    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 01-29-2017, 09:54 PM   #2191
Picked up a sc5m roller a while back. I am getting ready to put the aluminum c & d braces/blocks in. It currently has the plastic ones installed. How do I know what pill configuration to use to get the same setup I have now?
freezeframe007 is offline   Reply With Quote
Old 01-31-2017, 08:09 AM   #2192
Thinking of getting back into the mix. My son has an SC10 RTR and I have a SC10.2. I'm thinking of retiring the RTR and building up the SC5M for the boy. It seems like the 3-gear is definitely the way to go. Can anyone sum up what's necessary for the 3-gear tranny? Do I just need the motor plate and tranny case?
Also can't believe there's still not a FT version of this with the 3-gear, aluminum hexes, etc. SMH
Excellent Lipo Guide: https://rogershobbycenter.com/lipoguide/
Jason B is offline   Reply With Quote
Old 01-31-2017, 08:20 AM   #2193
This is what I did when I bough the kit. You just forgot the gear cover. The kit comes with all of the internals but you wont use one of the idler gears.
asr524 is offline   Reply With Quote
Old 01-31-2017, 08:51 AM   #2194
Thumbs up
Excellent - thanks!
Old 02-01-2017, 12:51 PM   #2195
Just picked one of these up... what do I need to use the FT hexes on the front and rear? I'm also picking up the parts for the 3-gear tranny... any other must-haves? Are squares or shorties better suited?
Old 02-02-2017, 08:45 AM   #2196
mxnickj's Avatar
Trader Rating: 51 (100%+)
Its been a few years since AE did any "factory team" cars. For the most part their cars have been pretty awesome right out of the box and the other stuff has just kind of been upgrades down the road and tuning options. Not all tracks and drivers really benefit from the 3-gear setup and things like the brass c-block and stuff like that, just gives you more options instead of releasing an entire new car with those things that might not benefit in EVERY situation. I do agree with the hexes though, they should just do away with the plastic ones all together.
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 02-02-2017, 09:40 AM   #2197
The front axle has an integrated hex so you would only need the rear set.
Old 02-02-2017, 10:07 AM   #2198
cameronspruill's Avatar
Trader Rating: 20 (100%+)
I put a laydown transmission in this truck and boy did it make a difference. AE really needs to think about rereleasing it with the b6 laydown tranny in it I bet it would sell really well.
cameronspruill is offline   Reply With Quote
Old 02-02-2017, 12:45 PM   #2199
Braxamus's Avatar
picked one up last week, went thru it and fixed a few problems I found and some stuff I didn't like. Rebuilt the shocks, put it back to the manual setup, going to be running mod on an indoor med to high bite track, with a 8.5 motor, any suggestions as to battery placement (shorty) will only have the springs that came on it to stat with white/white and the recommended 32.5 oil in shocks. or other adjustments I should do to start with.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 02-02-2017, 01:00 PM   #2200
aeRayls's Avatar
[QUOTE=Braxamus;14824344]picked one up last week, went thru it and fixed a few problems I found and some stuff I didn't like. Rebuilt the shocks, put it back to the manual setup, going to be running mod on an indoor med to high bite track, with a 8.5 motor, any suggestions as to battery placement (shorty) will only have the springs that came on it to stat with white/white and the recommended 32.5 oil in shocks. or other adjustments I should do to start with
If you don't have the gray front springs or a front sway bar or drilled 3rd hole in the front arm... I would recommend using 35-37.5 oil in the front.
aeRayls is offline   Reply With Quote
Old 02-02-2017, 01:34 PM   #2201
Default It's an option...
I have 2 sc5m. One with 3 gear standup, and one with 3 gear laydown from Shapeways. I really can't tell much difference. About all you really get is more front weight bias, and that can be achieved with a lipo weight. It's an option, but not the holy grail.
rlm996 is offline   Reply With Quote
Old 02-02-2017, 01:36 PM   #2202
AeRayls
Do you know anyone running the 3rd hole in the front arms? I'm interested in this....
Old 02-02-2017, 06:59 PM   #2203
aeRayls's Avatar
Originally Posted by rlm996 View Post
AeRayls
I ran the 3rd hole forever until, front sway bars came about. I still always run the 3rd hole on the T5 and so just add 1-1-5mm more droop
Old 02-02-2017, 09:12 PM   #2204
czrlaker's Avatar
Trader Rating: 24 (100%+)
I installed the shapeways laydown tranny in it expecting less roll (carpet racing) can't tell the difference. Still rolls @ same spots/speeds I lowered it a bit more and thats what makes the biggest difference.
czrlaker is offline   Reply With Quote
Old 02-03-2017, 12:56 AM   #2205
Hasi's Avatar
Which ones of the clamping ones do I need for a direct change with the stock plastic ones without changing the offset?
#71014 (8.5mm)
#71034 (6.0mm)
#91609 (5.0mm)
#91610 (7.0mm)
I'm a bit confused...
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
