    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 11-30-2015, 09:12 AM   #1141
Originally Posted by vfrninja View Post
If it's really high bite lower your ride height . This does wonders for the truck. Also the 3 gear really helps. I'm at 35wt up front with the 1.5 pistons.
How much lower ride height do you recommend?
WRXnItUp is offline   Reply With Quote
Old 11-30-2015, 03:31 PM   #1142
I'm running on carpet and my ride height is sitting at 23mm. But part of it depends on the jumps you are dealing with. You may have to raise it if it's casing the jumps.
Bdawg01 is offline   Reply With Quote
Old 11-30-2015, 07:26 PM   #1143
I'm on super high traction carpet.
The truck feels amazing right now with this setup:
All the way up to 45 weight oil in the front and 40 in the back. 1.6 pistons. Lots of limiters; enough that with the zero mm spring retainers the springs are not loose at full droop with the collars all the way up.
3 gear transmission
rear camber mount at -2mm position
-3 degrees camber
Pinpoints front and back with 2 rows of outside pins cut off
square pack towards back
Grey front, white rear springs
short wheel base
stiff rear roll bar
Ride height is only about 17mm. It's a carpet scraper, but the heavier oil stops it from bottoming out (too much). Most of the setup is to stop traction rolling while not pushing through the corners. It also jumps perfectly flat.
islandscott is offline   Reply With Quote
Old 12-01-2015, 06:46 AM   #1144
dirt42fan's Avatar
Trader Rating: 135 (100%+)
Originally Posted by 1/4milecrazy View Post
Ditch the 3 gear. I am about to do it even in my 17.5 car.
Im curious, why do you say to ditch the 3 gear?
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 12-01-2015, 07:23 AM   #1145
MadMax1996's Avatar
Trader Rating: 22 (100%+)
So - did anyone notice that the SC5m was out of stock on the Team Associated site until AFTER the big Cyber Monday sale? 20% off and free shipping would have been nice. How convenient that it's back in stock first thing Tuesday morning.
I got mine coming from SpeedRC.com because they had a $40 off code (and free shipping). Hopefully I'll have it in a few days.
FT SC10 - SC5m - FT TC7 - Slash 2WD LCG - Slash 4x4 Platinum - Summit
MadMax1996 is offline   Reply With Quote
Old 12-01-2015, 02:17 PM   #1146
Has anyone else found that this truck needs lots of rear camber?
For outdoor racing I found I needed -3.5
I have tried lowering it to -2.5 for indoor but I'm going try -3 again. It's getting a little more tail happy mid corner then I prefer.
From looking at rear tire wear, it's rolling over on the outside edge more than it should.
zimmon is offline   Reply With Quote
Old 12-01-2015, 07:53 PM   #1147
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I don't use static camber to deal with that. I adjust roll centers front and rear, either with link length or mounting height. One of the other things I have found is that uneven tire wear is NOT ALWAYS the best method of determining whether your rear end us setup correctly. At times it is, but not always.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-02-2015, 09:09 AM   #1148
Are you talking about running a high roll center to get more camber gain, instead of using more static camber?
Old 12-02-2015, 09:22 AM   #1149
Jim Hustins's Avatar
Roll center is how you create chassis roll or eliminate chassis roll. Allowing your chassis to roll over in low bite conditions will transfer weight to the outside tires and increase grip. Chassis roll in high bite conditions will make you traction roll.
I owe it all to Papa Lou.
Team Driver: Pro-Line, Maclan Racing, Xpert Servos, RC Soup, MIP, ARC
http://www.prolineracing.com/blog/team/jim-hustins/
http://www.youtube.com/user/jjlove1217?feature=mhee
https://www.facebook.com/jim.hustins.rc.racer
Jim Hustins is offline   Reply With Quote
Old 12-02-2015, 09:27 AM   #1150
This is the best video that made it click for me. What sounds strange is a high roll center is actually less chassis roll. A low roll center is more chassis roll.
http://youtu.be/tWdRQaz_Xq8
Old 12-03-2015, 04:52 AM   #1151
Hasi's Avatar
Didn't notice that but sice I'm living in Germany that hadn't been an option for me because of the taxes.
What I'm more worried about is that AE and/or Thundertiger seem to have miscalculated the christmas trade... no SC5M available in Germany and my hobby shop says it's not available until 21st january which is very reliable normally. Sucks
Even the gear diff #91461 isn't available until 4th february... ordered that in september...
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 12-03-2015, 10:38 PM   #1152
*wave* Hasi
As I told you before, get the Diff in Austria, took 4 days to get to me and payed 4$ more than in other shops. Problem solved
If you think of buying at sequoia here, he lists way shorter delivery times, but as I can tell you first hand:
I ordered some tires for my SC5M and he said: Tops 2 days and I got the other tires. Summarized: Took him 6 working days to get them, and two to ship
You should abandon the idea of builing a SC5M under the chirstmas tree
man1ac is offline   Reply With Quote
Old 12-06-2015, 10:49 AM   #1153
MNiceGuy's Avatar
Just picked up an SC5M which is also my first Associated vehicle. When installing the servo as recommended I noticed the link was hitting my servo (a Spektrum 6040). I took out the 1mm spacer from behind the ball stud it seems to clear but just barely.
Anyone else run into this?
MNiceGuy is offline   Reply With Quote
Old 12-06-2015, 03:37 PM   #1154
Fyrmed2's Avatar
Yes no spacer required. I've used reedy and spektrum.
Hobby Town USA - Lake in the Hills
Timewarp Raceway
IAFF Local 2392
Fyrmed2 is offline   Reply With Quote
Old 12-06-2015, 05:27 PM   #1155
joeld2llio's Avatar
Did the same with my B5M and T5M. No problems.
B6 - B6D - B64D - T5M - DEX410v5
joeld2llio is offline   Reply With Quote
