    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 12-20-2016, 07:11 AM   #2101
Azzkikin's Avatar
Everywhere says it'll be in stock on Dec 31st if you can hold off a little while longer. I know I am in search of one too.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-20-2016, 07:28 AM   #2102
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
There are a few Online shops that might have a few bumpers left in stock if you know where to look
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-20-2016, 05:08 PM   #2103
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Hey Guys, random question...
...does anyone know if the front body mount for the SC5M will fit the old SC10.2 front tower?
Thanks!
Rich Panganiban is offline   Reply With Quote
Old 12-20-2016, 10:54 PM   #2104
Trader Rating: 75 (100%+)
Originally Posted by bds81175 View Post
That's exactly what mine did. I've seen many others with the same damage. Wease doesn't have one to break at this point though. Anyone have an extra for him?
Found one! Google search came up with nothing, so I switched over to Bing and found a small hobby shop in Oregon with an online store. The online store said they had 1 in stock so I called them before ordering. Sure enough, that had one and it's on the way to me
On an unrelated topic, how much back and forth movement do you have with the rear arm between the inner hinge pin braces? I converted my T5M to the SC5M but the parts should be the same, yet I had a good 2 - 2.5 mm of back and forth movement. I found a 2mm plastic washer and installed it between the arm and the aluminum D block. I removed the shocks to make sure the arms still moved up and down freely which they did. I know some space should exist there, but more than 2mm seems excessive.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 12-21-2016, 03:08 AM   #2105
Default Sc5 Rims
What offset rims are needed for the sc5?
phinsfan76 is offline   Reply With Quote
Old 12-21-2016, 04:21 AM   #2106
Azzkikin's Avatar
Thanks!
Yes they will. If I remember right, they are shorter than the sc10.2 though.
Old 12-21-2016, 04:59 AM   #2107
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Page #8 of the T5 and the SC5 manual show a spacer in front of the arms
part #71010
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 12-21-2016, 06:10 AM   #2108
Default Sc5m rims
Bought a roller online what offset are the rims for the sc5m?
Old 12-21-2016, 07:05 AM   #2109
part #71010
Thank You, thank you, thank you! I guess I forgot about it since I built the T5M so long ago
XRAY 17 XB4
Yokomo YZ-2 CA
Old 12-21-2016, 07:15 AM   #2110
0mm~3mm offset should work just fine
Old 12-21-2016, 07:27 AM   #2111
jonski's Avatar
Trader Rating: 241 (99%+)
+3mm are the standard wheels for the SC5M
First RC car was a RC10T - 1992
jonski is offline   Reply With Quote
Old 12-21-2016, 11:40 AM   #2112
Hey gang, does AE make a non-coated shock body for their 12mm shocks? Hard-coated, Kashima or otherwise?
Old 12-21-2016, 11:40 AM   #2113
Thanks!
Old 12-21-2016, 05:40 PM   #2114
Default Bearings and size
I have a sc5m roller on its way and wanted to order some new bearings, any suggestions? Also how many are needed and what size?
Old 12-21-2016, 06:53 PM   #2115
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Check out Avid bearings. A buck a bearing or buy their kit specifically for the SC5M.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Frenimy
