    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree28Likes
Old 12-21-2015, 04:52 PM   #1201
slashman404's Avatar
Default Gearing?
Originally Posted by Cridd View Post
I'm using the SS version and like it.
Thanks for the reply so what pinion/spur are you running? Thanks!!!
Wild Bills Hobbies
BlueGroove Hobbies
Team Holy Rollers- John 3:16
slashman404 is offline   Reply With Quote
Old 12-21-2015, 09:29 PM   #1202
Cridd's Avatar
Trader Rating: 16 (100%+)
Running close to what the manual suggested with ratio. Funny thing is the book has the ratio at 7.24 but really is 7.5 if you calculate it. I finished up at 7.6, 76/26. I go up and down from there depending on track.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-21-2015, 09:40 PM   #1203
bubbaslash's Avatar
Originally Posted by mblgjr View Post
3deg antisquat is definitely too much.
The AE mid platforms seem happy 99% of the time running 1* as it makes the rear end sit down off the corner.
I've tried 2* in various traction conditions and generally it stiffens the rear under compression a noticeable amount, to the point you can get more mid-exit steering if you need it, but also makes the vehicle launch differently off the jump.
1 just seems to be the sweet spot most of the time.
Thank you for the reply. I'm pretty sure I'm on the right track now. That will give us one less thing to sort out when we hit the track. Then i can concentrate on gearing to the new track configuration. We started the build before the SC5M came out, when the only MM SCTs were the Losi and X-Factory, which are 4-gear. It's kind of a blessing that the new truck is out, and people are using the 3-gear in it. This gives us a rough baseline to work from. My youngest son did all of the cutting, drilling and assembly, with the exception of building the shocks and transmission. I had already put them together from a myriad of components from several manufacturers. He's a quick learner for 10 years old, and this hobby is teaching him skills that will help him later in life
X-Factory SCX-61....the ultimate multi-surface missile!
Made in USA!
bubbaslash is offline   Reply With Quote
Old 12-21-2015, 10:13 PM   #1204
bubbaslash's Avatar
Originally Posted by Scottysspeedsho View Post
[ATTACH]1335690[/ATTACH
jconcepts does not make or have any parts for the old SC10 swaybar.I found one from my old truck and modified it for the SC5M and yes it made a world of difference.
I couldn't make out the diameter of your front bar. Is it 1.0 mm? And what kind of track surface are you running on?
Made in USA!
Old 12-22-2015, 08:27 AM   #1205
Sorry for dumb question if already posted. I have been out of it awhile so bear with me. Are folks also using the SS 17.5 D4 in the SC5M or are they mostly using the non SS version? Thanks.
I'm running a Certified 17.5 D4 SS and absolutely love it
Dyechainsaw10 is offline   Reply With Quote
Old 12-24-2015, 09:29 AM   #1206
twindad98's Avatar
I noticed Cavalieri is using the white Xgear rear springs. Is the xgear spring softer or harder than the kit rear spring?
twindad98 is offline   Reply With Quote
Old 12-24-2015, 09:36 AM   #1207
1M
1M's Avatar
Trader Rating: 35 (100%+)
I go to the AE site, parts and accessories for the SC5M looking for front springs. Listed as medium # 91435, BUGGY springs listed on the parts page of the SC5M.
Any one know the correct part # for the SC5M font springs?
1M is offline   Reply With Quote
Old 12-24-2015, 10:25 AM   #1208
celt's Avatar
Green Front 3.75lbs. #91635
White Front 4.10 lbs. #91636
Gray Front 4.45lbs. #91637
These are documented all over the place...best place to start.
https://www.teamassociated.com/cars_...s_accessories/
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 12-24-2015, 10:41 AM   #1209
1M
1M's Avatar
Is White Front 4.10 lbs. #91636 the stock spring?
Old 12-24-2015, 10:52 AM   #1210
celt's Avatar
Yes...white front and rear.
Page 15 in the manual...
Stan Garvin
Old 12-24-2015, 10:56 AM   #1211
1M
1M's Avatar
Thank you
Old 12-24-2015, 11:19 AM   #1212
Just going to invest into some aibrush equip and sorting out on which bodys I could train:
Would this body fit nicely?
http://rc.michaelwuttke.de/RC-Zubeho...e=1&referid=65
(Any kind of performance issue that may occur? (Air Flow or something like this?)
man1ac is offline   Reply With Quote
Old 12-24-2015, 12:20 PM   #1213
Gpeters66's Avatar
That body will fit nicely.....make sure you check out the rear body mount holes before you paint and make sure you pick the right ones. This body is meant for other truck models so I would just check to make sure.
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 12-24-2015, 02:37 PM   #1214
jakeb's Avatar
Does anyone happen to know what body the kit comes with? I'm trying to find a replacement body and I don't really like the options I see out there.
I like the factory one.
jakeb is offline   Reply With Quote
Old 12-24-2015, 03:01 PM   #1215
I am using the smallest one I will check the size. I run on hi bite clay and Astro turf.
Scottysspeedsho is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
[email protected]
