    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree34Likes
Old 08-11-2015, 06:57 AM   #511
dbowen's Avatar
Originally Posted by Holeshot114 View Post
Thanks, I found some online. They're on the way
Can you post a link? And cant you get a thin brass sheet at home depot or something like that?
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 08-11-2015, 08:57 AM   #512
VegasHB's Avatar
I used a square and it was endo city for me off the triple
Can you tune it out with springs? Run a heavier front spring or stand the shock up more on the front tower. A lighter front oil might help as well, need a better rebound to keep the front up maybe. I hear the SC5m is close to minimum weight out of the box.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 08-11-2015, 10:04 AM   #513
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
http://www.ebay.co.uk/itm/55g-Polish...3D171822878896
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-11-2015, 11:07 AM   #514
dbowen's Avatar
Originally Posted by Wildcat1971 View Post
Thanks but do you know if Home Depot or Lowes has brass sheets? I remember someone saying one of those stores does that way I dont have to wait a week or two to get it I think putting that under my shorty and taping it in will solve a lot of my problems I am having with my truck.
Old 08-11-2015, 11:37 AM   #515
look for brass kick plates, for the bottoms of doors.
Old 08-11-2015, 11:38 AM   #516
maybe this?
http://www.homedepot.com/p/Prime-Lin...Q&gclsrc=aw.ds
Old 08-11-2015, 11:40 AM   #517
or this
https://www.google.com/shopping/prod...FZINkgodDi4NKQ
Old 08-11-2015, 12:41 PM   #518
Holeshot114's Avatar
http://www.smc-racing.net/index.php?...product_id=278
Holeshot114 is offline   Reply With Quote
Old 08-11-2015, 12:44 PM   #519
I need to try stiffening the front. Im definitely going with more weight. Brass C and D and battery compartment weights with a shorty instead of square pack. I'll post my results
Old 08-11-2015, 12:53 PM   #520
dbowen's Avatar
Thanks guys! I really appreciate it!
Old 08-11-2015, 01:08 PM   #521
VegasHB's Avatar
Just don't look at adding weight different places. Most problems can fixed by changing shock setup for the balance front to rear and camber link adjustment for the cornering ability.
Square pack is going to add more weight bias toward the front vs a shorty which is easily balanced with spring rate and shock positions. Take your truck and just drop it on a level surface and watch difference between the front and rear rebound speed. It's likely the rear of the truck is coming back up quicker than the front. If the rear is slapping then the rear oil is too light for the added weight of the square pack and this will cause the truck to endo as well. One trick is to record it with your phone, most phones now have a slow motion option so you can really see what's going on.
Old 08-11-2015, 01:17 PM   #522
Good tip. Thanks
Old 08-11-2015, 01:37 PM   #523
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Here is an under battery weight that looks like it could be beneficial to some.
http://www.amain.com/rc-cars/yokomo-...t-rw25/p417657
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-11-2015, 02:13 PM   #524
Trader Rating: 14 (100%+)
It seemed to me at nats that a slick tire is what was the best "tread" to use but people still needed a little weight to get the tires to hook the way they needed.
I say this because after seeing the Cav was using a front wing on the b5m made me think that traction was a little tough and most of us know you can only add so much weight to the front before you start nose diving or chassis slapping the front. Seeing that he then addedbweight to the more rear section of the truck just kinda makes my hypothesis a little more plausible. I may be right but most likely not. As for me, when I run my sc5m on carpet this winter I don't think for me running extra weight will be necessary unless I absolutely need it.
(I know this was off the beaten path a little but it's been on my mind majority of the day.)
3than0d311 is offline   Reply With Quote
Old 08-11-2015, 02:27 PM   #525
Super Moderator
SRS has traction up the wazoo, slicks are the only way to go there. The front wing was likely to give him better forward bite at high speed, without having to lift. The additional weight was likely to make the cars easier to drive. Like I said, traction was in abundance.
