    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 07-29-2015, 04:28 PM   #136
Originally Posted by coombes View Post
hey rav were did you race with it what stock oil did you used and diff oils mate so you say it worth getting one now since they fix the rear end lose and all
I was running at Liverpool. All oil's were stock (5/5/5 and 400/450? shock oil is from memory).
I never really found the rear to be a problem with the old car after I took out the centre and rear brace.
revhead145 is offline   Reply With Quote
Old 07-29-2015, 09:46 PM   #137
how does that work I thought you need to used them for the car
coombes is offline   Reply With Quote
Old 07-30-2015, 04:51 AM   #138
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
I never run the rear brace, and sometimes I take out the center too. It provides a little more flex in the chassis = more grip.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 07-30-2015, 04:59 AM   #139
oh I see so same thing go to the sct410 if you want more grip to am I right
Old 07-30-2015, 06:26 AM   #140
MOE
MOE's Avatar
Yes
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Old 07-30-2015, 09:54 AM   #141
Default Serpent Comparison
Has anyone driven the Eb48 vs the Serpent 811e? If so, can you tell me how they compare?
Thanks.
qstorm777 is offline   Reply With Quote
Old 07-30-2015, 03:12 PM   #142
thanks moe any think you change since you got yours
Old 07-31-2015, 01:00 PM   #143
Just finished my build and was doing pre-checks before first run in the garage and noticed binding in the steering. I noticed the steering turnbuckle screw was sticking out about 2mm or so from the nut and rubbing on the A-arm. Both sides were having this problem. I ended up taking the screws out and dremeling them down about 2mm and the problem was solved but just curious if maybe i did something wrong or others have experienced the same thing. I did use the 4 washers directly under the screw like the manual instructed, if i would have used 5 it might not have been an issue, but again, the manual only called for 4 on each side. I took it for a test driver afterwards and it's super smooth, powerful, and balanced. I do find the body a bit of a tight fit, but I guess that's probably fairly common for buggies.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 07-31-2015, 03:28 PM   #144
I had the same problem and a friend also had the same problem. It only occurs at full droop. I just took to them with the Dremel. I did the same for the screw on the servo horn or it scratches the body.
Old 07-31-2015, 03:56 PM   #145
yeah, i actually put a rubber tube spacer on the screw that holds the front body mount and raised it up about 5-6mm maybe, so it gives me just a smidge more clearance for everything and still looks stock.
Old 07-31-2015, 06:38 PM   #146
Somehow bent my rear shock shaft. Not sure how..
Riflebuilder is offline   Reply With Quote
Old 07-31-2015, 07:55 PM   #147
Jpm1's Avatar
Piston is upside down aswell, sucks about the shafts though!
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 07-31-2015, 08:53 PM   #148
Trader Rating: 16 (100%+)
Same here. I found a shorter screw and just used one washer.
MX304 is offline   Reply With Quote
Old 08-01-2015, 07:27 AM   #149
RokleM's Avatar
Trader Rating: 33 (100%+)
Correct, this only happens at full droop. If you see signs of it dragging while running the vehicle, you can do the tips above. If you only see it on the bench, I wouldn't be too concerned. This has been around since the original kit and typically is not an issue. Take a little material off the screw, remove washers and shorter screw (if that doesn't change your setup geometry), etc. I just make a slightly run of a dremmel across that section of the arm.
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 08-01-2015, 08:34 AM   #150
CAR
CAR's Avatar
Just turn the bolt around and be done with it.
CAR is offline   Reply With Quote
