    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 10-06-2015, 08:01 PM   #901
a1
Originally Posted by dpcardoza View Post
I thin foam behind the battery
moving the battery forward might help some.
a1 is offline   Reply With Quote
Old 10-06-2015, 08:42 PM   #902
So I'm building my kit and bought the Schelle rear hubs to go on it. The stock 10mm ballstud is 4mm too tall for the hub without using spacers. It looks like the B5m used 6mm ballstuds and those should fit better.
Just an FYI to anyone else looking to use these hubs on the SC5m.
WRXnItUp is offline   Reply With Quote
Old 10-06-2015, 10:08 PM   #903
Thanks for the replies guys.. I have the 5mm cups on it now. And I changed the front springs to grey and the rear to xgear white.. Works great and I got the height down to 28 after running a few packs. I also have a bad push off power.. My batt is fully froward already. Any other suggestions? Is anyone using the reedy square pack? I have one and thought about trying it.
Polock is offline   Reply With Quote
Old 10-07-2015, 04:30 PM   #904
shadowracer24's Avatar
What I did on mine was put the 15g aluminum 30 degree front hinge block on and have all kinds of steering. Actually to much in some tight corners. I roll outta the throttle a little bit going into the corners and it just hangs right on line. If I lift completely off the front hooks very aggressively. Don't know if this would work in your situation but love how it makes mine react. Everything else is box stock setup using saddle packs but wanting to try a brick pack. Shorty made the front grip way to twitchy. Hope this helps.
shadowracer24 is offline   Reply With Quote
Old 10-09-2015, 06:03 PM   #905
1M
1M's Avatar
Trader Rating: 35 (100%+)
Any one use AE 91383 Aluminum Arm mount (c)? How did you mount it?
Recessed on top side but a nut will not fit in,
Part I have, not sure what this one I have fits.
1M is offline   Reply With Quote
Old 10-09-2015, 06:55 PM   #906
cbass722's Avatar
I'm building my kit and in the instructions it says install the diff with the head of the diff thrust bolt opposite of the spur side. does that mean you adjust the diff from the driverside of truck
... FT SC10.2
.... SC5M
..... B44.3
...... BBA RACING
cbass722 is offline   Reply With Quote
Old 10-09-2015, 07:19 PM   #907
Fabulous's Avatar
Trader Rating: 42 (100%+)
There is no need for a nut, just use locktight on the screw. I even use a shorter screw.
Fabulous is offline   Reply With Quote
Old 10-09-2015, 07:22 PM   #908
Fabulous's Avatar
If your using a three gear tranny than yes. If you have the kit 4 gear than you adjust on the other side.
Old 10-09-2015, 07:25 PM   #909
1M
1M's Avatar
The aluminum has no thread,
Searched on rc10.com, The part I have is not the one I need. RC10.com doesn't tell me what this one fits.
Old 10-09-2015, 07:36 PM   #910
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
is that the rear motor C?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-09-2015, 07:39 PM   #911
Fabulous's Avatar
I beleive you have the rear motor C mount and not the mid motor C mount
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 10-09-2015, 07:40 PM   #912
1M
1M's Avatar
After searching on rc10.com, the one I have is not the one I need.
Old 10-09-2015, 07:40 PM   #913
http://www.amainhobbies.com/rc-cars-...c91522/p275280
Old 10-11-2015, 12:35 PM   #914
Like cbass722 , I'm confused by this. Other Associated 4 gear kits have the Diff Thrust bolt head facing the spur gear. Why does Associated recommend the opposite in the SC5M manual for the 4 gear tranny?
SC5M Manual - Page 11
Gearbox Build - Bag F - FF - Step 2
"Install the Diff with the head of the Diff Thrust Bolt (#6573) facing the opposite side of the spur gear."
mwjcyber is offline   Reply With Quote
Old 10-12-2015, 10:28 AM   #915
dirt42fan's Avatar
Trader Rating: 135 (100%+)
I raced 2 times this weekend, had 3 right rear innner bearings go bad on me. Stock hubs with pucks. I have studied the movement over and over and i dont see anything binding at all.
Any thoughts?
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Frenimy
