    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree25Likes
Old 02-15-2016, 08:14 PM   #1366
TravisS27's Avatar
Trader Rating: 25 (100%+)
My 4 gear SC5M overall handles and drives better than my 3 gear B5MFL and T5M. Better acceleration traction and more rear grip while cornering
TravisS27 is offline   Reply With Quote
Old 02-16-2016, 02:24 AM   #1367
The SC5M has tons of traction already so with the 4 gear it will get even more traction so that makes sense. Have you tried putting the 4 gear in your buggy just so you can see the difference?
Mxer210 is offline   Reply With Quote
Old 02-16-2016, 03:44 AM   #1368
TravisS27's Avatar
I'm going to try it this weekend
Old 02-17-2016, 09:32 AM   #1369
Default my setup sheet - indoor clay
based on Cav's ROAR Nationals setup, with a higher ride height, here is my setup sheet - I think it is a good starting point for indoor damp clay. Will be trying lower ride heights, currently at 28/26
the truck is easy to drive and alot of fun!
-Harry
hsp-sandiego is offline   Reply With Quote
Old 02-17-2016, 09:45 AM   #1370
jstump's Avatar
Send a message via Yahoo to jstump
Default Bodies By Ed Razor for SC5M
Is anyone running it in short course racing? Pro's\Con's?
Team AE RC10SC5M/RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Team AE B5M Lite/RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Team AE B64D/Hobbywing 120a esc/8.5 Hobbywing motor/Savox/Proline/Airtronics MT4
Mugen Mbx7reco 1/8 ebuggy/HW 120a esc/SMC 1900kv motor/Savox/Proline/Airtronics MT4
jstump is offline   Reply With Quote
Old 02-17-2016, 12:41 PM   #1371
celt's Avatar
Default best out of the box?
Not sure who might agree...
Out of all the dozens of kits I've built over the years, the SC5m is the best "build out of the box" experience I've had. By this I mean, build to the manual, with the kit setup, and it's 90% competitive as it sits.
Yeah, you can change out the front spring from white to gray, go up or down half weight in oil, message a few things here or there, but it's pretty solid out of the box.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 02-17-2016, 02:48 PM   #1372
Agreed. Associated really nailed it with their 5-Series. the b5m is equally as dialed. Looking forward to what they come up with for their new 4wd 1/10th scale buggy.
Old 02-17-2016, 04:05 PM   #1373
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Works GREAT on sealed clay off road and >> with RH in the 20-22 range the SC5M even works from the manual as a ON Road racer.
Two of the tracks I race at have a SC class or IF it doesn't fit any other class you race it in GT / Autocross class.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 02-17-2016, 05:39 PM   #1374
Gigasipke's Avatar
So does this make sense? Our indoor track is Ozite and my son's SC5M was setup pretty well for the track. However after experiencing improvement using the 3 gear transmission in my T5M and other people recommending trying it in the SC5M, I went ahead and put one in my sons SC. Well it was horrible. I didn't change anything but going from 4 gear to 3 gear. The problem was that the SC would be snap loose or traction roll. It went from easy to drive with the 4 gear, to a handfull with the 3 gear. SC is open class so he has a 10.5 in it so the difference in acceleration between the two was negligible. After a few batteries and playing with roll center, it still had bad traction roll . So I put the 4 gear back in and it drove easily again. It seem counter intuitive to me that on a high traction surface, with no other changes that the 3 gear would cause such bad drive-ability. My guess would be due to weight transfer and having the big body on the top. The change to the 3 Gear in the T5M was a positive one though. It just seems odd to me, I guess it needed some other adjustments at the same time as the transmission swap.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 02-18-2016, 07:25 AM   #1375
That's pretty interesting, I will have to give this a try on mine the next time I am at the track. Thanks for the information.
WRXnItUp is offline   Reply With Quote
Old 02-18-2016, 08:53 AM   #1376
Trader Rating: 42 (100%+)
Interesting.. I found just the opposite to be true running on a large indoor med/high bite clay. When I went to 3 gear, no more traction rolling, no more ridiculous wheelies, better braking and faster corner speed. The only setup change I did was move the rear hubs forward for 3 gear.
Bartman42 is offline   Reply With Quote
Old 02-18-2016, 09:04 AM   #1377
My 3 gear SC5m is hooked up - Question: what ride height are you running with in your setup? If traction rolling is a issue, it may be too high.
Old 02-18-2016, 05:58 PM   #1378
I took my new (to me) SC5M out to the track for the fist time yesterday. I threw my electronics in it but otherwise took it as it was delivered having only set the camber and ride height. I have to say that I was quite impressed. The truck by far exceeded my expectations. My tires were not even close to ideal, the front springs were probably one step on the soft side and I have no idea what pistons or oil is in the shocks yet it was still smooth and reacted well to my inputs. I'm looking forward to racing this thing on Sunday with the right tires and after having setup the shocks with some fresh oil.
afm223 is offline   Reply With Quote
Old 02-18-2016, 09:39 PM   #1379
i got mine "used" here - 3 gear, Ti turnbuckles, Electrons, etc... did a fresh JC HF2 body - pretty dialed for parts, but re-built it based on cav's ROAR nats setup and with tekin / 8.5 setup, with focus on buggy only for the past years and am loving driving sct 2wd with this truck. it's a blast. btw, i posted my setup here a page or so back - running 37.5/30 with 1.6/1.7 flat two-hole pistons, 28/26 ride height. 5mm offset cups. nothing crazy, but a tight setup
Old 02-18-2016, 09:59 PM   #1380
Trader Rating: 485 (100%+)
I have one with a 3 gear and one with a 4. I've found the truck is very sensitive to battery, springs, and the rear roll center. Regardless of the trans configuration it seems like if you don't get the springs and rear links set up properly its total poop with either configuration. Because of the width and and wheelbase its pretty easy to push the truck hard once its set up right. Its crazy to use a pro set up unless you drive like a pro. The only one set up tip that I have for anybody is run the grey front springs if you have any traction at all. The stock whites are too soft.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
