    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 06-24-2016, 10:27 AM   #1861
Don't know if this was addressed before. Has anyone used the 2mm offset wheel hubs yet? How would they affect a cars setup?
proliteandsc is offline   Reply With Quote
Old 06-25-2016, 11:08 AM   #1862
Cuebulon's Avatar
With the stock Tekno body or any body for that matter does anyone know what motor fan to use? It gets rather hot where I race so I have to gear and tune according, but I feel like that would help out as well.
Cuebulon is offline   Reply With Quote
Old 06-25-2016, 12:52 PM   #1863
DRJVogel's Avatar
Just read the Wiki. Thanks to the one who started it and it's contributors.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 06-25-2016, 07:30 PM   #1864
Has any one try 15/15/5 in diff oils to settle the rear end down and make it more stable
coombes is offline   Reply With Quote
Old 06-26-2016, 05:47 AM   #1865
Changing my rear links to #2 on tower and D on hub carrier with 0 camber helped me get more control last race and now have changed to 10,7,5 diff. Hopefully this will help bring it into control for my driving..
RcJunky76 is offline   Reply With Quote
Old 06-26-2016, 11:02 AM   #1866
Trader Rating: 16 (100%+)
I run a Tekin RX8 / 1900kv motor combo with a 19t pinion. I don't run a fan on the esc or the motor and can run 10 minute mains in 100+ deg weather with no temp issues. I don't even have cooling holes cut in the body.
MX304 is offline   Reply With Quote
Old 06-26-2016, 11:39 AM   #1867
I run the exact same setup....no issues with heat
weedsnager is offline   Reply With Quote
Old 06-26-2016, 12:43 PM   #1868
Cuebulon's Avatar
I run a Tekin rx8 gen2/ gen 1 2050kv and a 17 tooth. I hit about 160 on hot days.
Old 06-27-2016, 07:14 AM   #1869
justpoet's Avatar
That's a perfectly ok temp. Worry when you get closer to 200 at the end of a 10 minute run, then look for binding in places.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 06-27-2016, 08:19 AM   #1870
Numburn's Avatar
I used them on the .2, but haven't played with them on the .3 at all. The concept is pretty straightforward. The wider the car is the more stable it will be at the cost of traction. So if you put the +2 hubs on it will slide around the corners more, but be more predictable and controllable. Where it really comes in handy is making one end of your car wider than the other.
-Kevin McCoy
Tekno RC | Pro-Line Racing | Castle Creations | 92zero Designs
Numburn is offline   Reply With Quote
Old 06-27-2016, 11:55 AM   #1871
Ruffdog1's Avatar
Is it worth spending the money on TiNi shock shafts? Is there a noticeable difference in smoothness? My stock shafts are pretty dang smooth already
Ruffdog1 is offline   Reply With Quote
Old 06-27-2016, 11:58 AM   #1872
Not really. The stock shafts are really good, even better if you polish them. The Delrin bushings make a bigger difference than anything.
Old 06-27-2016, 12:31 PM   #1873
Ruffdog1's Avatar
Thanks!!
Old 06-27-2016, 03:28 PM   #1874
Thanks!!
When the upper shock eye bushings wear out, which will be almost instantly, grab a set of the M2C delrin bushings. You'll get a lot more life out of them too.
Old 06-27-2016, 03:28 PM   #1875
I agree the best option is the delrin bushings if I had to choose one or the other.but I did both at the same time
tlrky is offline   Reply With Quote
