Tekno RC EB48.3 Thread
#1577
So where are we at w/ a solid setup on this buggy for a hard pack dirt track.. LCRC CRC etc.. how many people are using the diff spacer to lift it up off the chassis, any top level guys or just guys messing around?
#1578
The top level guys are the ones that came up with the diff spacer I believe.
#1581
Obviously I can't speak for Matt or any of the other Tekno employees, but pretty much the entire team runs them. I haven't asked Joe or Ryan if they do still, but they were the ones who tested it and came up with it. I run it on both NB and EB.
#1582
I have the new 3 hole pistons on the way. If you try them, just remember you need to go up aproximately 200cst oil from the kit pistons for your starting point. So if you run 400/450, start with 600/650 and then adjust from there.
#1585
http://www.teknorc.com/wp-content/up...0Bumpy_Dry.pdf
http://www.teknorc.com/wp-content/up...ern%20Nats.pdf
#1586
pretty much narrowed it down to the EB48.3 buggy. If and when I place my order I'd like to throw a couple pinions in there for tuning. Going to run the CC MM2 2200kv on 4s 5000mAh 50C, track is fast but the turns are tight and theres a few doubles and a triple, like to able to have the nuts to clear the triple and zip out of the corners, any suggestions?
#1587
#1588
#1590
