    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree28Likes
Old 08-11-2015, 01:29 PM   #526
Jmuck69's Avatar
Originally Posted by 3than0d311 View Post
It seemed to me at nats that a slick tire is what was the best "tread" to use but people still needed a little weight to get the tires to hook the way they needed.
I say this because after seeing the Cav was using a front wing on the b5m made me think that traction was a little tough and most of us know you can only add so much weight to the front before you start nose diving or chassis slapping the front. Seeing that he then addedbweight to the more rear section of the truck just kinda makes my hypothesis a little more plausible. I may be right but most likely not. As for me, when I run my sc5m on carpet this winter I don't think for me running extra weight will be necessary unless I absolutely need it.
(I know this was off the beaten path a little but it's been on my mind majority of the day.)
I believe the wing was for high speed stability, presumably for the straight. maybe the front lifted a bit and would loose some of the steering?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-11-2015, 01:51 PM   #527
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yes, high speed stability. And the front wing was on his 2wd buggy and I dont think he added weight to it. Buggy and SC and not the same.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-11-2015, 04:15 PM   #528
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
front wing was just a troll to see how many of us would bite.
ryanpatrickgore is offline   Reply With Quote
Old 08-11-2015, 05:39 PM   #529
aeRayls's Avatar
Adding weight when running on that much grip was to calm the cars down! With that much grip they become very aggressive and darty.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 08-11-2015, 06:21 PM   #530
Trader Rating: 14 (100%+)
This all really helps with my perception on adding weight.
In that case maybe I should do it for carpet. All of my cars liked shooting out if the corner but had issues keeping the rear end straight for the first 8-12 feet.
3than0d311 is offline   Reply With Quote
Old 08-11-2015, 06:59 PM   #531
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Turn the power down.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-11-2015, 07:09 PM   #532
Thanks for sharing wildcat1971, all this time I thought buggy and sc were the same. 😶
Sinistersmile13 is offline   Reply With Quote
Old 08-11-2015, 08:30 PM   #533
bignik957's Avatar
Put my truck on the track sunday an was having the same issue with it nosing over on our big double it was worse with the brick pack so I ran A shorty and took a couple turns out of rear shocks and it was much better I'm running 30/29 ride height with 35/30 oil and manual set-up otherwise
TEAM VP-PRO TEAM RADIOPOST PRESTIGE RACING WORLDIDE
bignik957 is offline   Reply With Quote
Old 08-12-2015, 09:16 AM   #534
mes
... As for me, when I run my sc5m on carpet this winter I don't think for me running extra weight will be necessary unless I absolutely need it...
Give it a try! On high-bite astro, we are running Team Yokomo Europe's 50 g plate under a shorty battery in the brilliant YZ-2. The car is even more planted and does not roll over. With a truck, you should do whatever you can to lower the cener of gravity.
mes is offline   Reply With Quote
Old 08-12-2015, 10:40 AM   #535
Default Awesome Sauce
Love the new short course truck have one race day under my belt and no one there was even close to matching this thing. I have a quick question does the MIP b5m diff rebuild work with the sc5m and t5m diff. Im not quite sure if the m series associated stuff have different ball diffs. Thanks in advance. Also is anyone running the schelle slipper yet on these and how do you like them. Are they worth the thirty bucks.
SC10.2B
B5M
T5M
SC5M Preorder
Futaba 4PX
MyLilPony is offline   Reply With Quote
Old 08-12-2015, 10:55 AM   #536
Jmuck69's Avatar
All the same. Transmission and internal components work in all 5 series buggies and trucks.
B6D | B64D
Old 08-12-2015, 11:41 AM   #537
Thanks JMUCk
SC10.2B
B5M
T5M
SC5M Preorder
Futaba 4PX
Old 08-12-2015, 12:22 PM   #538
mes
...Also is anyone running the schelle slipper yet on these and how do you like them. Are they worth the thirty bucks.
I've been running the oiginal Avid Triad for quite some time and now the Evo version, which doeas away with the conic spacers. It is almost the same as the Schelle, so you can use spur gears from both. I love the adjustability and feel of these slipper units and won't run anything else in an AE car or truck. There is currently no easy way to make it work in my Yokomo YZ-2, but as soon as I find a way, I'll replace the stock clutch assembly for sure.
In short: Yes, get one!
Old 08-12-2015, 12:23 PM   #539
jconcept hazard wheels are ok for this truck?
Bubonic-X is offline   Reply With Quote
Old 08-12-2015, 12:35 PM   #540
Yeak, the JC +3 wheels work. I am using the AVID +3 wheels
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
