    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree34Likes
Old 08-24-2015, 10:24 AM   #661
dbowen's Avatar
Originally Posted by Wildcat1971 View Post
Ran a few laps with my daughters sc5m this past weekend. I still think the front is too soft for a track running slicks. But, I could drive the truck fairly hard without traction rolling. I think the truck jumps flat out of the box. Even my daughter who has close to 1 minute laps can make it jump flat. But, It is very sensitive to breaking or whipping. When I has an SC10, once it was in the air, it was hard to control. I feel this truck is very sensitive in the air. If you try to scrub a jump, you might nose under and front flip. Our track does not have any long distance jumps, that require you to "pin it to win it". So that might be the difference. Anyway, durability seems good. My front bearing are not getting gritty, so I wonder if AE made some changes in the last year to the front hubs and/or the black seal bearings. Anyway, in short. The truck is still much better than I was expecting it to be. This weekend I might race it to shake it out. I really need some different front springs. If anyone has a good kyosho front spring for track tracking running slicks and wet tacky clay, I am listening
I would recommend reds and yellows I run yellows on my T5M. Yellow I believe is like a red AE and Reds between blue and yellow. But it is pure speculation bc they dont have a chart for Kyosho truck springs that I can find just buggy.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 08-24-2015, 10:44 AM   #662
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
many locals run AE purple on the front, for some perspective. I run AE run on the front of my B5m. LOTS of traction here
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-24-2015, 11:30 AM   #663
Originally Posted by Jmuck69 View Post
AE only makes one set of Brass C and D blocks, can't miss them
10-4 ordered them today!
atvracer9m is offline   Reply With Quote
Old 08-24-2015, 11:37 AM   #664
Make sure u get the inserts for the c mount. They are sold seperately.
slow1000rider03 is offline   Reply With Quote
Old 08-24-2015, 11:49 AM   #665
can you help me with a link or part number?
Old 08-24-2015, 11:50 AM   #666
found them.
Team Associated Rear Arm Mount Insert Set (C) ?
Old 08-24-2015, 11:55 AM   #667
will i need the D inserts as well?
Sorry for the questions this is my first NEW KIT car so I'm excited to add on and build a dialed race platform
Old 08-24-2015, 01:00 PM   #668
dbowen's Avatar
Well the stiffest Kyosho Truck spring is Orange, I believe, which is one step above Yellow so I guess get Yellow and Orange.
Old 08-24-2015, 01:06 PM   #669
this one?
http://www.amain.com/rc-cars/kyosho-...xgs023/p209311
Old 08-24-2015, 04:21 PM   #670
Fyrmed2's Avatar
Cav setup sheet http://www.teamassociated.com/pdf/ca...i_Shootout.pdf
Hobby Town USA - Lake in the Hills
Timewarp Raceway
IAFF Local 2392
Fyrmed2 is offline   Reply With Quote
Old 08-24-2015, 06:54 PM   #671
Yes u will need the inserts for the brass d as well.
Old 08-24-2015, 08:28 PM   #672
Trader Rating: 487 (100%+)
I'm not sure if they are available yet but AEs new truck springs have part #'s now. Its a little weird as they only go 1 step firmer and one step softer and that's it. You can ID them as the fronts are 54mm and the rears 72mm. Just look in the manual and add or subtract 1 from the part #s for the kit springs and that will give you the #'s for the optional springs.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-24-2015, 08:34 PM   #673
Default X Rings
Im building the new Kashima Shocks and was wanting to know if there is a difference in the Xrings vs the regular rebuild kit. Not really sure any help would be appreciated. Also what else do I need to rebuild the internal parts. The O-rings? Does the X-rings replace the red O-rings?
SC10.2B
B5M
T5M
SC5M Preorder
Futaba 4PX
MyLilPony is offline   Reply With Quote
Old 08-24-2015, 08:37 PM   #674
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Xring Rebuild kit comes with the plastic bushings, they are the same as the kit ones. Xrings by themselves are just that, no difference in the rings. Xrings replace the red orings
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-24-2015, 08:41 PM   #675
cool thanks so just need the Xrings to replace the red Orings and the spacers. Im assuming this helps with leaking and to use green slime also or no.
SC10.2B
B5M
T5M
SC5M Preorder
Futaba 4PX
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
cjcoffroad
