    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 05-30-2016, 12:09 AM   #1726
werner sline's Avatar
Originally Posted by NoobRacer View Post
I went back into my esc and changed the limiter back to 80 and adjusted my throttle curve on my mt4s. Now she accels smooth as butter. I forgot I ha it set up for my eb48sl that was on 3s.
great. 6s is cool with the good esc. I used a very basic esc, that's why I didn't get the best of a 6s setup for controlled 1/8 buggy driving
werner's bunch of 1/8 RC freestyle tricks NEW video : TRUGGY tricktionary, part 2: 14 tricks
check it out : https://www.youtube.com/watch?v=5PVrXfs5TG8 6s power !
werner sline is offline   Reply With Quote
Old 05-30-2016, 08:32 AM   #1727
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
anyone running the hobbywing xr8 plus? if so, how do you like it compared to the tekin rx8?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 05-30-2016, 10:28 AM   #1728
Shawn_S's Avatar
Trader Rating: 18 (100%+)
I like the XR8 a lot. I ran an RX8 first, then a Viper VTX8, and now an XR8. To me, it's the perfect combination between the two. The VTX8 was soo smooth, but really lacked the power of the RX8. The XR8 is very smooth as well, but packs lots of punch. It does run a slight tick warm, not anywhere near the Viper though.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 05-30-2016, 11:15 AM   #1729
thanks for your input. I bought a used car and it has the SCT pro in it.. thinking of changing to the xr8 or the tekin.. I use a hobbywing in my tc and really like it so thinking if sticking with them..
Old 05-30-2016, 01:48 PM   #1730
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I'll throw this out there as another option, the Castle MM-X works excellent and is waterproof. I have been quite impressed by it.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-30-2016, 02:00 PM   #1731
hmm, I'll look into that.
another question, are there carbon shock towers for this car?
Old 05-30-2016, 04:56 PM   #1732
No carbon towers.
turtle189 is offline   Reply With Quote
Old 05-30-2016, 05:30 PM   #1733
I've no issues with my XR8 and it definitely feels smoother than my friends RX8 both paired with the SMC 1900. I do wish it had a built in switch but it's not a deal breaker...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 05-30-2016, 06:06 PM   #1734
Originally Posted by turtle189 View Post
No carbon towers.
well shoot.. guess i'll see about having some made.
Old 05-30-2016, 06:06 PM   #1735
good info, thanks!
Old 05-31-2016, 06:31 AM   #1736
Numburn's Avatar
Originally Posted by McKeown View Post
Does anyone have a Mamba Monster X esc installed in there buggy? I'm wondering how fitment is?
Thank you
I have been running one. It's fairly large but fits fine. There is a little gap between center brace and side guard and plenty of room for the sensor wire. It is a very good ESC, smoother than Tekin. I'm just not a fan of all the wires hanging off of it.
I'm currently testing the REDS TXX ESC and have been very impressed by it. Once we verify the kinks are worked out this will be what you want. It's a clean setup and feels great on the track.
-Kevin McCoy
Tekno RC | Pro-Line Racing | Castle Creations | 92zero Designs
Numburn is offline   Reply With Quote
Old 05-31-2016, 12:41 PM   #1737
anyone else refresh the tracking page on the UPS website? patiently waiting...
Old 06-02-2016, 11:14 AM   #1738
let the building commence.. hope to drive it saturday
Old 06-02-2016, 11:15 AM   #1739
Enjoy!
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 06-02-2016, 12:47 PM   #1740
Trader Rating: 22 (100%+)
Almost finished with mine. Just need to build the shocks and install electronics. It's a nice piece of kit for sure. Every step has it's own bag which I love. Only issue I had was a incorrectly machined and bent screw. Shot an email to Tekno and they are sending me replacements. Everything went smoothly until I got to the turnbuckles. Man those turnbuckles are a #$%^&^ pain to do by hand. If you have a drill use it. Your hands will thank you.
littleZEN is offline   Reply With Quote
