1912
8ight-e's Avatar
Trader Rating: 57 (100%+)
anyone have some time in w/ the universals? Seems like it will be a lot harder to clean with the inner bearing so far in the hub, leaving a lot more space for build up? Or does it stay pretty clear/clean?
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 07-04-2016, 05:59 AM   #1913
mxrcracer23's Avatar
Thinking of ordering a eb48.3, I was set on an eb48sl but I am leaning towards the .3 now. I am new to electric other than a 410.3 I just bought for the kids but I have kinda taken over. I was gonna go with the eb48sl so I could stay with the 2s batteries I had for the 410.3 but it seems as though a 4s system is the way to go with a buggy. My question is, will a hobbywing sct pro combo with the 2250 motor be enough to power a full sized 48.3. I will probably be ordering everything from fierce rc is the reason I'm curious about this combo
mxrcracer23 is offline   Reply With Quote
Old 07-04-2016, 07:26 AM   #1914
On 4S buggy systems, most will run the XR8 and a 1900 to 2100 motor.
qstorm777 is offline   Reply With Quote
Old 07-04-2016, 07:28 AM   #1915
PT told me Mugen visosity is about the same as theirs. However, I just runt the PT so I know I'm comparing apples to apples when looking at the team setups.
Old 07-04-2016, 07:55 AM   #1916
couple months and they seem fine, the bearing is deeper in the carrier so its protected better from the elements. I blew out at least four outer bearings in half the time ive ran since the swap, tekno did seem to have a bad run of bearings but to me it is better
Old 07-05-2016, 04:41 PM   #1917
Default oil question
I read AE oil is about 2k heavier then ptrc. How does mugen, ofna, and losi oil compare to ptrc?
proliteandsc is offline   Reply With Quote
Old 07-05-2016, 06:31 PM   #1918
Default Another oil question
Anyone know what the ptrc shock oil wt is equal to in AE, mugen, ofna, and losi. My LHS doesn't sell ptrc oil. They sell AE mugen ofna losi and kyosho.
Old 07-06-2016, 08:16 AM   #1919
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
PT racing has a conversion chart on there site showing how Losi oil compares to there stuff.
May have your LHS order some for you?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 07-06-2016, 08:39 AM   #1920
Super Moderator
Trader Rating: 17 (100%+)
LutzRC has PT Oils
http://lutzinator.com/lutzrc/cart/in...k1n5fja3mp8of4
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
