    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 11-18-2016, 03:34 AM   #1966
Default Servo
What would you recommend for a steering servo for a team associated sc5m that won't break the bank?
MikeyBigs is offline   Reply With Quote
Old 11-18-2016, 04:32 AM   #1967
Big_Show's Avatar
This is the ones I use. https://www.amainhobbies.com/reedy-r...c27109/p511084
https://www.amainhobbies.com/reedy-r...c27101/p428453
I thought about going Savox but you have to use capacitors to avoid brown outs.
RC10B6D/RC10T5M/RC10SC5M
Big_Show is offline   Reply With Quote
Old 11-18-2016, 05:08 AM   #1968
abailey21's Avatar
Trader Rating: 36 (100%+)
I like the Reedy's mentioned above, also Love the ProTek 170bls, pricy but worth it
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-18-2016, 06:13 AM   #1969
A TS-920 would be perfect: fast, metal case+gears, takes HV, and cheap. I've run them in a SCT410 and D413 with no problem.
PetRock is offline   Reply With Quote
Old 11-18-2016, 09:14 AM   #1970
Is this better than the Savox servo's?
thatrccarguy is offline   Reply With Quote
Old 11-18-2016, 11:43 AM   #1971
Originally Posted by tylem28 View Post
okay, good to know. I'm looking at the Tekin ESC / Motor combo. I was looking at the RSX or the RS Gen 2. What motor would be the best combo to pair with? Running a small indoor carpet track and also a medium to large size clay track
can anyone help answer this? Thanks
tylem28 is offline   Reply With Quote
Old 11-18-2016, 11:57 AM   #1972
Trader Rating: 15 (100%+)
7.5-10.5 would be good. I switch between a 10.5 and a 7.5 depending on trac conditions.
sluther343 is offline   Reply With Quote
Old 11-18-2016, 12:10 PM   #1973
Okay good to know. Thanks! Is it worth the extra money to go to the RSX ESC vs the Gen 2? I know the Gen2 can only go to a 8.5T but and the RSX can do all the way down to 2.5T .
Old 11-18-2016, 01:09 PM   #1974
mxnickj's Avatar
Trader Rating: 51 (100%+)
I know from experience that the 8.5 limit on the RS gen2 is no joke. I had issues with it even handling that much motor. However, that was in a 4wd buggy. But for what its worth, I only run a 10.5 in my SC5M and its plenty for a medium size indoor clay track. For me I feel like much more motor and it gets hard to drive. With the 10.5 I feel like I'm actually able to use the power that is available, not just babying it around the track to keep the wheels from spinning.
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 11-18-2016, 05:10 PM   #1975
Thanks, I know a lot of the guys at the local track were running 8.5T motors. I can always turn it down as well. Was just curious if the RSX was the better route to go.
Old 11-19-2016, 05:59 AM   #1976
mxnickj's Avatar
With the 8.5 I would say for sure go with the RSX
Nick Johnson
AE SC5M - AE B6D
Old 11-19-2016, 07:16 PM   #1977
jonski's Avatar
Trader Rating: 241 (99%+)
Anyone have a good starting setup for indoor med-high bite clay? We run JConcepts Dirt Webs in Gold. Only have had the truck for a few weeks and just wanted to see where everyone else is at.
First RC car was a RC10T - 1992
jonski is offline   Reply With Quote
Old 11-19-2016, 07:36 PM   #1978
Trader Rating: 488 (100%+)
Its very hard to beat a Savox 1258. Their warranty service is solid too.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-22-2016, 05:46 PM   #1979
What are the MUST HAVE accessories / upgrades for this kit? I will be running on both carpet and clay tracks.
Old 11-22-2016, 06:04 PM   #1980
Also what size clamping Hexes (aluminum) for the front and for the rear? Also what offset wheel to use with these Hexes?
