Team Associated SC5M Thread
#2387
Yes I ran 17.5 from December to April 8th except for a one off carpet race. Now I am moving outdoors for the summer season and nobody near me has 17.5 so switching to the 8.5 for summer. At this point yes it is has been better with the 17.5 motor, I ran 17.5 spec class and Mod SC with the 17.5 in the truck. Trying to find a good outdoor setup with the 8.5.
#2389
Right now I am running a 10.5 Viper 3300kv motor. I would like to know if I run a 13.5 or 8.5 motor, would either one give me more over all power? I want more power than my brother who running a Tacon 3650-3500kv 10t motor.
As I am not a racer, I am looking for a budget motor.
Hobbywing ezrun 8.5t or a 13.5t motor.
HobbyStar 8.5t or a 13.5t motor.
SkyRc 8.5t or a 13.5t motor.
I want enough more to beat my brother.
Buzz
Buzz
#2390
If your are running sensorless this should out power your brothers truck.
https://www.hobbywingdirect.com/prod...nt=27755254929
The 4000KV version.
The 4000KV version.
#2391
I should have said I am running a "CHEAP" sensorless ESC as the Viper ESC never did work well and finally just stopped working. So I bought the lowest priced ESC I could find. The ESC does work with my Hobbywing program box.
The sensorless has a lot better control in the corners and smoother over all. We were running the same setup. I tried the Viper and it did not work out that well.
So looking for a better sensorless setup.
Buzz.
Buzz.
#2392
#2394
Team Associated B6 & B6D Setup Sheets
#2395
anyone running the three gear tranny?
What do I need to get besides the case?
#2396
the case and motor plate I believe is all that is needed.
#2397
So it uses the same internals from the stock gearbox, just minus one gear?
#2398
The motor plate for 3 gear for sure. I am not sure about the top shaft. Someone else verify that. It seems like I recall there being two top shafts. If you had one, it would work on both...but, the other one would only work on one of the configurations. I am no expert!
#2399
#2400
Don't forget the topshaft spacers
