    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 12-09-2016, 04:43 PM   #2056
jonski's Avatar
Trader Rating: 241 (99%+)
Originally Posted by Slammed80 View Post
Here's mine. Used some left over traxxas links with a custom bar and mounts. Huge difference in handling
Do you remember what sway bar holders those are?
jonski is online now   Reply With Quote
Old 12-09-2016, 05:30 PM   #2057
I do, made them myself
Slammed80 is offline   Reply With Quote
Old 12-09-2016, 07:39 PM   #2058
C5R01's Avatar
Send a message via Yahoo to C5R01
Default Pro line Raptor
Can some who has the flotek raptor show how they mounted the rear post. Seems there is a week spot if you cut the holes out in the back of the body. Thanks in advance.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 12-10-2016, 01:14 PM   #2059
jonski's Avatar
Anyone running B6 rear hubs?
Old 12-10-2016, 01:52 PM   #2060
I just installed schelle aluminum rear hubs. Much less slop than factor plastic ans more running options.
tylem28 is offline   Reply With Quote
Old 12-11-2016, 01:44 PM   #2061
Broken my first front A arm yesterday. Replaced with what the track had In stock. Do the hard arms hold up better?
Old 12-11-2016, 07:38 PM   #2062
blwaz23's Avatar
For those running the laydown in the SC5M what company's laydown are you running?
blwaz23 is offline   Reply With Quote
Old 12-11-2016, 08:02 PM   #2063
Will the b6 lay down transmission work?
SlashBash10 is offline   Reply With Quote
Old 12-11-2016, 08:56 PM   #2064
Also another question, I replaced the front axles with the T5M clamping axle (ASC71013) so I could use the 6.5mm Clamping front hexes. I noticed after putting on my wheels (Jconcepts 3mm offset Hazards) that the wheel nut is all the way bottomed out when putting the nut on. There is a little flex as it seems like there is half a turn maybe left that it would need to be completely snug.
Has anyone experienced this? It seems like the stock axle has a wider offset than the t5m axle with 6.5mm clamping hex. Would putting a bigger clamping hex such as the 8.5mm snug it up more? Or would I be better just to remove those and put the stock axle back on?
Old 12-11-2016, 09:05 PM   #2065
aeRayls's Avatar
Those axles just ended up not being quite right for the sc5 by a hair using the 6mm hex. Me personally I would rather keep the correct offset. So I'd put the stock axles back on.
aeRayls is offline   Reply With Quote
Old 12-11-2016, 09:16 PM   #2066
That's what I was thinking but wanted to make sure it wasn't something I was doing wrong or I was crazy. I like the idea of the clamping hex but I also would rather have a wider offset for more stability.
Do the hard arms make a difference or are they pretty much the same as the standard arms?
Old 12-11-2016, 10:54 PM   #2067
aeRayls's Avatar
The hard arms take away a small bit of grip but adds a lot of consistency in how the truck corners/lands/accelerates.
Old 12-12-2016, 01:27 PM   #2068
unfortunately no.
not sure you would get any performance gains and the truck jumps poorly with the battery/weight forward biased (imo of course).
hsp-sandiego is offline   Reply With Quote
Old 12-12-2016, 03:39 PM   #2069
Thanks man. Do you know of any lay down trannies that'll work? I race indoor clay
Old 12-12-2016, 06:50 PM   #2070
I could be wrong as I am learning myself but, I don't think a laydown tranny in a SCT will make much of a difference. Are you running a 3 gear or 4 gear tranny currently?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
