    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree27Likes
Old 09-11-2017, 05:33 PM   #2611
zeakemedia's Avatar
Trader Rating: 72 (100%+)
https://www.prolineracing.com/pro-li...-red-hard-kit/
I run the red front and yellow rear on my T5m. They're discontinued but still in stock.
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 09-11-2017, 06:02 PM   #2612
denon's Avatar
Default Rear Clamping Hex
Are these the rear hexes to use? Any other better options?
https://www.teamassociated.com/parts...1014-ASC71014-
ft_clamping_wheel_hexes_8_5mm/
B6 | SC5M
denon is offline   Reply With Quote
Old 09-11-2017, 06:29 PM   #2613
tsair's Avatar
Blake
Cool, thanks for the link. Any ideas if the lengths front/rear are about the same?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 09-18-2017, 03:50 AM   #2614
Hasi's Avatar
Sorry guys,
after reading much about your used wheels / rims in this thread and what the standard offset of the KMC wheels is (0 offset, for anyone searching too), I'm wondering which rims to get.
I'm running the black Asso KMC wheels (#91101) at the moment which have 0 offset and don't want to get more, but other rims.
Decided to get the Jconcepts Hazards to get matching colors with the yellow Asso rims on my B5 and B64D , but the Hazards for the SC5m (part #3344Y) are +3 offset.
To stay with the 0 offset I have now, I guess I would have to get the ones for the Losi SCT-E (part #3352Y), right?
Would that work?
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 09-18-2017, 06:13 AM   #2615
From what I've read, the offset is a bit misleading. The SCTE wheels are, well, let's call them "true 0" offset for simplicity. Then there's the KMC wheels, which are not actually 0 by comparison, but a bit more. And then there's the +3 offsets which are wider still. On the SC5M you can use all three. On the SCTE on the other hand you can only use the "true 0" ones because the others will cause it to be too wide for many SCT class rules, as well as rub on the body.
For the SC5M technically the +3 ones would be the best because they make the car wider and more stable. Personally I have some KMC wheels that I bought for myself (originally for SC10) and some +3 ones that I got used. But as said, you can use whichever you wish, basically. At least when I tried on my SCTE wheels on the SC5M I didn't notice any binding or such... but mind you, I didn't actually drive with them on.
tvih is offline   Reply With Quote
Old 09-18-2017, 07:11 AM   #2616
Hasi's Avatar
Thank you very much for your thoughts and experience, much appreciated
My SC5m is already very stable, it's easy to catch when the rear slips in turns. It's more like it could use a little bit more steering, setup is still out of box on loose, hard clay.
I want to keep this so I looked for 0 offsets like the KMC were stated... hm...
A friend of mine got an SCTE; guess I'll try his rims in terms of binding etc.
Thanks again, I will report
Old 09-18-2017, 09:44 AM   #2617
denon's Avatar
Default Motor Suggestions
Looking for some suggestions for a budget 17.5 motor for my son's sc5m. Has a speed passion pro 1.1 esc. Was looking at the speed passion 17.5R or maybe the Reedy 17.5 stock spec. Any other ideas? Just looking for something to get him into the class and keep it on the track
Old 09-18-2017, 10:52 AM   #2618
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
https://www.rcjuice.com/motor-esc/br...red-motor.html
or
Totemic 17.5T
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 09-18-2017, 01:01 PM   #2619
denon's Avatar
Originally Posted by Wildcat1971 View Post
Perfect. Thanks!
B6 | SC5M
Old 09-18-2017, 01:14 PM   #2620
My suggestion would be a Turnigy TrackStar V2 17.5t from Hobbyking. I have the 6.5t version on my SC5M and it works very nicely, and also getting the 17.5t for an onroad car.
Old 09-18-2017, 05:17 PM   #2621
Perfect. Thanks!
The totemic is nice, because SMC has pretty good customer support.
Old 09-18-2017, 05:51 PM   #2622
zeakemedia's Avatar
Pro-Line springs are just a little bit longer than AE truck springs.
Blake
Old 09-18-2017, 06:32 PM   #2623
tsair's Avatar
Blake
Thanks for the pic, much appreciated!
zeakemedia likes this.
Razor RC blog:
Old 09-20-2017, 11:31 AM   #2624
Notice anything "unusual"?
Finally decided to try installing the Pro-Line cap mounts. To hopefully minimize loss of structucal strength of the body posts caused by the drilling, I applied a thick layer of very strong (240kg/mē tensile strength) epoxy to the underside of the "disc" to thicken the joining of the disc to the post. I figured thickening the post walls needed to be done and this was the simplest method of doing so that I could think off the bat, while hopefully being strong enough to make a difference.
Time will tell if it'll hold up in use. I probably should've tried to do an ever so slight tilt to screw hole to better conform to the body shape, but to be safe I tried to drill straight. Not succeeding perfectly I suppose, but it is usable.
I did order a new cap set today, but since I wanted to see if it works right away I stole the set screws from the SC10 for the time being.
Also the gear diff arrived today, assembled it but haven't installed it yet - a task for another day, I think.
Cb750CafeRacer likes this.
Old 09-20-2017, 04:26 PM   #2625
a1
a1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
fastchevyboy, jmcelroy42
