    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree25Likes
Old 11-22-2016, 05:50 PM   #1981
aeRayls's Avatar
Originally Posted by tylem28 View Post
Also what size clamping Hexes (aluminum) for the front and for the rear? Also what offset wheel to use with these Hexes?
6mm front and 8.5 rear
You'll want the +3 wheels
aeRayls is offline   Reply With Quote
Old 11-22-2016, 06:58 PM   #1982
Thank you. Can someone please confirm these are the correct parts? These are TowerHobbies Part numbers.
LXFLDV Associated 1/10 RC10SC5M Team Kit
LXEXKP Associated FT Front Motor Plate Black 3 Gear
LXEZVT Associated Clamping Wheel Hex Blue T5M (2)
LXFLXC Associated Clamping Wheel Hex 6.0mm Blue (2)
LXBNWV JConcepts Hazard 3mm Wider 12mm Hex Whl SC10/4x4 Blk(2)
LXCVHH Associated Rear Spring Gray 12mm 2.20 lbs
LXCVGY Associated Front Spring Gray 12mm 3.45 lbs
LXFDCY Pro-Line Prime SC 2.2"/3.0" MC (Clay) Tires Fr/Re (2)
LXEXKT Associated FT Aluminum Top Shaft B5M 3 Gear
LXEXKU Associated B5M Gearbox 3 Gear
tylem28 is offline   Reply With Quote
Old 11-22-2016, 09:34 PM   #1983
Big_Show's Avatar
Will the RPM ball cups fit the SC5M or is the cup to small?
Also I thought the stock hex's was 5mm and you could either get +3mm offset wheels or run the 8.5mm hex's with 0 offset wheels.
RC10B6D/RC10T5M/RC10SC5M
Big_Show is online now   Reply With Quote
Old 11-23-2016, 04:33 AM   #1984
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
The stock ball cups are better than RPM, believe it or not.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-23-2016, 04:50 AM   #1985
Big_Show's Avatar
Ok, I was wanting to add some color to my chassis. But if stock is stronger I will use them. Thank you
Old 11-23-2016, 07:39 AM   #1986
aeRayls's Avatar
6mm front and 8.5 rear with +3 wheels. This is the only combo you want to run!
Old 11-23-2016, 07:42 AM   #1987
sduffy77's Avatar
Trader Rating: 18 (100%+)
For those that have added a front sway bar, what setup changes did you end up making to compensate for the stiffer front end if any?
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 11-23-2016, 07:43 AM   #1988
aeRayls's Avatar
Those are not the correct springs, those are buggy springs. You'll want the new truck springs. Associated part numbers: 91637 and 91641.
Also, you won't need a new topshaft for the 3 gear. It already comes with that alum topshaft in the kit.
Old 11-23-2016, 07:45 AM   #1989
aeRayls's Avatar
Also, to use the front clamping hexes you'll need front clamping axles. AE part number 71013.
Old 11-23-2016, 09:15 AM   #1990
Thank you, Thank you!!!!! I appreciate all the help!
Old 11-23-2016, 10:04 PM   #1991
Big_Show's Avatar
Thank you Rayls.
Old 11-24-2016, 04:04 PM   #1992
Needing some help with the front SC5M wheel Hex. Tower Hobbies has them on back order for part number 71034. Would SLF1006 fit? Hot Racing Blue Aluminum Locking 12mm Wheel Hex Kit. Are these the same?
Old 11-24-2016, 05:14 PM   #1993
or would these work as well?
Tekno RC Aluminum Hex Adapter 12mm M6 Driveshaft
TKR1654X
I guess what my question really is if I am using the Proline Hazard wheels, will they work on the stock front hubs while I wait for the hex adapters to ship?
Old 11-24-2016, 05:17 PM   #1994
Trader Rating: 15 (100%+)
TKR1654X
Why do you need front clamping hexes? I've used the stock steel ones with no issues whatsoever.
sluther343 is offline   Reply With Quote
Old 11-24-2016, 05:53 PM   #1995
I was under the impression you needed them to run the JConcepts Hazards wheels with a 3mm Offset. Is this not correct?
