    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree27Likes
Old 12-18-2015, 03:17 PM   #1186
bubbaslash's Avatar
OK, I don't have an SC5M, but I built a midmotor mutt with my son that started with a Chuckworks Slice A6 chassis, and all aftermarket (for Slash, Rustler and SC10) parts. He will be moving up from novice to 17.5 SCT this year. We are putting the finishing touches on it for this season. He runs low grip indoor clay in low temps. The truck is a 3-gear with .85 mm front swaybar, gear diff, shocks built to bypass on rebound, sideways mounted battery, and homemade rear roll-center and anti-squat adjustment via separate toe blocks that can be shimmed up and down, or angled. The truck has plenty of steering. Oversteer and forward bite are my two biggest concerns right now. I figure on running the roll center on the rear as low as i can, but any suggestions for anti-squat? initial setup is 3 degrees. wondering if i should reduce it to aid in weight transfer out of the corners? Sorry, I don't have any scales to check corner weights
X-Factory SCX-61....the ultimate multi-surface missile!
Made in USA!
bubbaslash is offline   Reply With Quote
Old 12-18-2015, 03:26 PM   #1187
bubbaslash's Avatar
PS...I'm a builder, not a driver. But I hope the SC5M helps to bring 2wd SCT back to its former popularity. Sometimes the club where we race doesn't even have a B main any more. I like trucks, but buggies seem to be dominating the club racing scene around here lately
Made in USA!
Old 12-18-2015, 11:57 PM   #1188
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by RC Tommy60 View Post
Ok to the Great Minds here on this Forum. I just built my first kit a SC5M. My Question is how do I know if I have the Diff screw tight or loose enough for the rear end. Something just does not feel rt in the back end after I put on the Slipper. HELP Please.
Go to the first pages of the B5m page and it shows videos on diff and slipper.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-19-2015, 09:12 AM   #1189
Jpdanger's Avatar
Tighten the diff screw until it is tight, but don't wrench down on it. Then unscrew the diff screw an 1/8th of a turn. That is it. This is how I've been setting up my diffs forever. Periodically, check the tightness because it will slightly loosen as the diff breaks-in.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-19-2015, 10:51 AM   #1190
Thankyou very much JPdanger for getting back to me on my diff. I will try that tonite.
RC Tommy60 is offline   Reply With Quote
Old 12-19-2015, 02:31 PM   #1191
Originally Posted by Scottysspeedsho View Post
[ATTACH]1335690[/ATTACH
jconcepts does not make or have any parts for the old SC10 swaybar.I found one from my old truck and modified it for the SC5M and yes it made a world of difference.
What did you use for parts?
Newbie Rc Guy is offline   Reply With Quote
Old 12-19-2015, 06:10 PM   #1192
Default TLR Wheels
What is the offset difference if you use TLR 22 SCT 2.0 wheels? The only answer I have seen is that it is different.
"Can't Bust 'Em"
TLR 22, Speed Passion Reventon Pro, Spektrum SR3100, Spektrum DX3R
TLR 22SCT, Tekin RS Pro' Spektrum SR3100
TLR 22T, Tekin RS Pro, Spektrum SR3100
BuddyLee303 is offline   Reply With Quote
Old 12-19-2015, 07:47 PM   #1193
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
3mm per side. The Losi is a 0 offset and the SC5M can run a +3mm offset rim to reach max ROAR width.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-20-2015, 10:24 AM   #1194
I had a old Jconcepts SC10 sway bar that I retrofit to the SC5.
Scottysspeedsho is offline   Reply With Quote
Old 12-20-2015, 10:32 AM   #1195
biggen's Avatar
The stock associated wheels are zero offset and the losi wheel works fine on this truck
FATBOY RACING
Soar Seki 998 td1
Dialed Rc Hobbies
biggen is offline   Reply With Quote
Old 12-20-2015, 03:42 PM   #1196
Trader Rating: 42 (100%+)
I didn't prefer 3 Gear, hero lap was 29.8. I swapt back to 4 gear and immediately ran 28.5. In all fairness the track was drier than normal and 3 gear just didn't have the acceleration. I haven't given up on it yet. The next time the track has lots of moisture I'll give it a try.
Here's the results from today's club race. The top 4 are SC5Ms
Bartman42 is offline   Reply With Quote
Old 12-21-2015, 10:03 AM   #1197
bubbaslash's Avatar
Sorry for hijacking the SC5M thread, but my son's homebuilt is probably closest in configuration to it. Seems like all the TLR guys are using 2 degrees anti squat on the MM 22SCT on low-bite tracks, whereas the AE guys are running 1 degree. Since we're running a 3-gear, I'm thinking I need to shim 2 degrees of anti squat out of it. We built it with 3 degrees.
Made in USA!
Old 12-21-2015, 12:52 PM   #1198
slashman404's Avatar
Default D4 17.5 SS
Sorry for dumb question if already posted. I have been out of it awhile so bear with me. Are folks also using the SS 17.5 D4 in the SC5M or are they mostly using the non SS version? Thanks.
Wild Bills Hobbies
BlueGroove Hobbies
Team Holy Rollers- John 3:16
slashman404 is offline   Reply With Quote
Old 12-21-2015, 12:55 PM   #1199
mblgjr's Avatar
Trader Rating: 86 (100%+)
3deg antisquat is definitely too much.
The AE mid platforms seem happy 99% of the time running 1* as it makes the rear end sit down off the corner.
I've tried 2* in various traction conditions and generally it stiffens the rear under compression a noticeable amount, to the point you can get more mid-exit steering if you need it, but also makes the vehicle launch differently off the jump.
1 just seems to be the sweet spot most of the time.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 12-21-2015, 02:42 PM   #1200
Cridd's Avatar
I'm using the SS version and like it.
Chris
B6D / T5M / SC5M
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
