    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree32Likes
Old 08-10-2015, 01:25 PM   #496
Originally Posted by slow1000rider03 View Post
+2 on this. I will be on a loose track dominated by rear motor configs so I am hoping I can piggy back off some setup tips from someone else.
Originally Posted by Newbie Rc Guy View Post
Anyone run this on a loose track yet?
+1
Anyone?
Curious to know if there would be an improvment over, say, an SC10.2 (or if there is even a good setup to make these trucks work) on a "real" dirt track. In other words, something you would expect to run Enduro, City Block, Grid Iron, Caliber, or Blockade type tires. Something with some ruts and a bit of loose dirt, especially after the 4x4SC heats, where people even add weight to the rear of their SC10's...
stelio279 is offline   Reply With Quote
Old 08-10-2015, 01:30 PM   #497
Originally Posted by motopat View Post
LOL, I get that but in a pinch could I use these without any negative side effects until I can new one. I kinda blew my budget buying the kit and the electronics.
Yeah you could use them. All it will do is make your truck a little narrower by a couple mm which will change the handling but probably won't even notice any difference. I've used different types of wheels many times and it felt just fine.
Sinistersmile13 is offline   Reply With Quote
Old 08-10-2015, 01:36 PM   #498
Originally Posted by stelio279 View Post
+1
Anyone?
Just ran mine over the weekend on a loose bumpy outdoor track with enduros and it handled really good. The only thing that I would change is softer springs. Other then that the stock setup worked well.
Old 08-10-2015, 02:07 PM   #499
Sounds good I'll find out this weekend
slow1000rider03 is offline   Reply With Quote
Old 08-10-2015, 02:53 PM   #500
Holeshot114's Avatar
How did it handle over the big jumps? What battery setup are you running?
Holeshot114 is offline   Reply With Quote
Old 08-10-2015, 02:55 PM   #501
My SC5 was really good on outdoor track this past weekend. Truck lands very well i went with the +4 c mount from the factory, along with a bunch of aluminum for looks. Truck was really smooth out of the box, build went smooth but seemed like some parts were in the wrong bag.
currymcflury is offline   Reply With Quote
Old 08-10-2015, 03:40 PM   #502
NeedsHobbyMoney's Avatar
Default Battery
I used a shorty set up at 702 on Friday. Seems like it'll be what I run for now, but if I find I need more weight I will slap in a square.
Team Associated
T5M | B44.2 Schelle Shorty | SC5M | RC8B3e | RC8B3
TEKIN | Airtronics | Savox | Avid | MIP
NeedsHobbyMoney is offline   Reply With Quote
Old 08-10-2015, 05:28 PM   #503
I used a square and it was endo city for me off the triple
Old 08-10-2015, 05:52 PM   #504
I was having that problem as well, but solved it through the throttle for the tine being.
Team Associated
Old 08-10-2015, 06:54 PM   #505
Trader Rating: 36 (100%+)
What size shock pistons come with the kit front and rear?
mxturd is offline   Reply With Quote
Old 08-10-2015, 07:22 PM   #506
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
2 X 1.5mm, 1.6mm, and 1.7mm
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-10-2015, 07:25 PM   #507
Moderator
bds81175's Avatar
I've been running a mid motor Losi for the full summer now to kick the tires on mid motor short course before the SC5M was released. I'm definitely faster on smooth higher grip tracks with the mid motor. And I am at least as fast on the loose tracks as well. I have found that increasing rear toe is very beneficial (I finally settled on 4 with the Losi) and doesn't seem to as adversely affect steering as with the rear motor. The mid motor also seems to have a much narrower window of tuning effectiveness compared to a rear motor. All in all, the mid motor is just plain funner to drive. If you enjoy tuning and driving a car with a bit of smoothness and finesse, mid motor is the way to go.
Tekno RC
Old 08-10-2015, 07:37 PM   #508
ROAR NATS: Inside Ryan Cavalieri's winning cars
Chassis: Team Associated SC5M Team
Motor: Team Orion VST2 LW 7.5
ESC: Team Orion R10.1 Pro
Battery: Team Orion Carbon Pro 4500mAh shorty
Radio/Receiver: Airtronics M12/RX481
Servo: Airtronics 94671
Tires: AKA Typos (ground down), Clay compound
Body: JConcepts Hi-Flow
Notes: Hard front arms, brass C-plate, Factory Team aluminum rear hubs, and Kashima shocks with silver shafts. Brass weight under the battery.
Anyone know what this brass weight under the battery looks like?
Old 08-10-2015, 09:18 PM   #509
Very thin sheet under the battery, about the same size. Maybe like 1.5mm ish?
Team Associated
Old 08-10-2015, 09:22 PM   #510
Thanks, I found some online. They're on the way
